Question about Dell Inspiron E1705 Notebook
P C only works in safe mode, can't download files
  • Fion Wan Nov 03, 2012
    my pc is similar to yours. can't download files at all. But couldn't work out what's wrong since all other funtions are still working normally.
  • 31 Answers
Run Microsoft Memory Diagnostic, and follow up with an overnight of memtestx86+
There is always the possibility that it was a bad BIOS Update (something that should not be done unless to get rid of a particular compatibility issue to begin with), but if it passes POST then it is likely fine. You may want to reset the UEFI/BIOS, and load defaults to ensure system stability.
Just a word of note; Recently I just had a real pain of a repair job. Everything passed all tests, but I was still having random crashes. Turned out that the controller on the SSD was having issues, so the SSD needed to be replaced. But the device had passed 5 different benchmarking suites which tested different aspects of the drive, and the only way I found what was wrong was by replacing 1 part at a time.
Posted on Nov 01, 2012
My Sound In Safe Mode Will Not Work Even If I Download Stuff Or Try?
Booting in Safe Mode tells a computer to start ONLY what is needed for the computer to run, i.e. the Operating System and services associated with it. Running in Safe Mode is generally used for troubleshooting purposes. Try starting the computer in a "normal" start up.
Feb 16, 2013 | Dell Computers & Internet
Windows Error Reporting Error
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer also Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions. Hope this helps.
Dec 30, 2012 | Computers & Internet
Office word files in my pc become corrupted. I can't read them.
Try to repair your corrupt file with the help of Open & repair. You can do this by following below steps:
Start->File->Open->Select the corrupt file->Click arrow next to open button->select open & repair
If you are still facing the same problem then try to start MS word in safe mode.
If you will be able to open the file in safe mode then there is a problem with add-ins. Delete all the add-ins to fix the problem.
Nov 02, 2012 | Microsoft Office Word 2003 for PC
\windows\system32\config\system 0xc00000e9 toshiba vista
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Oct 04, 2012 | Toshiba Equium A100-027 Laptop Dual Core...
What do I do?!
Try this:
Reboot your PC into Safe Mode With Networking:
Start your computer in safe mode
Safe mode starts Windows with a limited set of files and drivers. Startup programs don't run in safe mode, and only the basic drivers needed to start Windows are installed. For more information, see What is safe mode?
Safe mode is useful for troubleshooting problems with programs and drivers that might not start correctly or that might prevent Windows from starting correctly. If a problem doesn't reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes. If a recently installed program, device, or driver prevents Windows from running correctly, you can start your computer in safe mode and then remove the program that's causing the problem. For more information about troubleshooting problems in safe mode, see Diagnostic tools to use in safe mode.
  1. Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer.
    Click the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, click the arrow next to the Shut Down button eb058ccf-b21e-4dfe-9bb7-1ad6c83b705c_47.jpg, and then click Restart.
  2. Do one of the following:
    • If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you'll need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
    • If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to start in safe mode, and then press F8.
  3. On the Advanced Boot Options screen, use the arrow keys to highlight the safe mode option you want, and then press Enter. For more information about options, see Advanced startup options (including safe mode).
  4. Log on to your computer with a user account that has administrator rights.
When your computer is in safe mode, you'll see the words Safe Mode in the corners of your monitor. To exit safe mode, restart your computer and let Windows start normally.
Once in Safe Mode With Networking
Click on the two links below and go to the download now tab. Save Rkill and Malwarebytes to the desktop.
First run Rkill then Malwarebytes.
http://www.bleepingcomputer.com/download/rkill/
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html
Aug 14, 2012 | Acer Computers & Internet
How do i get my computer to run in normal mode again? and how do I get rid of the google chrome because this problem didn't start until i downloaded it into my computer.
Once Safe Mode comes up, click Start/Programs/Accessories/System Tools/System Restore and select a Restore Point (date and time) that is before you downloaded and installed Google Chrome.
I seriously doubt that Google Chrome is your problem. Chrome is among the top tier as far as browsers go.
I think you've got a windows system file or boot file issue.
Apr 15, 2012 | Gateway NMZ-500SE Notebook
I deleted files on my hp mini and then used system recovery to try and fix it now windows wont start
Try coming up in safe mode and selecting last known good configuration. Get safe mode by powering up laptop and pushing F2 on top row of keys. It can be fussy to get it to come up. Try it again if it doesn't come up the first time.
Jul 15, 2011 | HP Mini 1000 Netbook
I have a Fujitsu Lifebook C2210, that took 15 mins to start up and power down. The unit just sit there with then fan, the power indicator, the ac adapter are turn on, but no HD indicator. After 15mins the...
It sounds like you might need to free up some space on your hard drive. Delete some of your programs that you don't use anymore.You can do this is by tapping f8 while turning on your laptop.If you can get into safe mode then there is a chance.When the safe mode screen comes up you will need to use the up arrow button to highlight safe mode.You will come to a page that gives you a choice yes for safe mode or no for a system restore.Safe mode is where you want to go.This will only load the core programs,about ten programs.Go to the control panel and remove as many of the programs that you can.Don't remove any thing with Microsoft in the title.As you uninstall you will get more room on your hard drive.Do a disk clean, defragment your hard drive and then you need to get out of safe mode and clean out your browser history,cookies temporary files all of this is under tools in the menu bar. When you get all of that taken care of there is one more thing to do and that is to turn off system restore and turn it back on again.Then create a new restore point.What this dose is erase all of the old restore points.
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?tag=rb_content;main
http://download.cnet.com/Advanced-SystemCare-Free/3000-2086_4-10407614.html?tag=rb_content;main
http://download.cnet.com/windows/3150-20_4-0-3.html?&filter=licenseName=Free&tag=page;page Smart Defrag
Here are some free apps that I use.
May 18, 2011 | Fujitsu LIFEBOOK C2210A (AKA0F0A00B001000)...
How do I turn off safe mode on Mozilla
Want to turn off Safe mode option on your Mozilla Firefox? Then follow this simple steps:
  1. Open Mozilla Firefox
  2. At the top of it (Firefox window), click on the Firefox button (in you have Windows Xp, click on File menu) and then click Exit.
  3. Start Firefox as you normally would.
  4. If Firefox keeps starting in Safe Mode see Firefox is stuck in Safe Mode.
If your Mozilla Browser is stuck on safe mode better to the steps here: Click here
May 16, 2011 | RCA VR702HF VCR
Dell Inspiron E1705 Notebook Logo
63 people viewed this question
Alun Cox
