Question about Technics Audio Players & Recorders
Hello i only have sound coming out of the right speaker when i play the right deck what do you think this could be. The left one plays sound from both
I believe it could possibly be a bad rca plug. try wiggling them while connected to mixer.
Posted on Sep 03, 2013
djproaudio
  • 515 Answers
SOURCE: sound problem
You might also have a bad tonearm connection - make sure your headshell is securely in place. Also take a look at the tonearm pins, this is the 4 pins inside the tonearm, where your headshell connects. If any of the pins are pushed in, then you have a faulty tonearm.
The most common issue with sound is the RCA cables, so I would suggest replacing those first before you go to the tonearm, as the tonearms are pretty expensive.
DJPROLAB
Posted on Feb 24, 2008
landsend
  • 1066 Answers
SOURCE: Technics SL-L3 turntable no sound until warm up
either the cartridge is bad in the phonograph tone arm.  Or the pre-amp in the stereo is bad...remember that the turntable is the only accessory that uses the pre-amp input on the stereo.  I'm betting the pre-amp is bad.
Posted on Mar 21, 2009
  • 691 Answers
SOURCE: one of my DJ turntables = only left side stereo sound
need to narrow it down, using 1 turn table ONLY with the mixer on channel 1 (the chanel that is working) to test reciever is working properly and sound working on both side of the speakers, this eliminate the first turn table. Next, disconnect the working turn table (1) and connect your second turn table to the same chanel and see if you getting the sound coming chanel 1 just as your first turn table did. If you getting sound coming out from turn table on ch1 than is not the turn table issue. It will be you mixer having problems. You cant solve the problems having everything connected. Testing one turn table at a time using working chanel on the mixer to see if both turn table working properly. If you use the same chanel testing both turn table and the second one does not work than it will be one of your turn table is faulty. Note: if you find and test both of your turn table is working properly than it will be your mixer. good luck and hope that help..
Posted on Aug 06, 2009
  • 32 Answers
SOURCE: Technics 1210's playing out of one speaker / channel
i got my turntables repaired by these guys www.technmics1210repair.co.uk
i did they made my setup work like new so im going to spread the word.
give them a shot
Posted on Apr 18, 2010
  • 32 Answers
i had my decks fixed by these guys they are in london.
thier websites is www.technics1210repair.co.uk
they do technics turntable servicing
check them out.
im only spreading the word due it i had my decks fixed their and i am so pleased im telling everyone so they can get the same service i did, rather than paying over the odds at some **** toster repair shop.
alan
Posted on Jun 10, 2010
DP29F turntable has static
either you haven't earthed the deck to the amp, on the proper ground screw, or your head shell wires are touching.
if the cartage(the thing the needle slots into) unscrews from the tone-arm, try unscrewing it,then putting back on, nice & tight....
if it still does it then it's your RCA leads that go from the deck to the amp(phono cables).
normally you would wire a deck/decks to a mixer first, then from the master out on the mixer to the AUX IN on the amp.
Oct 21, 2012 | Denon DP-29F Turntable
Why does my sony reel to reel tape deck make no sound when playing a tape?
Are you playing the tape "right-side up"? I used to screw that up a lot at my radio station.
Jun 01, 2012 | Sony Audio Players & Recorders
Sound only from left side speakers!
If you put the good channel from the deck into the right and then left phono imputs of your amp, the sound should come out from the left and right speakers. If it only comes out from the left, then the amp as a right hand channel fault. Now if other devices work on both channels, then it's the pre-amp for the phono socket that has a fault on it. You should be able to find this by following the wires from the phono socket. If you touch around that pre-amp you should get it to buzz on either channel (where it joins with the main pre-amp). Doing this with a screwdriver will pin-point where the faulty part is (working backwards). PS don't short anything by touching to bits of metal together with the screwdriver.
Magnetic cartridges need a small pre-amp before they can be past to the main pre-amp. That's why you can't hear anything with the deck plugged into another line socket.
If you get signal on both left and right speakers with the above test the deck is to blame.
Jan 11, 2010 | Sony PS-LX300USB Turntable
I just hook up an after market cd player up in my 2001 chrysler 300m and the radio play but the cd player want play, it turns on and everything just no sound. do anyone have any ideas of what i did wrong?
DOES THE RADIO PLAY? HERE ARE THE FACTORY WIRING COLORS FOR THE RADIO HARNESS, RECHECK YOUR WORK. IF U FIND NOTHING THEN IF THE RADIO PLAYS THE CD PLAYER IS DEFECTIVE, IT HAPPENS BELIEVE ME.
2001 Chrysler 300M Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis or Strap
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: Orange/Red
Car Stereo Cell Phone Mute Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Located under the rear deck in the trunk.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Nov 05, 2009 | 2000 Chrysler 300M
1995 Saab 900S Left speaker doesn't work when using tape player
sounds like the cassette adapter has a bad channel, or didn't fully seat into place. Try removing and re inserting, to play the other side of the adapter if the wires will allow it. Then auto reverse the cassette deck to allow a different portion of the cassette head to be used for the signal. Those cassette adapters are poor quality, and put alot of time on the mech.
Jul 12, 2008 | 1996 Saab 900
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
Both left and right speakers play audio for right speaker
I think you mean the left channel is out but when you use test tone, the sound comes from left and right channels through the right channel speaker. If this is case, the switching IC is malfuncting. Unit needs service
Mar 15, 2007 | Sony STR-DE545 Receiver
Logitech speakers will only play on 2 speakers not 5
Liamog, i bought the exact same speakers and sound card, and i had the exact same problem as you. I tried for days to fix it and it turns out that its only a setting you have to enable in your sound card settigns. If you go into your EAX console for your creative sound card you will find a thing that sams CMSS 3D, and all you have to do is select the button that says Enable CMSS 3d surround. I hope this will fix your problem. Alex.
Nov 11, 2006 | Logitech X-530 Computer Speakers
65 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
