Question about MSI Computers & Internet
Monitor resolution stuck on 800 x 600, 16 colours.
After reinstalling Windows ME no option to increase monitor resolution above 800 x 60 and 16 colours. Motherboard is MS 6724 ver 1.
  • MSI Master
  • 32,281 Answers
Windows maybe using a generic video driver. try installing the latest video driver from the MSI WEB site.
. You can download the device drivers from MSI WEB support site, select your model motherboard to download :- http://www.msi.com/index.php?func=downloadindex
Posted on Nov 02, 2012
  • 1602 Answers
SOURCE: Can't see 1440x900 resolution in display settings. in LG w1942s
go into the refrash rate and change it to something other than what it is you may need to go up or down it depents on the manufacture settings. also they may say the monitor can do it but it cannot do it, drivers are a big factor also.
right click, select the vedio card options, software option for the card, or properties, display options
control panal, open up personalization,diplay settings, advance setting, choose the best option for your needs.
rod
Posted on Feb 05, 2009
SOURCE: I Need MS-6712 Ver:10A Motherboard driver to download
my system mother board is MSI N1996. After formating my system mu audio and vidio drivers ane not working. I dont have any CD also. Can you slove the problem.
Posted on Mar 17, 2009
SOURCE: I need MS-7142 VER:1 motherboard drivers(audio,
driver installation on MS 7142 ver 1 driver want
Posted on Jun 29, 2009
SOURCE: I lost MS 7060 Ver 1 motherboard driver cd.
Thanks brother so helpful really god bles u
Posted on Apr 14, 2010
Stuck on 640 resolution
INSTALL CORRECT GRAPHICS DRIVER
Jun 07, 2013 | MAG M24LM 24" LED Monitor
Reinstalled Windows XP on an old computer (DELL Dimension 2400) and the monitor won't display above basic resolution. Downloaded and reinstalled the monitor driver and still no good. Opened up START
According to the Dell Support web site the Dell Dimension 2400 has a built in Intel 3D extreme graphics adapter, assuming you are using this and not a PCI graphics card.
Go to the Intel Download Centre and run their Intel Driver Update Utility which will automatically scan your system for updated drivers for any installed or integrated Intel devices.
If the Intel Utility identifies an updated driver for your graphics adapter then download and install that which should enable you to configure a higher resolution for your display.
Dec 24, 2011 | Computers & Internet
My monitor will is all grainy I have connected it to a Sony Vaio (4 months old) downloaded latest drivers etc but still [poor quality -
I think it is your screen resolution it needs to be increased, go through my published guide entitled How to set your Desktop Screen Resolution?
Increased resolution and colour quality will give you an excellent picture.
damnor01
Jan 30, 2011 | Acer S201HL Monitor
When i open the screen i get an indication "not optimum mode Recomended mode 1400 x 900 60 Hz but i can't find a way to adjust it!
this setting is set in windows, right click on your desktop, go to either graphic options or properties and look for a resolution slider, the more you increase the slider the higher you resolution, but smaller the graphics on the screen, if the slider wont go that far or does not have that resolution you will need to change your monitor driver. in the same window, click advanced, monitor settings, look under the driver tab. you may need to download a driver for you monitor and operating system, if its not listed.
Aug 27, 2010 | Samsung Syncmaster 940BW LCD Monitor
Monitor will come on briefly then turn back off, what could be the problem?
A distinct possibility would be a resolution error in the operating system. Try booting in "Safe Mode" (I assume you use Windows), and see if it works. If it does, change the resolution to something safe, such as 1024 x 768 by 16 million colours (24 bit), or even lower. Then boot normally. At that point, increase gradually the resolution.
Jun 17, 2010 | Advueu Technology ADV178T 17" Flat Panel...
Too much screen flickering @ 1024x768 (60hz)
setup your monitor driver supplied with the monitor, you will get more options. Thanks
Oct 29, 2009 | Computers & Internet
Black colour displaying become greenish and narrow vertical lines
Most LCD monitors have a default refresh rate of 60 Hz. Older monitors also have limited resolution. Please check your display settings and ensure you're not using a refresh rate higher than 60, or a resolution higher than what it supports. If either one is the case, you're lucky the LCD still works.
Aug 12, 2009 | Computers & Internet
Need to change resolution but cannot get onto desktop to do so as the monitor just goes to sleep
plug it into your laptop and change the settings to the monitor to 800 by 600 pixels, then change the refresh rate to 60 hz or you could change it to 1280 by 1024 pixels and 60hz but it should work with 800 by 600 too, then plug it back into your desktop it should work then
Apr 13, 2009 | HP L1706 17" LCD Monitor
Problem with my LG monitor L194WT
First change the referesh rate for your monitor. If that works, then you dont have to change the resolution. If that does not work, try increasing the rate again. Once you can get the game, then try to change the resolution from within the game options, if necessary..
May 27, 2008 | Computers & Internet
My monitor is stuck in the lowest resolution
Distorted video after increasing the resolution in Windows. The resolution has been set higher than what is supported by the monitor, ... we recommend 640 x 480 with 256 colors or the lowest available setting.
Computer always boots into Windows safe mode. When booting into safe mode, the lowest settings are used, including your video card. This means that the resolution is 640x480, 16 colors when in safe mode.
Drivers & Downloads for your Dell Monitor Drivers & Downloads for your Dell Monitor ... Drivers & Downloads for your Dell Monitor
These's site click on them and follow instructions, Good Luck....Please dont for get to Vote.Thank you.
Dec 15, 2007 | Dell E173FPb 17" TFT LCD Monitor
Computers & Internet Logo
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
