Question about Food Mixers
Repair help dormeyer hand mixer hm6-5
Need info and re-installing a part
  • fontella hankins Nov 03, 2012
    I could not get beaters to release when I pushed button to do so. So I took case off to look inside. I think I solved the the problem with a little oil. However, there was a small, thin piece of material , sort of "tee" shaped laying inside and I don't know where it belongs. Perhaps it was a shield to prevent something getting in the fan. I have placed it under a bracket that the beater release button pushes down; since I didn't see where it would fit anyplace else.
My Hamilton Beach model 63220 mixer won't mix motor is running but mixer is frozen and will not turn
If mixer is locked in down position, and you hear motor running, the problem could be worn gears in mixer head. Check warranty and return to place of purchase or take to small appliance repair shop for estimate.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 20, 2016 | Hamilton Beach Food Mixers
Kenwood HM320 Hand White 250 Watts Mixer
could be the result of a bad bearing,either that or something has caused the offbalance of the rotor.it should be repairable,if you take it to some repair workshop,unless you would want to take it apart yourself.
Apr 21, 2012 | Kenwood HM320 Hand White 250 Watts Mixer
DORMEYER stand mixer maintenance
Sadly, the service directions, while excellent, are for a Sunbeam Mixmaster Model 12...uselful for a Dormeyer only in the most general of terms.
Dec 12, 2011 | Food Mixers
How to disassemble Dormeyer mixer, Model 4300, to get to the motor?
how do you remove the power cord on dormeyer model 4300 mixer
Dec 05, 2011 | Food Mixers
We have a Cuisinart Hand Mixer Model # HM70 and the Beaters do not stay in the mixer holes. Can this be fixed in any way? Jack
Cuisinart hand mixers are not repairable. You can buy replacement accessories like beaters, but you can't buy any internal replacement parts.
I have a Cuisinart HM-70 and I stripped the plastic gears inside by trying to mix a really thick dough. It was easy to open and get to the plastic gears. When I called Cuisinart to try to get replacement gears, they said that they don't sell replacement parts and their hand mixers are not repairable. I looked all over the internet and no one sells internal parts.
Unless your mixer is still under warranty, I believe that you're out of luck and your mixer is headed to the electronics recycle pile.
Most handmixers today are sold with plastic gears - including high end brands like Viking. For me the lesson learned is to buy low end hand mixers (don't buy a top of the line 9 speed mixer) and treat them like they're disposable when they break.
Dec 03, 2010 | Cuisinart HM-70 220 Watts Hand Mixer
Kitchenaid KHM7T
Hi. Before you take your mixer apart, take a multimeter and test for continuity in the cord. Wiggle the ends of the cord while you're doing this in an attempt to make the cord fail. If it tests out OK, then you must get inside the mixer. If you have the ability to repair the mixer then do so, otherwise take it to a repair place for them to check it out.
Goto www.kitchenaid.com, enter your model # and search for the parts catalog for your mixer. Download the info. This will help you with the project
If this solution has assisted you, please rate it. Good luck! ricardok45
Mar 22, 2009 | KitchenAid KHM7T Ultra Power Plus Hand...
Replacement Beaters for GE Hand Mixer
Hi, replacement beaters can be found at amazon, click here and take a look: Amazon com hand mixer beaters. Wish you best of luck.
Ned
Dec 02, 2008 | Black & Decker MX55 PowerPro Hand Mixer
Replacement beaters for Dualit hand Mixer
at the service/distribution center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Sep 11, 2008 | Dualit 88400 Hand Mixer
Food Mixers Logo
63 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
