Question about Zanussi F1245W Front Load Washer
Blowing Fuses.... My washer blew its fuse,and went pop from the lower front left hand corner. When I laid it over to look at the fault,there was a bit of water under a plastic sheet which covers 2 terminals on a long 12" plastic box,to which the pump is connected to on the right hand side,and the fluff filter also connects to this box. I dried it completely,covered it with a bag,(in case there was a slight drip somewhere),but when I tirned it on the fuse blew again! - It did not blow straight away,as it seemed ok for a start,but when I think it reached the setting to 'wash' and put the water in,there was a humm sound,and little else,then it blew again. The door seal is brand new, and I cannot see any obvious fault with the machine.....please help :0 Thank you..
  • fini Dec 08, 2007
    cleaned filter, examined motor.
  • 883 Answers
It may be the water inlet valve has expired? use an ohmmeter to check when powered down
Posted on May 23, 2007
Where is the horn fuse to the 99 cutlass oldsmobile
Fuses are located in the relay center, on the passenger's side, below the instrument panel. You must remove the sound insulator on the right side of the passenger footwell to replace these fuses. Open this and you will see a bunch of relays and in the lower left hand corner is 4 rows of 3 fuses. The 3rd one down on the left hand side is the horn.
Jan 24, 2017 | Oldsmobile Cars & Trucks
Where is my fuse box located? haha
there is two. one is under the dash board on the left hand side, or the drivers side. to best describe, put your hand on the brake pedal, go a little bit to you left, once you reach the wall, plastic, or end of carpet(trying to use best description) there is a little trap door with a handle on it that you turn 90 degrees to open that fuse box. the other one is in your engine bay. pretty much, pop the hood, look at your top left corner, there is a little black box with a cover on it, remove the cover, there are the rest of your fuses. hope this helps.
Jun 01, 2011 | 1994 Honda Accord
Need diagram 2001 vw new beetle fuse panel. When I bought it did not have panel cover........thanks! problem with washer pump book says #1 10 amp small fuse and #24 20 amp no where on fuse panel says #'s
The #1 fuse is in the upper left corner of the fuse panel, actually its the top fuse in the third row down, but row No. 1 and No. 2 do not have any fuses in the upper left corner. There are a total of 23 fuses in the upper most section. Fuse #24 is the first fuse in the lower section of fuses (upper left corner of that section as well.
The block diagram for the fuse panel is also contained in Section 3.2 of your Owner's Manual. The fuses are numbered in each section from top to bottom starting in the upper left. Fuses 1 thru 23 in the top section, fuses 24 thru 44 in the bottom section which consists of three columns.
Oct 28, 2010 | 2001 Volkswagen Beetle
Lights arent going on,boyfriend changed fuse yesterday and it worked. Gotta do it again to be able to drive to shop. Need fuse layout for headlights
It's not a fuse problem....
The car has at least 4 fuses for headlights. one for each Dip left + right hand side (10A mp approx) and 2 more Main left + right. Your front fog and sidelights are also seperate fuses. A doggy connection or relay is a high suspect instead.
Mar 18, 2010 | 1995 Chevrolet G20
01 Grand Caravan wiring problem
Found a corroded / shorted wiring harness below the TCM in front of the left front wheel.  Repaired the wires - now works fine.
Jan 10, 2009 | 2001 Dodge Caravan
Possible electrical problems.
I would suggest that you check to see if the battery is connected properly---correct polarity!
If connected wrong, main fuse will blow. Lights come on because power is routed through the frame (ground) briefly.
Hope this helps.
Dec 23, 2008 | 2003 Mazda Protege
Power surge resulting in: no picture, sound or anything!
hello sterling home the fuse is located in the lower right hand corner of the main power board that is located just off center of the tv to the right a bit.. then there is another 2 fuses on a board located to the right of that and another fuse on the board all the way on the left side of the tv ..hope this helps ..oh and by the way if you end up having a bad power supply i do have 1 for that model ..
Nov 20, 2008 | Televison & Video
Navigation system, radio, front power outlet failure
The solution is to buy a new mini fuse (Blue #15) at an autonation or similar. Open the passenger side kick plate fuse box and pull out the fuse in position #9 (upper most left fuse). You will need needle nose pliers or tweezers etc... Insert new fuse and you are done. 50 cent repair and 30 seconds spent screwing with it. Enjoy! Oh, and don't worry about blowing it again. Best I can say is when starting the car, unplug the power sucking device like a radar. Once car is on you can re-insert it the radar. The initial jolt of powering everything on all at once is what blew your fuse in the first place. Get a few additional fuses to have on hand just in case.
Jun 29, 2008 | 2005 Acura MDX
Fuse keeps blowing
This is probably a water heater problem  Try operating on the lowest temp  eg.15C If it goes through the cycle then its more than likely your water heater  You will need a refit
Jun 01, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Burners Blew
if you will send me your model number off your serial plate on your range will be on front open oven door or lower drawer some where and when you bought it i need to check the service bulletins before i reply but dont rate me till were done
Jan 02, 2008 | KitchenAid KESC300 Electric Kitchen Range
Zanussi F1245W Front Load Washer Logo
65 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
