Question about Fluidmaster INC #B1F09 9" Faucet Connector
What is the most common problem associated with the fluid master
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 42 Answers
The water adjuster slide allows it to move on its own.
Posted on Dec 18, 2012
Master warning light is on and I don't know why. Window washer fluid light also on which I can remedy. Would the master warner light be associated with the fluid light?
Master warning light? Are you refering to the check engine light which is yellow? If so, The lights will be unrelated. The check engine light comes on when the vehicles computer detects a problem in one or more of the vehicles operating systems and should be checked to avoid unnecessary and costly repairs
Jan 14, 2016 | 2010 Infiniti QX56
Hydraulic clutch problem
brake fluid goes in the reservoir on top of the clutch master cylinder. If there is no reservoir check for a line to the brake master cylinder reservoir as some cars use the brake master cylinder reservoir as a common unit . Check that that reservoir is full. Bleed out the slave cylinder to remove air in the system.
Nov 03, 2014 | 2005 Mini Cooper
Clutch wont disengage when I push the clutch
do you feel normal pressure under your foot. it can be a couple of thing. check if the master cylinder has fluid in it .check for fluid inside the cab high up on the clutch pedal.then the master is leaking.but most common would be the slave cylinder on the side of the transmission.peel back the dust cover if fluid leaks out replace.
Nov 04, 2013 | 2000 Chevrolet S-10
Dash brake light stays on. Brakes are working and fluid full. 1993 Ford escort wagon
The sender for the brake fluid level is probably bad. It should be mounted on the master cylinder or associated assemblies.
Oct 29, 2013 | 1993 Ford Escort wagon Roof Rack - Rack...
FRONT BREAK IN HARLEY WITH ABS
Do you mean the brake it self, or the abs? I f it is the brake it will certainly either the caliber or the master cylinder. Loosen the bleeder valve on the caliber and give a little pull on the brake lever, check for fluid at the bleedervalve no fluid =bad master cylinder, fluid means bad caliber. this is assuming you have checked the fluid level. Make sure to check on the master cylinder for proper type of brake fluid, my HD uses dot 5. If you are talking about the abs, the most common issue is the wheel sensor connector being loose or bad, all check the wiring to make sure it is clean and tight.
Jan 19, 2013 | Harley Davidson FLHTCUI Electra Glide...
Nkr 200 1991 brake alarm sounds low brake pressure
are you loosing brake fluid? do you notice any leaks? it could be a bad master cylinder or a bad proportioning valve, master cylinder is more common failure.
Jun 09, 2012 | Cars & Trucks
Have a 2001 camly le v6 the cruise control dont work it wont light up warning brake light stays on brakes seam to be in good condition any ideas?
Hello. Welcoem to FIxYa. Please allow us to assist you.
If the Brake warning light is illuminated on your instrument cluster, the cruise control is prevented from being set. This is normal.
The most common reason for the Brake light to be illuminated is low brake fluid in the brake master cylinder. As the brakes wear, the fluid in the master cylinder drops proportionally to make up for the wear on the brakes.
We sould suggest that you check the fluid level in the master cylinder. If it is low, top it off with a new can of brake fluid. Don't use brake fluid that has been opened, use new. Brake fluid that has been sitting in a can will draw moisture, and this moisture, when you put it into your master cylinder, may cause your steel brake parts (that touch the fluid) to rust.
If the fluid level is OK, you may have another issue; one that a trained professional needs to look at.
Thanks for choosing FIxYa for assistance. If you have any questions, please feel free to get back to me.
Aug 17, 2011 | 2001 Toyota Camry
Where is the clutch valve located on a 95 honda accord
clutch master cylinder is located drivers side firewall,right next to brake master cylinder. it has small shot glass size fluid resevoir mounted above it,fluid is fed through hose down into clutch master. clutch master cylinder has a rod mounter on ft of it that goes through firewall and attaches to clutch pedal under dash . clutch slave cylinder is mounted on ft passenger side of transmission assy. most common leak is from master cylinder,you would be able to look under dash ,follow clutch pedal up to where it attatched to clutch master pushrod.follow that rod to wear it meets up to a small 1 1/2" or so rubber boot.fluid will be leaking from that boot if master is leaking.
Jul 03, 2009 | 1995 Honda Accord
My 1994 buick lesabre's brakes will not work. I have low brake fluid and the brake pads were just replaced. My friend said that there was brake fluid leaking from the car and that I might need a master...
if you can see a good amount of wet brake fluid between the brake master cylinder and the brake booster. and you have been adding fliud often,you could have a bad master cylinder. it has to be replaced not rebuilt. you however may have a far more common problem, a rusted through brake line.have someone pump the brake pedal, than look under the car for a brake fluid leak ,repair as needed. than bleed the brakes for a good hard brake pedal
good luck chris
Mar 18, 2009 | 1993 Buick LeSabre
Fluidmaster INC #B1F09 9" Faucet Connector Logo
162 people viewed this question
Top Fluidmaster Plumbing Experts
Jim Goldsmith
Jim Goldsmith
Mack Baxter
Andrew Bugbee
Are you a Fluidmaster Plumbing Expert? Answer questions, earn points and help others
