Question about Keurig B70 Platinum Brewing System
Keurig high pressure valve - Keurig B70 Platinum Brewing System
  • 1,511 Answers
See the manual for resetting paramaters.
Posted on Jan 31, 2014
Keurig B40 prime problem?
That whole system is run with air pressure. You need to check all the valves for deposits and proper operation.
Aug 10, 2014 | Keurig Elite B40 Coffee Maker
Does not shut off and the safety valve went off
Your problem dependents on when the safety valve is opening. If the safety valve is opening before the tank reaches its rated high pressure level, usually 130 to 150 psi, the spring in the valve is weak or broken; replace the safety valve. If the tank pressure is going over the rated high pressure level, the pressure switch isn't turning the motor off when it should; replace the pressure swtich.
Nov 25, 2012 | Stanley Air Tools & Compressors
Where can i buy a solenoid valve for a keurig b70
Search ebay for Keurig b70 solenoid and you'll find your part!
Oct 24, 2012 | Keurig B50 Coffee Maker
Ac drainline 2002 toyota camry
Hi Andreas, The valves for evacuation and refilling the ac are the same. To drain the system an evacuation pump should be connected to the low pressure and high pressure valves. The valves are situated in the engine compartment, the high pressure has a red valve cover and the low pressure black. You will easily find the valves by looking along the air conditioning plumbing. Regards John
Sep 16, 2012 | 2002 Toyota Camry
Need a valve for a model B60. are both valves the same ?
Here is a tip that I wrote about how and where to get replacement parts foryour Keurig Coffee Brewer
Keurig CoffeeBrewer Replacement Parts
heatman101
Jun 19, 2011 | Keurig Special Edition B60 Coffee Maker
I have a 1995 jeep grand cherokee and i cant figure out the difference between the high and low side is the low side gonna be on a metal pipe near the fire wall or on the compresure its self cause that is...
during the 1995 R12 was still in uses if you have 134a then you have the conversion here are the valve rule of thumb if the A/C pipes are thick you have the low pressure line the filter drier is a low pressure area, here the high pressure the condensor the thin line is the high pressure, go to the filter drier follow the thick line and you will find a valve that low pressure, go to the condensor the thin line you may even find a sight glass that area is the high pressure you should find a valve this is the high pressure
Jun 04, 2011 | 1995 Jeep Grand Cherokee
A/C builds up too much pressure and pops off high pressure relief
have you added freon to system because it sounds like there is to much
Jul 25, 2009 | 1996 Dodge Stratus
I cannot get a full cup of coffee from my Keurig coffee maker.
I HAD A SIMULAR PROBLEM...AFTER DESCALING WITH VINIGAR I NOTICED THAT MY COFFEE CUP WASNT ALWAYS SERVED FULL....THEN AFTER A LITTLE DIGGING ON THIS SITE IT BECAME OBVIOUS....I HAD A PIECE OF SOMETHING STUCK IN THE ONE WAY VALVE...SO TO SOLVE THIS I DISCONECTED MY KEURIG,BROUGHT IT OUT TO MY SHED AND CAREFULLY BLEW OUT THE THE ENTIRE UNIT WITH MY AIR COMPRESSOR BEING CAREFUL NOT TO USE TO MUCH PRESSURE AND BLOWING OUT A SEAL.....BROUGHT IT BACK IN,FIRED IT UP,WORKS PERFECT AGAIN...EVEN THE DESCALE LIGHT NOW STAYS OFF.NO MORE PINCHING THE RUBBER RETURN VALVE IN THE RESIVIOR JUST TO BREW A CUP OF COFFEE. HOPE THIS HELPS SOMEONE........................
Jun 05, 2009 | Keurig B60 Coffee Maker
Keurig B70 Platinum Brewing System Logo
54 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
