Question about Sony Playstation 3 (PS3) Console
My PS3 is not accepting discs when you try to put one in it wont go and it makes a god awful clicking noice whats wrong with it
Is there a disc already in the drive?
Posted on Jan 04, 2009
My ps3 wont accept any disc. try putting it in but it stays there. Also when i try to put it in the blue light comes on but the game is not in the system, and when i push the blue button afterwards, it...
Hi Sef,
If you are getting the YLOD or yellow light I will run through what causes it and how you can fix it.
Causes:
The yellow light is caused by internal overheating and the main chips that take the damage are the GPU and the CPU.
You need to stop the heat build up and you will be able to get back to gaming again.
Solution:
You can either send the console back in for repair and they will fix it for you, however it will take about 4 weeks to get this done and it will cost about $150 for the repair!
Quicker Solution:
For a faster way to fix it you can use a good YLOD Repair guide that will show you with videos how to stop the heat build up and get back to gaming.
The important thing is to make sure that you get a guide that is up to the job!
I have put together a list of the best PS3 Repair guides and a complete review below:
Click Here To See The Best PS3 Repair Guides
Hope this helps.
Other Problems That You Can Fix Today Are:
PS3 Freezing Up
PS3 Will Not Read Games
PS3 No Display
PS3 Error Codes
PS3 Red Light
PS3 YLOD
PS3 Red Screen
Check out the full site and get a 1 hour solution...
Sep 12, 2011 | Sony Playstation 3 (PS3) Console
My ps3 slim blue ray drive will not accept discs. it wasnt reading them so i took the drive out and tried cleaning it but forgot my game was still in it so i removed it manually. when i put it all back...
OK, all the answers I see here don't look like they was reading your problem and what you did. You most likely should take it back apart and put the disc back in it that way. Since you took the disc out the PS3 thinks there isn't and is a disc inside. When you press the eject button it's not going to reset the disc arms inside because there isn't a disc in there and that white thing is there to keep a disc from going in with a disc inside even though there isn't one. You should go ahead and order another laser and when you take it back apart change the laser also slim PS3 are more common on the laser going bad I've changed alot of them. But when you change that make sure you either put a disc back in or move the arms and slides to where it's ready to accept a disc when it's put back together.
Nov 01, 2017 | Sony PlayStation 3 Slim Black Console
PS3 will not accept discs
sounds like a product fault, is it still within warranty? id have that sent off and checked
or are there some kind of settings, one of the settings may be interfering with it accepting discs
what discs are you trying to use? if you are using genuine PS3 dics and even DVD movies wont be accepted then there must be a fault in the system somewhere
also, how long have you had it? less than a year and theres definitely a problem
i'll be honest, i aint a Playstation Guru, but this is what im thinking it may be, i may be wrong, if i am then dont hesitate to pull me up i am willing to learn ;)
Jan 16, 2010 | Sony Playstation 3 (PS3) Console
My ps3 wont accept a disc. if i try it makes a loud clicking noise
If your ps3 is not reading your discs this is most likely because of the lens moving slightly off key, you can fix it yourself or you can send it in. The good news is that it is quite an easy fix.
Dec 31, 2009 | Sony PlayStation® 3 (80GB) Console
Disc drive wont work
PS3 is The amazing device by sony but it has some common problems like Disc error, unreadable disc etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Jan 11, 2009 | Sony Playstation 3 (PS3) Console
Wont accept disc
Try this....after a lot of frustration and research, what i found on the internet for this problem was usless. I tried holding down the eject button for 15 seconds to reset the disc drive, still it would'nt accept the disc. As i literally picked up the phone to ring sony, as the ps3 was on standby i pressed the eject button multiple times and heard 2 beeps each time, still the system stayed on standby. After that i then tried just putting the disc in as normal as its on standby and the system booted automatically and accepted my disc. I hope this helps others, as mine now works perfectly.
(PSN ID is Burnsy333)
Jan 04, 2009 | Sony Playstation 3 (PS3) Console
My ps3 is not accepting discs
sounds like the claws that pull it in may have a striped gear call sony at 1800-345-7669
PS3 wont play blue ray disk
press and hold down the power button on the ps3
Jan 01, 2008 | Sony Playstation 3 (PS3) Console
Draive wont take discs
Hi Spooks,
When you put the Disc drive back together, the mechanism probably did not go togther properly. You have to put it together with a disc in the drive. It is very hard to get the disc player to go back together properly I know. I needed three hands to do it. I done one. It took me several tries, but I finally got it. Another thing, since you have already disassembled your PS3 and need to do it again, go to Radio shack and get some Thermal heat transfer compound, Replace the compound between the heat sinks and processors. The original compound dries up after about a year and will kill your PS3 completely if you do not do this. Good luck,I know its not going to be easy.
Nov 05, 2007 | Sony Playstation 3 (PS3) Console
Psp
is it a scratching scrapping noise?
as some UMD cases, as in the plastic thing around the disc colapse or come apart this stops the disc spinning properly.
Check the plastic on the UMD... click any sides together that may be loose / or make sure the case isnt pushing on the disc.
Also open the PSP, hold it upside, gently shake it & blow into it.
Put the UMD back in & try again.
Oct 03, 2007 | Sony PlayStation Portable (PSP) Console
Sony Playstation 3 (PS3) Console Logo
272 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
