Question about Whirlpool GSC9455 Top Load Washer
Maytag washer will not rinse on the white cycle. is it the timer?
The washer works fine except for the white cycle. The washer will not rinse on the white cycle. could it be the timer?
    Sergeant:
  • 311 Answers
You must know that because it sets there and dose nothing???if so it has to do with water[its calling for it and its not coming so it keeps waiting,cant move on till sattifies the water level switch].set timer at start of load and check water setting temps .dose cold come out when set cold only also same hot.ihope thats a bit of help.God bless ,tom
Posted on Jan 04, 2009
  • Thomas Malailua
    Thomas Malailua Jan 06, 2009
    if i was helpful please remember me with the ratings,thanks
WHy won't my washer finish its cycle?
check lid switch first, this is most common.(machine thinks lid is open), carefully lift and lower lid an you should here a faint click. otherwise i hit some timer issues but not so common. there is no reset, the model you gave comes back as electro-mechanical and not electronic
May 10, 2014 | Maytag MAT12PD Top Load Washer
Washer stops before rinse cycle
Check the water level sensor.
Nov 25, 2013 | Maytag Washing Machines
My maytag top load washer model #sav2555aww spins but not fast... I replaced the belt and that helped but still not like it did before.. Everything else works fine, any suggestions?
some of these machines have a timer conflict between rinse [ spin pulse ] and full spin at end of wash cycle the timer contacts remain in the pulse cycle the switching assembley may need replacing
Mar 05, 2011 | Maytag SAV2555A Top Load Washer
My maytag mav6200aww washer stops at the rinse or the spin cycle. However, if I wait about 30 min it will work. Possibly a bad timer? Are they difficult to replace?
If the washer is working properly in the wash cycle & not the rinse or spin cycle, I would suspect a defective timer especially with the delay of 30 mins you described. Replace the timer with this part.
Jan 14, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Maytag SAV5910aww will not always drain. Fills and agitates fine but will go through entire cycle without draining. Will sometimes give end of cycle buzz sometimes not. If I am in the room and lift the lid...
"I have found spinning the timer back to begining of rinse cycle first helps". The timer only rotates clockwise; counterclockwise rotation can destroy it.
May 18, 2017 | Maytag SAV5910 Top Load Washer
Washer stops at rinse cycle
Hi There,
Sounds like you need a new timer. Hope this helps and thank you for using FixYa!
Mar 30, 2009 | Maytag Washing Machines
Maytag mav6200aww washing machine doesn't rinse clothes
If you say this only happens on the Colors and Whites cycle i dont see what the lid switch or balance sensor (if your washer has one) would have to do with it. It does seem like it has something to do with the timer,,, it really sounds like maybe the (Colors & Whites) section of the timer is malfunctioning. Inside the timer, there are a series of gears and switches, and by slamming the lid, or tapping on the timer control knob,,, it could maybe help the damaged part of the gear move, temporarily "fixing" the problem
Mar 13, 2009 | Maytag MAV6200 Top Load Washer
Mav7200-57-58
The timer itself is bad, replace and wala! Timer Part Number: PT756240 Made by MAYTAG http://www.partstap.com/partsearch/model.aspx?model_id=47859 $70.22 + S&H
Sep 16, 2007 | Maytag MAV7600 Top Load Washer
Whirlpool GSC9455 Top Load Washer Logo
66 people viewed this question
Dan Webster
Dan Webster
Sal De
