Question about Hayward TriStar Energy Solution Variable Speed Pump Control with Pro Logic Interface
Hayward tristar variable speed pump control
The LCD on the control box "froze". I turned the breaker off and then back on. I now only see shaded boxes where the words were. The control box is no making noise as if it were operating, but it is not.
  • 93 Answers
SOURCE: my hayward pool pump started making a humming
check impeller by turning shaft with pliers sounds as if its stuck do this while of and try to restart
Posted on Jun 18, 2009
john224
  • 1378 Answers
SOURCE: my hayward pool pump was working fine until
It is likely a motor failure. You may be able to take it to a local electric motor repair shop but most of those motors are not economical to repair. You can replace the motor and pump seal for far less than the whole pump. If you would like a quote on the parts, try us at www.arrowpools.net
Use the contact button and include your current pump info in the message.
Posted on Jul 05, 2009
  • 990 Answers
SOURCE: my hayward northstar pump makes a loud noise when
If you have a crack in your basket you may have a clogged impeller. With the power off reach back into the pump through the pump pot with a long screwdriver and feel around. If it feels spongey it there you have a clog. Take the serew driver an use an oceleting motion in a counter clockwise direction this should loosen the clog then reach in with a long set of thin pliers and pull the clog out. This should fix your problem and once water is flowing your pump should quiet down.
Posted on Oct 03, 2009
  • 8404 Answers
SOURCE: I'm need assistance wiring my hayward 2 speed
You may have a faulty bearing ... causing the noise. The pump is actually water cooled. Do you have 2 inch line for your 2 HP pump? Small pipe makes the pump work harder. If your lines are smaller, you may want to consider a smaller pump.
the motors will run pretty warm.
Run your pump on high for best results.
If you are using a timer ... you will need a double pole switch to turn it off if it is setup for 220 VAC (which it should be, for most econimical operation)
Posted on May 25, 2010
mc1bean
  • 3053 Answers
SOURCE: my hayward 1hp super pump
Inside pump is a difram , it most likely is stuck, some times if you shut off pump, turn back on a few times it might release itself, but most likely needs to be replaced. Let me know, mike from fixya.com
Posted on Jun 08, 2011
My hayward pool pump not working,forget to close the air vent before pump started and is water allover the pump,what to do?
Water sprayed on the pump occasionally shouldn't hurt it but it might cause a ground fault circuit interupter (GFCI) to trip. If you turn on the pump and literally nothing happens then most likely the the GFCI has tripped. If it hums then this is a different issue. If you have a volt meter you can open the timer box and check whether power is available to the timer. If no power is available in the timer then it confirms that the pump is probably ok. Checking your circuit breaker panel for a tripped breaker or finding a tripped GFCI then either one can be reset and your pump will probably run without a problem.
I hope this helps.
Sep 16, 2011 | Hayward Tristar Pool Pump 1 Hp for In...
Just had my Hayward Tristar 2-spd pump/motor replaced a month ago. I've been running it on high speed for about 3 weeks because my control pad went out and I couldn't get it to run on low speed. ...
running the pump on high speed will not have caused the problem, they are meant to run 3,450 rpm's continually. It's more than likely a supply power problem like you mentioned. Check GFI's, and breakers to see if anything has tripped.
Jul 26, 2011 | Pool & Spa
My Hayward Tristar 1.50 HP pump is 3 years old, and recently developed a high-pitched humming noise that is causing a noise disturbance. The performance seems to be operating okay, but it never used to...
sounds like the bearings are going out on the motor. The noise will increase as they wear out more until it locks up and throws the breaker. You can have the motor rebuilt or just replace the motor. Consult a pool professional to help out with this.
Nov 22, 2010 | Hayward TRISTAR PUMP 1.0 HP, 115/230V
Have voltage to the Hayward Tristar pool pump but it won't run!
SOUNDS LIKE YOU HAVE A BAD BREAKER.. THIS IS A GRAVY FIX.. I SEE A VOLT METER IN YOUR FUTURE YES ITS ONE TO CHECK 230 V AC .. YOU LOCAL CAR PARTS STORE HAS THESE CHEAP .. ASK HOW TO USE IT AND YOUR OFF.. WHAT WE ARE LOOKING FOR IS 230 240v IN THAT RANGE ON THE 2 WIRES ON THE BACK OF THE MOTOR... OR EVEN THE TIMER.. NO?.....BREAKER NO? REPLACE BREAKER... BREAKER YES.. CHECK TIMER CONTACTS .. don't forget to prime your pump after a repair !!!!!!!!.. did i help ? well then please vote.. I got to get back to fix'n the pool pumps here in Florida ... Jay .. PPRG
Jul 08, 2010 | Hayward TRISTAR INGROUND POOL PUMP - 2 HP...
Hayward TriStar Energy Solution Variable Speed Pump Control with Pro Logic Interface Logo
51 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
