Question about Toshiba Computers & Internet
Toshiba p750 recovery did not work
Updated a toshiba bios update and now my system will not boot up tried to do a recovery and still no luck.
  • Toshiba Master
  • 7,627 Answers
Can you do a system restore?
Posted on Nov 01, 2012
  • 5 more comments
  • Michael-Ann Kirby Nov 01, 2012
    max i was not able to do a system restore, it just comes back as loading windows and 3 color dots show up and then freezes up.
  • max carson
    max carson Nov 02, 2012
    Do you have a "Factory recovery disk"? You could contact toshiba and purchase a Factory recovery disk with you SN from your laptop. My Factory disk was $20.00. The toshiba support page http://eu.computers.toshiba-europe.com/i... Or you can you can search here for a win 7 64 bit recovery disk here and download , burn to a disk and if it will load you have options to repair. Push come to shove you may have to remove the HDD and reformat. that a drastic step. CAN YOU REMOVE THE BUTTON CMOS BATTERY AND THAT MAY HELP.
  • max carson
    http://www.google.com/webhp?source=searc...
  • max carson
    iF YOU UNPLUG, REMOVE BATTERY, HOLD DOWN ON/OFF BUTTON FOR 10 SECONDS, REPLACE BATTERY, PLUG IN AC AND BOOT WHILE TAPPING F-8 REPEATEDLY THAT MIGHT WORK.
  • max carson
    LOOK AT THIS INFO I THINK IT'S WHAT YOU NEEDhttp://www.pcworld.com/article/248995/ho...
  • max carson
    GO TO THE WEB ADDRESS ABOVE SCROLL DOWN TO STEP 2 AND DOWNLOAD THE YOUR VERSON OF WINDOWS 7, THE SPECS FOR YOUR COMPUTER SAY WINDOWS 7 HOME PREM. 64bit , is that right.
  • max carson
    :look at this procedurehttp://aps2.toshiba-tro.de/kb0/FAQ350065...
sivareddy040
  • 53 Answers
SOURCE: bios update
Hello!!
I am not sure after installing which update the display has gone. I mean Windows update or HP software update or BIOS update.
Let me take the senario of the BIOS update and assist you in this regard.
If the display has gone after installing the BIOS update, then the issue cases are 1. Installed wrong BIOS update 2. Notebooks might have restarted or hanged while installing the BIOS update.
In both the cases BIOS will get currupt and there will be no display on the notebook.
Solution for the issue is: If you notebook is under warranty, HP will arrange for mail-in repair, plss contact HP. If the notebook is out of warranty, then you need to contact HP authorized service center.
Posted on Aug 08, 2008
  • 97 Answers
SOURCE: bios update
You can try and change the boot device by pressing on F12 on POST. The computer will prompt you to select a boot device after pressing on F12 on power on.
Posted on Sep 21, 2008
SOURCE: toshiba L305D S5881 bios updates
problem solved
take out battery open the port were the ram is installed ......remove RAM
you need a small piece of wire and a piece of tape
you will see 2 mount points with B500 above them
simply place the small wire across the 2 points install 1 stick of RAM plug into wall leaving main battery out fire it up and it may restart 2 or 3 times or you will immediately be in
NO JOKE did this exact process last weekend and it worked
i figured this out from a very similar tutorial on toshiba
let me know if this helps .............CIRRUS
cirrus2028@yahoo.com
Posted on Sep 26, 2009
  • 251 Answers
SOURCE: Hp dv9008 Tried to update the bios but somehow failed,now it
get it repaired under the limited warranty scheme
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us
Posted on Nov 08, 2009
  • 14 Answers
SOURCE: Updated my BIOS on my
You'll need to Reset your BIOS password. To do this, go to another PC, and visit youtube to find a guide, or ring toshiba support and have them talk you through it.
Posted on Oct 03, 2010
Froze after update, now won't boot, just goes to logo screen and wheel spins and spins
Try going into BIOS on boot (press F1/F2/DEL or F10 depending on your laptop) and hunt for the 'reset BIOS to default' option. Do this, Save and Exit. Now start pressing the F8 button and see if you can boot to 'safe mode'. If you can, and you are running a version of Windows, you can go to programs/windows update section to try uninstalling the last update which probably caused the initial problem. If none of that works you may need a bootable system recovery disk which can be bought cheaply on eBay if you have not got one.. Good Luck
Aug 26, 2015 | Computers & Internet
Bios black screen
Did You Check to See If Memory is in correctly ?you might have dislodged them by accident please check this !! Can you get back into bios there must be a reason for the black screen like Memory is the computer beeping ? What you can do is use a friends laptop or computer and create a recovery disc on there computer then put that disc into your laptop or you can borrow there windows disc.
