Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
Toshiba 42wh36p problem
I have a problem with my rear projection tv, when you first switch it on its fine then after about 20 minutes lines appear across the top of the screen which get worse until the picture breaks into red and blue and goes curved. I turn the tv off and on and it does it again after a few minutes. It gets worse the longer ther tv is on.
    Genius:
  • 1,074 Answers
You tv problem intermittent the problem is in the color circuit, vertical circuit.have a tech check your tv for repairs.good luck.
Posted on May 18, 2007
Toshiba 42" projection tv model number 42WH36P rippled effect on picture
Well this could be a serious issue you may have to call to a tech guy
good luck
Dec 18, 2009 | Toshiba 42H83 42" Rear Projection...
After about 15 to 20 minutes lines start appearing on the screen
Check for cold solder joints around and including the Convergence IC's.
Nov 16, 2009 | Toshiba 57H81 57" Rear Projection...
I have Toshiba 51H84 rear projection HDTV. There
Open the tv up,but don't touch the lamp use a fan open it high setting blow out everythings should clean it.If not lamp might have scatch some how?
Oct 12, 2009 | Toshiba 51H84 51" Rear Projection...
Power went low all things went dim since then are tv's are all red picture and sound fine but all red
You need to first: Unplug TV and let it sit 20 minutes.
Then replug it... Then you may have to set the red, blue and green guns if this is a projection TV>
Mastersage!
Jan 03, 2009 | Toshiba 43H70 43" Rear Projection...
Screens broke
You can go to www.tritronics.com and use your model number to see if they are still available . They are somewhat easy to install by removing the speaker grille on the bottom thus exposing the screws hold the frame that secures your screens . Sometimes the screws are on the back side holding the screen . Send a picture of your tv if you think you might want to try it yourself . The screens can be expensive . Also try to call around to see if a repair shop might have some used ones that will work with your tv that are in good condition . Could save big bucks . Good luck
Feb 29, 2008 | Toshiba 42H83 42" Rear Projection...
Toshiba 42WH36P rear projection TV has wavy lines
the problem is going to be a bad NEXT HYPER UNIT module. this is the digital scan card in the tv. try using the componenet inputs and if the tv works ok then you know that the HYPER UNIT is the problem. the reapir process for a "do-it-yourselfer" is too involved and would recommend a serivce center for this repair.
Dec 29, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 42wh36p
Please define line tearing or line hold drift==Do you mean horiz. or vertically?? Is the problem the same on all sources?? Any change hot to cold?? more diagnostic observation needed.
Aug 05, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba model 57H81
If you have zagged lines there are 10 small surface mounted capacitors you will need to change on the HYper Board. This is not an easy repair so alot of folks simply replace the hyper board. You will need a service manual to take this set apart and to get the proper part number. If you have no TV repair experience or do not know how to solder, as the hyper board has sheild arounfd it, you should play it safe and call out a pro to assist you in this repair. Good Luck
Mar 19, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
161 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
