Question about Lakewood Dryers
I need wiring diagram for lakewood mc-42 fan / elec motor
Elec motor has 6 electrical connectors on the outside --where do they connect?
Jahn27
  • 1554 Answers
SOURCE: I have a 30" drum fan that I turned over in my
You have a two-speed as indicated by the red jumper wire and brown wire left out for connection. These two wires connect to the speed switch with the red jumper to low speed and the brown wire to high speed. The black electrical cord wire connects to the L or COM terminal of the speed switch. The diagram below should give you better understanding on how the motor and the speed switch is wired.
The L/COM terminal makes contact with terminal 1 for low speed and terminal 2 for high speed. The OFF (0) is not shown.
Please accept the solution should you find it helpful and/or informative. Accepting the solution will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Jul 16, 2011
  • 178 Answers
SOURCE: Kenmore Elec Dryer Won't Heat up
Sounds like either a faulty thermostat or heating element. Both are accessed from the lower right backside of the dryer behind a metal door. Be CAUTIOUS, the edges can be sharp and cut you very easily. Good luck.
Posted on Mar 23, 2008
jsrock516
  • 5911 Answers
SOURCE: where can i get a
The model number you provided is for a stacked model washer/dryer combo. If this is correct, look behind the panel directly below the operator console. The manufacturer usually places a wiring diagram behind the panel for service technicians. Post back if it is not there and I will see if I can provide you with a better solution.
Posted on Apr 07, 2008
  • 184 Answers
SOURCE: WHERE CAN I FIND A
THERE IS USUALLY ONE ATTACHED SOMEWHERE IN THE DRYER. TRY INSIDE THE CONSOLE, FOLDED UP AND WEDGED BETWEEN THE WIRING. ALSO, SOME DRYERS WITH A TOE PANEL ON THE FRONT, HAVE THE SCHEMATIC GLUED TO THE INSIDE OF THE TOE PANEL.
SOME OF THE OLDER DRYERS HAD IT GLUED TO THE BACK PANEL.
Posted on Apr 08, 2008
reg501
  • 413 Answers
SOURCE: loud squeaking noise on an
The most common cause for this noise is a failed belt idler pulley. Lubricating is a temporary solution and will not last, the noise will return. You can get a parts list and breakdown at this website: http://www.searspartsdirect.com.
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 19, 2008
Need a replacement motor for MC-42
just trry to find a motor with the same wattage, power,and shaft type.
off hand i don't know where to get motors except off of ebay or the factory, but good luck!
Aug 12, 2010 | Lakewood MC-42 Fan
I need a replacement motor, 60 HZ 2.7 amp, for a Lakewood fan Model HV-217SPC
GRAINGER.COM ... .GOOD LUCK AND I'FN I WAS ANY HELP PRAISE IS APPRECIATED .. SO VOTE JAY MOTORWIZJ
May 28, 2010 | Lakewood MC-42 Fan
Fan will not come on,but it turns.need to know if there's a reset button or cluch reset?
I think that some models have areset button on/near the motor. Look on the end of the motor for a red button.
--W/D--
Aug 18, 2009 | Lakewood MC-42 Fan
Need to rewire Lakewood Fan
wires should be color coded. You can go to the hardware store and pick up some crimp connectors
Jul 07, 2009 | Lakewood 007 Floor / Box Fan
Where can i get a fan blade for the lakewood mc42 in fan
have a crack in one of the blades. Where do I get a new fan?
Jun 29, 2009 | Lakewood MC-42 Fan
I get error code c-0046 and now machine will not work. What do I do?
C0046: Fusing Cooling Fan Motor /1’s failure to turn
Relevant Electrical Parts
Suction Fan Motor (M12) Control Board (PWB-MC)
Step Action
WIRING DIAGRAM
Control Signal
Location
(Electrical
Component)
Check the connector of motor for proper connection
and correct as necessary.
Check the fan for possible overload and correct as
necessary.
M12 operation check PWB-MC PJ18MC-9 (LOCK)
PWB-MC PJ18MC-7 (REM)
6-P
4 Change PWB-MC — —
Fusing Cooling Fan Motor/1 (M9) DC Power Supply (PU1)
Step Action
WIRING DIAGRAM
Control Signal
Location
(Electrical
Component)
necessary.
3 M9 operation check PU1 PJ17PU1-5 (LOCK) 2-K
4 Change PU-1 —
Jun 05, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
ERROR CODE C0096 - BIZHUB C350
2.6.19 C0096: Image Transfer Belt pressure/retraction failure
2.6.20 C0098: Fusing Pressure Roller pressure/retraction failure
1st Image Transfer Retraction Position Sensor (PC12)
1st Image Transfer Pressure/Retraction Motor (M11)
Step Action
WIRING DIAGRAM
Control Signal
Location
(Electrical
Component)
Check the M11 connector for proper connection
2 PC12 I/O check PWB-MC PJ3MC-6B (ON) 6-B
M11 operation check PWB-MC PJ5MC-1~4
(Pulse Output)
6-C
4 Change PWB-MC
Feb 18, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Help! Dog Bit Through Electrical cord on Lakewood 2727. How to replace cord???
another option for you would be to use crimp on terminal connectors(**** connectors) you may purchase these from most hardware stores. Even using these I would still tape around the outside to ensure a good insulating surface.
Apr 28, 2008 | Lakewood 2727 Heater
Dryers Logo
504 people viewed this question
Top Lakewood Dryers Experts
Jerry Greenberg
Jerry Greenberg
tfelton3
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
