Question about Dryers
It now takes 2 hours to dry towels
My dryer is 10-12 years old. It takes forever to dry anything, at least 3-4 times longer than it should. I just dried towels for 2 hours. I am going to check the outside vent tomorrow, but if that isn't clogged I'm not sure if I should pay to have it fixed, due to it's age. When do you just bite the bullet and buy a new one?
    Sergeant:
  • 311 Answers
Lets hit the eazy button first.dry a load with out the venting[wont hurt a thing]if ok its the house venting,if not dryer .GE is only brand that has two elements.so if not ge and heating element ok and its blockage in the dryer.hope that helps God bless ,tom
Posted on Jan 04, 2009
  • Thomas Malailua
    Thomas Malailua Jan 06, 2009
    if i have been helpful please remember to help me with ratings
It takes my dryer an average of 4-6 hours to dry a load of towels. A regular load of clothes is about 2-3 hours. What can I do?
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Oct 19, 2010 | Fisher and Paykel DGGX1 Electric Dryer
It takes forever to dry a load of clothes. Drum
Have you checked your vent for blockage? Over time, lint build-up in the vent and in the back of the dryer makes your drying time longer and longer. Unplug the dryer, pull it out and disconnect the vent. Using a flashlight and a vacuum, clean out the back of the dryer that connects to the vent and the vent itself. If you have a long vent line, you'll need to find a away to clean it out to clear any blockage. I use a hand-held plumbers snake that rolls up and pulls out as much length as needed. Then spin it around in the vent to knock off lint attached inside the vent tube walls. It may be easier to do this from the outside, but you can do it from the inside too. Check your outside vent cap for blockage and make sure the vent flap outside is not stuck closed. Also make sure when you push the dryer back into place, that you don't squish the vent tube, if it is made of plastic or foil. After reconnecting the vent, turn on the dryer. The air flow may blow out the lint you have dislodged with the snake. Clean out as necessary at the outside vent. I have a long vent line on my dryer, so I have do this annually. This has helped shorten my dry time every time I do it. Of course, cleaning out the filter regularly, does help too. The more often you clean the filter, the less lint that will build up in the vent . Hope this helps. Douglas
Jul 17, 2010 | Maytag MED5600TQ Electric Dryer
My dryer seems to be hot, however it takes forever to dry a load. Is 3 -4 hours normal to dry towels?
Your heater coil has burned into 2 parts. Find a friend WHO IS KNOWLEGABLE about dryers, Call a repair man or find a good used dryer. I understand this isn't what you wanted to hear, but this involves lint and 220 voltage. NOT to be taken lightly. The coil will cost around $50 and the repair men will be a minium of $75; Look in the paper and buy another one....
Aug 25, 2009 | Dryers
Takes 3 hours to dry a small load, dryer is 3 1/2 yrs old
You need to clean vent hose and vent line in wall of house.
May 08, 2009 | Dryers
Hello: I have a Maytag, do not know model # as I inherited the 5 year old model when I purchased a condo and it is now 7 years old. The front of it states Maytag - Dependable Use, Heavy Dtuty - Large...
I ALWAYS START WITH VENTING WHEN CALLED WITH LONG DRYING TIMES BUT I HAVE SEEN WHERE ONLY HALF OF THE HEATING ELEMENT IS WORKING, WHICH IS PRETTY RARE. A NORMAL LOAD WOULD BE WHATEVER THE WASHER HAD IN IT WHICH WOULD BE LOOSLY FILLED TO THE TOP ROW OF HOLES IN THE WASHER TUB. THE ONLY OTHER QUESTION I WOULD ASK IS IF THE WASHER SEEMS TO BE SPINNING OUT PROPERLY AND IF THE CLOTHES ARE GOING INTO THE DRYER TOO WET.
Jan 10, 2009 | Maytag LSE7806A Top Load Stacked...
NOT GETTING HOT ENOUGH TO DRY TOWELS IN AN HOUR
It takes the dryer forever to dry a load of clothing, no matter how many pieces or thickness. Yes, I have already checked the vents out of the dryer, there not clogged. Any other suggestions?
Jul 09, 2008 | Whirlpool GEW9200L Electric Dryer
Dryers Logo
246 people viewed this question
Top Dryers Experts
