Question about Delta Saws
Delta shows part #40-650 drive collar is obsolete - Any obsolete parts source
I need the plastic collar which connects the C-arm to the motor connecting rod. Probably can improvise something, but would prefer to replace the original part. Is there a "Rare & Obsolete" parts source that I could try?
    Sergeant:
  • 468 Answers
What happened to your drive collar? Anyways, try to inquire with www.bandsawparts.com . They have aftermarket parts of delta band saw parts. Hope this can help you .
Posted on Nov 07, 2012
2 Suggested Answers
  • 4088 Answers
SOURCE: i need the support-lower guide for model
If you still have the old part(s), take it to a machine shop who can repair or re-manufacture the item. Good luck!
Posted on Jun 25, 2010
How To Convert Y Connection 3 Phase Motor Which Burnt Into A Delta Connection?
Delta is entirely different connection.... look here:
https://www.google.co.uk/search?q=3+Phase+Motor&es_sm=122&tbm=isch&tbo=u&source=univ&sa=X&ei=TWKZU9jpJobSOe3lgdAD&ved=0CEMQsAQ&biw=1534&bih=846
Jun 12, 2014 | Baldor RM3120 HVAC Fan and Blower Motor,...
Delta 31-250 saander dc drive motor doesn't work
You have probably tripped the breaker for the drive motor. If you have the manual, it shows you the location of the reset button on pg. 20. The reset is a small white button above the drive switch. You can download the manual from this link: http://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=10&ved=0CG8QFjAJ&url=http%3A%2F%2Fwww.redmond-machinery.com%2FManuals%2FDelta%2FDelta%252031-250%2520-%2520OM.pdf&ei=VfcfUba3FYeXyAHGrYFI&usg=AFQjCNGcOLvprmIo_af4ofEd10DBnJ7ocQ&bvm=bv.42553238,d.aWc
Dec 10, 2012 | Delta 31 - 255X X5 18'' x 36'' Drum Sander
Dean sings his arms and body move but his mouth does not i saw that someone replace d the string is there a diagram to show the workings of the doll
slide tux collar down and find 4 staples in neck, with small flat screwdriver work stales from neck, they are quite long and it takes some time. then with thumb under mouth at chin, gently wiggle and pull owtwards until mouth slides from head, mouth must be removed before head will lift from neck. once head removed, you will see drive motor near top that drives mouth. there should be a smoll nylon string connected to small plastic wheel on end of this motor, most times the adheasive that hold this string in place has let loose and string is still in tact. before reconnecting press activation button and be sure motor is spinning, if so simply reconnect string to plastic end, and reassemble head I used 2 part epoxy (JB Quick) Note if motor is not turning when activated then this too needs repaired
DW Mylin.
Sep 28, 2012 | Gemmy Bing Crosby Big Head Doll
Delta 467sssd hard to turn
there may be under the handle is a crown nut + a plastic collar which holds down the inards there is a tool that works this. it can be gotten at hardware store.. handle usely comes off w/ 1/8 allen wrench...
Mar 31, 2011 | Delta Faucet Delta 467-SSSD-DST Palo...
Who to wirie star delta starter
This site gives an excellent explanation of the star connection and the delta connection.
Answers.com - How do you wire a star delta motor
Then this site shows the wiring of the motor windings and the star delta starter and what occurs when the starter switches from star to delta.
Moeller - Star-delta switching of three-phase motors - Automatic star-delta starters SDAINL
Good luck.
Dec 20, 2010 | Air Tools & Compressors
I am trying to run the delta 10 radial arm saw on 110 but it is running very slowly. Is there some switch or anything to change over from running it on 220 to 110
if this tool is 220 and you are running on 110 that is your problem. Some motors can be rewired to run on the proper current. UNPLUG tool and remove small cover from motor and usually they will have a diagram to show you how to change over. running this on the 110 will burn up the motor.
Aug 25, 2010 | Delta Machinery 10" Professional Radial...
Shifter under hood pops of the little ball wat is
the ball is not bad, the arm needs replacing the socket's on the arm, it's loose
No repair, just replace it (Fairly cheap, dealership part only)
When you put the new arm on fill the new plastic ssocket (Both ends) with silicone grease (White or clear) do NOT use petroleum grease
Aug 31, 2009 | 1986 Oldsmobile Delta 88
Water pooling at base of delta waterfall faucet spout
I have the same problem. The part that is needed is found with a simple Google search for "Delta Waterfall RP22934 O-Rings"
Simply Slide the collar up at the base of the spout where it swivels.
Gently open the now exposed split plastic retainer so that the tabs near the bottom are pulled from their holes.
Lift the spout off the base to expose the o-rings.
Replace with the new o-rings and apply o-ring grease.
Re-assemble and enjoy a dry sink area.
Nov 25, 2008 | Delta Faucet Delta 172-SSWF Waterfall...
Windshield Wipers
Under the cowl (it is a plastic piece that the windshield wipers come out of) are the wiper arms that connect to the wiper motor. There are plastic parts that hold the wiper arms to the wiper motor. Lots of time these plastic parts dry out and break and the wiper arm will fall off the wiper motor. I would bet if you tried to move one of the wipers by hand both of them would move with little resistance. This would tell me that the wiper arms are disconnected from the wiper motor. The parts to fix this are easy to get. I know the motormite HELP line of parts used to have the plastic bushings to fix this problem.
Jul 22, 2008 | 1994 Plymouth Voyager
Saws Logo
85 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
John Trevino
Are you a Delta Saw Expert? Answer questions, earn points and help others
