Step 1: Enter Safe Mode
a)
Start or re-start your computer.
b)
Before the Windows 7 loading screen appears, Press 'F8? to enter
Advanced Boot Options.
c)
Use arrows to choose 'Safe Mode' when you can see the Advanced Boot
Options screen.
d)
Press 'Enter' and wait for Windows 7 files to load.
e)
Log on with an administrator account when you can see the log on screen
Note: Well, when you are presented with the
Advanced Boot Options screen, there are 3 types of Safe Mode. They are the Safe
Mode, Safe Mode with Networking and Safe Mode with Command Prompt, and the 3
options are all available for you. Here above we take Safe Mode as an example,
but if you choose Safe Mode with Command Prompt, you'll need to input related
to command prompt to reset the password.
Step 2: Reset the forgotten Windows login
password in Windows 7
Now you could diagnose and solve some serious
computer problems in the safe mode and reset the forgotten Windows login
password in Windows 7 as follows:
1.
Click 'Start' button, input 'lusrmgr.msc' into the Search box and press
'Enter'.
2.
In the 'Local Users and Groups screen', click 'Users'.
3.
Right-click the account that you need to reset the password for, and
then click 'Set Password'.
4.
Type and confirm the new password, click 'OK'. (You can go to 'Local
Users and Groups' screen by right-clicking 'Computer' to select 'Manage' on
desktop.)
Step 3: Log on your password protected PC again with the new password since you have successfully performed Windows password reset for Windows 7.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words "Safe Mode" appear in the corners of the display to identify which Windows
mode you are using. If an existing problem does not reappear when you
start in safe mode, you can eliminate the default settings and basic
device drivers as possible causes.
If you don't know the cause of the problem, you can
use the process of elimination to help you find the problem. Try
starting all of the programs you commonly use, including the programs in
your Startup folder, one by one, to see if a program might be the
cause of the problem.
If your display works in safe mode then you have a video driver issue or virus or software issue.
