Question about Broan-NuTone Dryers
Can i test run the fan motor by bypassing the capacitor
  • Broan-NuTone Master
  • 5,245 Answers
Maybe: If you can manually rotate the motor to get it started.
The capacitor is on start winding, and causes sudden release of amps that starts the motor.
There are two (or four) windings in each single phase motor.
Both receive power at same time.
One winding is the start winding, which can be considered 'low gear' on a transmission. The capacitor is on this winding and gives burst of enough power to begin rotation.
So when a motor just hums, and doesn't rotate, then the start winding and/or capacitor are suspect. Dry or worn bearings are suspect too.
The other winding is the run winding that brings motor to up to speed.
On fan motor, the run winding can have multiple connection points for selecting different speeds.
Illustration.
http://waterheatertimer.org/images/Motor-wiring-500.jpg
Posted on Nov 02, 2012
3 Suggested Answers
SOURCE: fan stopped running. no power to the fan (ie, no
i have the same problem 5742993386 let me know if you find something and i will do same
Posted on Jul 26, 2010
hondo73162
  • 132 Answers
SOURCE: Fan does not work motor will buzz thats all. Nutone ultra quiet t
it may be that the bearings nead to be oiled, have you tried to spin it by pushing it with a pencil and see if it sticks or spins freely ?
Posted on Nov 07, 2009
Freezer chest not cooling but Compressor is running
Unless you have a microfarad capacitor meter, you won't be able to check the capacitor. Make sure the evaporator fan motor is running. You may be low on refrigerant.
Feb 22, 2015 | Refrigerators
Hunter fan remote bypass
This fan uses a "ballast" to run the fan. The ballast (part #272) probably contains wiring for multiple speeds. Here is a manual that discusses the wiring- http://www.hunterfan.com/SupportDocuments/OwnersManuals/42700.pdf.
To use a wall mounted fan dimmer, you need to identify the high speed wires and connect them to the dimmer switch. This method will bypass the other speed windings and is not as power efficient.
Jan 31, 2014 | Hunter 21617 Palermo Brushed Nickel...
Replaced condenser fan motor with OEM and I replaced the dual run capacitor with exact same rating and the condenser fan motor still will not run, I wired the way it came off (3wires brown to f on...
One way to test the motor and the board is to bypass the board. You need to direct wire the motor and test to see if it comes on. Then you know the motor is good and the board is bad. Not sure exactly what board your talking about though. Condensers don't have defrost timers on them. Can u post your model no. and any pictures of the unit would help also.
Aug 04, 2013 | Heating & Cooling
Condenssor fan moter not working
The condensor fan is usually a capacitor start capacitor run motor.To test i switch the unit on as normal then carefully flick the fan around in the direction of rotation (you may have to take the grill off) to do this,do not use your hand! If the motor starts to run it will be a faulty capacitor, do not leave it running for long as it will not run at full speed and will trip on thermal O/L or burn out.This is a common fault on AC split phase motors that use a capacitor for either starting or start and run.
Feb 03, 2013 | LG LS-L1210CL Mini Split Air Conditioner
Do you bypass the run capacitator on a lakewood model hv-18 fan with a 2.4 motor
More than likely it's not the start capacitor why your fan will not run this more than likely it's not the start capacitor why your fan will not run this lubrication try turning the fan motor by hand if it does not turn freely it's lubrication I have answered this another post.
more than likely it is lubrication spray WD-40 into the oil holes after you have unplugged the fan of course Keep turning the fan and you'll notice will start turning more freely apply more oil to the rear of the motor as this is an oil bushing you're putting more oil into
hope this solves your problem
May 03, 2012 | Lakewood HV 18-c Floor / Box Fan
Uaka 024JAZ condensing unit comes on, fan and compressor start up, fan remains on, compressor shuts off in appx 1 min , pressures appear to be headed to normal op range. I did not see a run cap for this...
This unit uses a dual run capacitor. There is no start capacitor involved.
The dual run capacitor is possible weak, also check all the electrical connections for tight fitting connections with can cause motor/compressor overheating.
To test a capacitor properly you need the proper test meter capable of reading uf readings(within 6% of the stated rating on the capacitor) "C" common to "F" fan and "C" to "Herm" terminal, the higher rating for compressor and the lower for the outdoor fan. [(example= 25/3uf 370v) 25uf=compressor, 3uf=fan motor.]
Oct 01, 2011 | Ruud UBHC Air Conditioner
I have a wall mounted accutek oval fan.been running for 5 yrs.now it wont start.i bypassed the reostat and the motor works at h speed but tuns in the wrong direction.i live in witbank in south africa and...
The motor may have a capacitor that has failed. Start Capacitors and/or motor winding "shades" are used to determine the direction of rotation, if the capacitor is checked and is defective replace it, if the capacitor is tested and is functional the fan motor may need to be replaced. it is helpful to include the model and serial number of the unit to ensure the wiring diagram is correct for your fan.
Nov 01, 2017 | Heating & Cooling
Fan starts slow or not at all.
This is usually an indication that either the motor capacitor is bad or the start centrifugal switch in the motor is bad or, possibly both. Spinning the motor bypasses the starting process. Capacitor are fairly inexpensive, I'd do that first. If start switch is bad, motor has to be replaced. Not a cheap motor either.
Jan 19, 2010 | Garland Convection Oven - MCO-NAT Gas
I have a Trane XE1200 condensor for which I bought a replacement fan motor, same specs as the original G.E. motor. The original G.E. motor was wired to a dual capacitor, which is also wired to the...
OK, locate the terminals on the capacitor marked "HERM"(Compressor lead), "FAN", and "COM".(common)
HERM and COM remian as they are.
The wire going to "FAN" (usually brown) will be placed on either terminal of the new capacitor. (This is the ((usually brown)) wire comming off of the fan motor.) An additional wire needs to be run from the other terminal of the new capacitor to the "COM" on the old capacior.
What you are doing is bypassing the fan side of the old capacitor but still using the compressor side of the old Cap.
The fan should have a wiring diagram on it to help identify the wires if there is no brown wire. The other two wires will be identified on the wiring diagram as well, but one typically goes to the contactor and the other to the board.
Sep 07, 2009 | Heating & Cooling
RV A/C fan won't start on its own
This could be the problem. It is more likely that the motor bearing is bad. Take the fan capacitor and have it tested. Or replace it, (under $20). Was the fan motor loud before this happened? Hopefully it is just the capacitor, the motor runs $60 - $100 and is a FUN to replace.
Jul 02, 2008 | Coleman Mach 15 Air Conditioner
Dryers Logo
2,183 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
maddyveggie
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
