Question about D-Link DSL-504T Router
DSL-504T Router - not connecting?
Hi, i have a D link 504T router. I have recently changed internet providers, so i had to access the router admin, i did this by reseting the router. Now when i type in 10.1.1.1 i get the username/password page, but it does not accept admin/admin, or should i say it shows a blank I.E page with "done" at the bottom with an error symbol.
I have pinged the router and it works fine.
I have also updated firmware, but that made no difference either.
I have just about tried everything!
Suggestions would be much appreciated
  • D-Link Master
  • 4,338 Answers
Try using the D-Link Click'n Connect Utility.
Admin is the correct code for both the user name and password.
10.1.1.1 is the correct IP address for the setup page.
You may need to reset the router again by holding the reset button in for 30 seconds until the lights flash off then on.
Here is the setup manual:
ftp://files.dlink.com.au/products/DSL-504T-GenII/QuickInstallGuide/DSL-504T_GenII_QIG.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Jan 04, 2009
D-Link DSL-504T driver disc missing, looking for Win 7 compatable driver for modem.
No driver needed since you aren't connecting the pc the the modem, but to the router.
Connect the pc to the D-Link DSL-504T with a LAN cable, access it from a browser by going to this IP - 192.168.0.1 - , in there access the modem settings and configure it accordingly.
Jun 20, 2011 | D-Link SWT DSL-504T ADSL MODEM with 4...
I suspect other people may be using my internet. I have a DSL-504T D-Link router and a Belkin wireless router connected to that for our laptops, how do I protect our internet?
Go to the site
http://support.dlink.com/emulators/wbr2310/wireless.htm
and follow the steps for your router.
1.In Wireless Security mode select Enable WEP wireless security.
2. Authentication select as shared key.
3.Now set your WEP key values.
4.Save the setting.
Hope this will help you.
Thanks for using FixYa.
May 14, 2011 | D-Link DSL-504T Router (DSL504TX31FOC)
Dsl wont pass thru router wired or wireless I have reset the router several times, the computer shows connected ,signal strenght excellent, but will not connect to the internet wired or wireless as long as...
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Mar 28, 2010 | D-Link 802.11g Wireless Router WBR-1310...
I need to change the modulation type on my modem to select g.dmt to make my internet connection more stable HELPPPPP!! i have NO clue how to do it. it's an ADSL 2+router DSL 504T.i am computer...
To configure the modem You will need to use the cd provided.
ftp://files.dlink.com.au/products/DSL-504T-GenII/QuickInstallGuide/DSL-504T_C3_QIG_v2.00.pdf
Or to configure without the cd follow the steps below:
  1. Connect the Adsl router with your computer.
  2. Use the network cable provided with the router.
  3. Connect the power cable to the modem, it will light on firmly with a green button on.
  4. Open your web browser and type the ip address: http://10.1.1.1
  5. Default username and password is:
  6. User-name: admin
  7. Password: admin
  8. Use the quick setup wizard.
  9. It will be more easy for you to configure it.
  10. Be sure to have the username and password from the ISP for the internet access, you may need to reconfigure it from start. or if you may need to reset the modem
  11. At times to access your modem you will need to set the ip of your network card to the same range.
  12. To set the ip go in control panel then open network connection
  13. Doulbe click the local area connection.
  14. open Internet Protocol Open Tcp/ip
  15. then set your ip Like: 10.1.1.5
  16. ok
  17. ftp://files.dlink.com.au/Products/DSL-504T-GenII_NZ/Manuals/
I am enclosing a manual for you.
If you Need further help do not hesitate to revert back
Ok cheers
Uttam
Feb 13, 2010 | Computers & Internet
Need to configure for wirless setupnew dsl line from one isp to another need to set up router for wireless connection
If you are setting up a new router for DSL connection, i presume that you already know the login credentials to access your router's admin interface. By default, depending on your router's model, you can access and configure it at http://192.168.1.1 or http://192.168.0.1 using a web browser and make sure that computer you are using is connected to the router through an ethernet cable.
Default login credentials:
user name: admin
password: admin (or try also leaving it blank)
When you are at the web interface, go to a link known as SETUP and there you can setup your connection. If your DSL provides you a user name and password, then you can also enter them there. Then save your settings.
To allow internet broadcasting using wifi, go to a link known as "WIRELESS" and setup encryption there using WAP, WPA2, or WEP or any other recommended encryption protocol. Through this, you can prevent other users near your place to use your internet connection without informing you.
Feb 04, 2010 | Computers & Internet
I changed from DSL to Cable internet service. I
For that you need to access your router configuration.
Connect your router to computer with ethernet cable then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router .
Click on WAN settings and set network settings of your internet service provider.If you want ip address from your network then enable DHCP.
If you want wireless click on wireless and set security as WEP if you want to secure.
Dec 19, 2009 | Linksys Wireless-G WPS54G Print Server
One of the lights on router is blinking. Cannot
First Reattch all connection to router then check.
If still not working then you need RESET all settings of router to defaults.
For that press RESET button for 10 seconds it is in back side of router press it.
Then connect your router to computer then access it with these link
http://192.168.1.1
or
http://192.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
thenconfigure again.
Aug 07, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Remote manage a DSL 504T router
If you have a dynamic IP on your wan port you shall register a domain name and register it with dynamic DNS, provide your dynamic dns name in your DSL router so that you shall connect to your DSL router by calling the registered dynamic dns name from any where (you should have internet connection).
1. Register a name in dyndns.com
2. update this on your dsl router
Wait for some time,
3. access the registered name from anywhere using a browser
Jun 09, 2009 | D-Link DSL-504T/EU Router
D-link DGL-4500 is not accessing my dsl modem
make sure the dsl modem is in bridge mode. you do this by connecting directly to the modem then accessing modem configuration page. after doing this connect the way everything was before. now go to router admin page, then setup tab at the top, then choose internet, manual setup. in the place where its says my internet connection is select PPPoE. then put in your dsl username, password and etc. save settings. this should fix the problem
Apr 20, 2009 | D-Link DGL-4500 Wireless Router
No internet connection
This should be connected as so. From wall outlet to DSL modem, from DSL modem to D-Link router, From D-Link router to Laptop via wireless or wired connection. You will still need the DSL modem installed but the wire coming from the DSL modem will go to uplink port on the router instead of into the laptop.
Dec 21, 2008 | Computers & Internet
D-Link DSL-504T Router Logo
214 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
