Question about Dryers
What does it mean when the display unit says ele
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 02, 2012
2004 ele parking brake not pulling up to m.o.t s type jaguar
i presume you mean the electronic parking brake does not meet the minimum effort for mot test, first check the rear calipers and pads, the caliper sliders seize and/or the pads seize in the caliper frame, check the discs also for bad corrosion, is the park brake warning showing on the dash? if so check the wiring above the rear subframe its prone to chaffing and grounding out, the park brake motors are also troublesome, sounds like a pad/ caliper problem more than likely seized sliders easy job to free off, hope this is helpfull to you.
May 28, 2015 | 2004 Jaguar S Type
DVR-7318V Factory Default Settings
Look at the unit, you will be looking for a small hole in the unit. You might get lucky and it will say reset. If not the hole will be about the size of a paperclip end, and that's also the tool you will need. Push the button in the hole and HOLD it for a slow count of 30 seconds. Release it and let the unit go through it's startup . This should reset it back to factory default.
Feb 22, 2014 | Computers & Internet
ELE
Do you mean LE? Because a LE code means Overload in Motor.
May 11, 2012 | LG DLE2512W Electric Dryer
Elextrolux code ELE
The model number you have submitted to us is incomplete or not correct for your unit. In order for us to provide you accurate information and supply you with the correct manufactures part numbers , we will need the complete model number, serial number and batch or series numbers (if applicable) found on a business card size metal/foil plate. If you are having difficulty locating this identification label, follow this link which will take you to our Website where we have pictures of common locations where your model number ID label can be found. Here is the link: http://www.affordableappliance.com/Tips/modelnumbers.htm Once you have the updated information, please reply to this email. Eric Campion
Apr 14, 2012 | Washing Machines
Have had a Nakamichi Sound Space 1 music stereo system for 10 years. Has served me well but the other day when I turned on the wall switch the power light did not come on. have tried...
you should always check the plug 2 all your thangs an change them if they are faulty. try 2 plug it in someware eles. or the unit is done. somethang could be burnt out. dnt leave it plug in.and dnt plug it in 2 a multi plug. go staight 2 the wall to check any power problems.
May 10, 2011 | Nakamichi SOUNDSPACE 1 CD Player
Display yellow with a round spot in the center of screen i think it might be the lamp any info on how to find if it might be something eles
Hello: This unit does not have a lamp. It is a CRT read projection version television, Your symptom indicates to me that the RED CRT is defective. Replacing it would restore the television back to normal.
Nov 19, 2009 | Sony Grand WEGA KDP-65XBR2 65" Rear...
Zanussi zwf1430s error codes - E40 / E41 & ELE
hi
ele means the pcb is in factory settings . all you need to do is turn back off the on again then will be back to normal use. but e41 usally means the door lock has failed. does it click alot when you start it up and not do anything? if so this will be the lock
regards
Mar 19, 2009 | Zanussi ZWF1430W Front Load Washer
NO DATA. sony NWWM MEM AAD2 driver
FORMAT UR PLAYER (NOT FROM EXPLORER) FROM THE MP3 PLAYER SETTINGS..THEN TRANSFER SONGS
Jan 10, 2009 | Sony NW-E107 MP3 Player
Problem with this unit
The washer has a field service mode. To enter the service mode: 1. Press the POWER key to turn the washer on. Make sure the HOME screen is displayed. 2. Press HELP. 3. Press and hold MY CYCLES and BACK simultaneously for 3 seconds. The display should display any recorded errors. write them down, including all MORE screens. This should be enough to get you started. Note: You must press EXIT and unplug the washer to clear all error messages and to activate the setup mode program. After repairs are made, you have to run a setup / self diagnostic check to get washer operating again. (prompts on screen when plugged back in and turned on) We can't ask for or give out email's, however if it slipped in an ask me maybe some scanned pages from a service manual might be had. This is most likely an involved exchange. Don't know how much info (ie: free time and advice) I'll be able to allow.
Oct 06, 2008 | GE WPGT9360EPL Top Load Washer
Dryers Logo
32 people viewed this question
Top Dryers Experts