Boot Manager:
Windows failed to start. A recent hardware of software change might be the cause. To fix the problem:
1.Insert your Windows installation disc and restart the computer.
2.Choose your language settings, and then click "Next".
3.Click "Repair your computer."
If you do not have this disc, contact your system administrator or computer manufacturer for assistance.
Status: 0xc000000f
Info: The boot selection failed because a required device is inaccessible.
(more Info Please)
Sep 18, 2017 | Toshiba Satellite Computers & Internet
Dell 1018 laptop bios corrupted during install new A02 v. After unsuccessful update no display in system
Was there a problem that required a BIOS update? Did the update come from Windows or Dell? Have you tried a system restore/recovery? Can you get to anything at boot?
Dec 23, 2012 | Dell Inspiron 1018 Notebook
HP 4530s BOIS image cannot be read - update: Using Windows 7 Pro 64bit
BIOS is stored on a CMOS chip on main board. Used to instruct hardware during boot. It's not accessible in Windows.
A BIOS update may fix the problem. Here is the link. Just make sure to follow instructions and precautions! This is something you want to get right the 1st time.
Good Luck
Sep 26, 2012 | HP ProBook 4530s Notebook
Need to update bios toshiba satellite c660,using ubuntu live dvd, will not boot hard drive, all normal recovery options used up
Hi There,
There are currently no easy ways to update a bios through linux at all - including live cd's. Your best bet is to make a bios update USB stick (or floppy depending on the age of the computer)
Here's a link to those instructions:
http://www.biosflash.com/e/bios-boot-usb-stick.htm
Alternatively, speaking from my own experience with a similar situation, you can take the hard drive out, use it in place of the usb stick, boot from it, update your bios, and go from there.
Jun 06, 2012 | Toshiba satellite c660
Toshiba Satellite : X205-S9810 won't boot after i installed new hard drives/ used recovery discs. System just keeps running the green bars across the bottom.... installed two 250 gb in place of the 160's...
If you put the old hard drive back in your system and it works fine, log onto Toshiba's web site and download the updated drivers, firmware and BIOS. It is really easy to do.
Try this linkI hope it helps.
Oct 31, 2010 | Toshiba Computers & Internet
Bios Faile
bios is always risky update, and toshiba is very well known to stuff up they bios...
first advice, never, ever, update bios from inside of your operating system...
as your computer is already dead, try this method, i cannot recall if you have phoenix or amibios but should work on both:
1. remove power and battery from dead laptop
2. download again bios and unfold it, remember the folder, do not run it!
3. go to this folder and find file with suffix *.rom, rename it to amiboot.rom
4. copy amiboot.rom to usb drive
5. plug usb drive into usb port
6. press and hold fn+b, plug in power cord and press power button
7. if after few seconds you see screen flashing and toshiba logo then returns, you just saved your laptop and few dollars...
8. allow it to boot, switch off, re-insert the battery and use as before.
if this do not work, i am afraid tha tyou need to find some toshiba centre which will flash and re-program bios for your. do not get conned into replacing motherboard! there are non-toshiba repairers which charge between $30 and $100 to flash "dead" bios, toshiba for replacement motherboard want over $300.00
if you find my advice helpful, plese do not hesitate to leave comment and vote 4 fo rme, thanx!
Aug 01, 2010 | Toshiba Satellite P205D-S8804 Laptop
Toshiba Satellite A45-S130 boot failure
* If it's a BIOS problem, try this :
1. Shutdown ur system, and remove the BIOS battery.
2. Reinstall it and start again.
3. You can also replace the battery. (if above steps don't works!)
4. Try to get a updated version of BIOS driver. (if above steps don't works!)
* If u r also hearing any kind of beep sounds, it may be bad RAM (memory). Try this :
1. Shutdown ur system, and remove the RAM.
tell me if these steps don't work! :)
Dec 31, 2009 | Toshiba Satellite A45-S250 Notebook
Toshiba 4100XDVDwill not bootup. screen says insert disk to upgrade bios.will allow me to get to the setup menu
You will need to go to Toshibas support site and find the proper BIOS download for this computer. In the options for the download, you are going to have to download it so it can be burned to bootable media...like a bootable cd rom. That way when you boot the laptop up, it will boot off the disc, and upgrade your BIOS....if it goes wrong you will be shopping for a new motherboard or a BIOS chip reprogram.
Sep 03, 2009 | Computers & Internet
My bios is corrupted and iam not able to boot from it
I would only guess to reset CMOS and try updating BIOS from DOS. Altho, i couldn't remember for the life of it the process to update BIOS from DOS....sorry.
-Mike.
Jan 12, 2009 | Intel D845GVSR Motherboard
Computers & Internet Logo
88 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
