Question about Bosch HBL8650UC Electric Double Oven
I have a new wall oven arriving tomorrow. The old one's wiring was simply wire-nutted to three leads sticking out of a duplex box in the wall behind it. The new oven says the junction box needs to be above the unit (i.e., behind the upper cabinet?). My question is whether the connection can be made in a junction box attached on the end of my current wiring and then pushed up into the wall cavity beind the upper cabinet, or does the box have to be somehow attached up behind the upper cabinet. I have to have this ready for when the oven arrives tomorrow. I also need to know what size opening I need to punch out in advance for the armored cable from the oven if I need to hard-mount it behind the upper cabinet and then connect in the back of that cabinet. Any help appreciated.
SOURCE: bosch hba34b520
Yes, it is o/k to have a single oven connected to a 13 amp power supply supplied with a 2.5mm cable.
A lot of single ovens already come with a 13 amp plug fitted, so you can plug it straight into a 13 amp socket.
If there is no covenient socket nearby, then you can wire the 2.5mm cable srtaight into the oven terminal block.
I must stress that this only applys to a single oven and not a double one.
Plz rate my solution.
Thanks.
Posted on Jan 14, 2009
SOURCE: Our Bosch electric oven is 5 years old. We
Either you have not refitted the door back correctly, or the door hinge springs are weak, a common problem.
This being the case, then the only solution is to replace door hinges.
Posted on Feb 11, 2010
SOURCE: My HBL452 double oven is slow to heat both upper
If your electric oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Jul 30, 2010
Oct 08, 2017 | Ovens
on Jun 18, 2008 | GE JGRS14 Gas Single Oven
Dec 27, 2015 | Bosch Ovens
Oct 10, 2017 | Ovens
Aug 14, 2017 | Ovens
Jul 14, 2009 | Bosch Appliances 27 in. Wall Oven Electric...
Feb 28, 2009 | GE 24" Built-In Single Gas Wall Oven
Dec 12, 2008 | GE Monogram® ZET3038 Dual Single Oven
Nov 29, 2008 | Ovens
Jan 27, 2008 | Ovens
May 10, 2016 | Bosch HBL8650UC Electric Double Oven
Apr 15, 2012 | Bosch HBL8650UC Electric Double Oven
66 people viewed this question
