Question about Locks & Locksmithing
How to change my weiser lock combination on electric door opener
Weiser lock model 67wl
VtToolMan
  • 704 Answers
SOURCE: Have to change the key code? No manual.
You can change codes as often as you like, for use by babysitters, contractors, etc. You can also reset the lock so you can reset the master code, which is needed in order to set the other user codes.
Rather than re-type all the step-by-step instructions, since you also could benefit by having a copy of the manual for your use and reference, I'll give you a link to a free copy you can save and print.
http://www.smarthomeusa.com/Products/ED1460XXXX/manuals/WeiserLockPowerbolt1000-manual.pdf
Hope you find this Very Helpful and best regards!
Posted on Aug 19, 2009
VtToolMan
  • 704 Answers
SOURCE: Weiser combination lock for front door
You can reset the lockset to change the master code and then enter in other codes for use by contractors, delivery people, etc. which you can then delete as you wish without having to give out the master code.
Rather than give you the simple step-by-step instructions for resetting the lockset, I've provided a link to the user manual so you can have it available for use and reference, as I assumed you didn't have yours any longer.
  • 14512 Answers
SOURCE: the kids locked the bathroom door and closed it... my
if not a key hole stick small screwdriver or any small flat devise into handle and turn will unlock passive door handle
Posted on Oct 19, 2009
  • 15 Answers
SOURCE: how do i change my code on my weiser front door
page 6ish
Posted on Nov 06, 2009
  • 17 Answers
SOURCE: I have a keyless weiser deadbolt. Can't find any
Very common for the keypad to stop working.
check that the keypad is not defective. You can disconnect the batteries and then unplug the keypad. Now put the batteries in without the keypad connected. If the beeping stopped, your keypad may need replacing.
You can get a replacement at the store where you bought it for free or call the Weiser support line and they will mail you one for free.
Posted on Dec 26, 2010
How do I enter new code?
[PDF]Quick Reference Installation & Programming Manual
www.weiserlock.com/.../electronics/smart...
Translate this page Weiser Lock25605-02 Weiser SmartCode Manual. Program. Button .... Press and hold the "LOCK" button on the exterior keypad, while fully inserting the battery pack into .... anyone withaccess to the power board can change these codes, you must restrict access ...technical means, or evaded by entry elsewhere on the property. No lock.
Nov 26, 2015 | Weiser Lock Locks & Locksmithing
Change batteries in weiser Powerbolt elec deadbolt
Pull the inside cover away from the door, to remove. This exposes the battery holder. Replace all four AA batteries with new alkaline AAs The cover snaps on. Align top first.
http://www.weiserlock.com/PDFs/instructions/Electronics/Powerbolt.pdf
Mar 31, 2014 | Weiser Lock POWERBOLT ELEC DEADBOLT
Lost combination
The Weiser brand and Kwikset brand Powerbolt are identical, so these instructions will work just fine for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Change the batteries with fresh brand-name batteries before you reprogram!
Sep 21, 2012 | Weiser Lock Powerbolt 1000 Lock
Need to change the combination on weiser lock
Follow this link:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Which will take you to the programming instructions for your Powerbolt 1000.
Jun 27, 2011 | Weiser Lock Powerbolt 1000 Lock
Weiser combination lock beeps
You should check if the keyboard ribbon cable is properly connected and not pinched or cut ... Also it is possible that water has entered into the keyboard. In case you should remove and dry with a hair dryer.
Jul 09, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
Need to change combination
Here's a link to the Frequently Asked Questions page for the Powerbolt 1000:
The instructions for reprogramming the code can be found there. Good luck!!
Jun 01, 2010 | Weiser Lock Powerbolt 1000 Lock
I have an old weiser powerbolt 3000 with a remote. my battery went dead in the remote and i lost it after removing it. can anyone tell me what battery the remote takes?
I have the Weiser Lock powerbolt 3000 Home Access system Model WLTX Garage door opener and the Battery is a Maxell CR2032 3 Volt. very common.
Nov 18, 2009 | Weiser Lock Locks & Locksmithing
The kids locked the bathroom door and closed it... my
Oct 19, 2009 | Weiser Lock Locks & Locksmithing
May 17, 2009 | Weiser Lock POWERBOLT ELEC DEADBOLT
How do I change combo of electronic lock
Have you tried removing the cover (inside the house).. there should be a program button, which you press, enter your code, and press again....don't forget to try your code before actually locking the door...
Hope this helps
Jan 07, 2009 | Weiser Lock POWERBOLT ELEC DEADBOLT
Locks & Locksmithing Logo
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
