Question about LG 42PX5D 42 in. Plasma HDTV
What is "The ground"
[quote]disconet the ground on the power cord of your tv will fix the problum. or the subwofer power ground .[/quote] This is the solution I was given in response to my previously posted problem. Does anyone know what "the ground" is, or how I disconnect it?
Do not repeat DO NOT disconnect the Ground or Earth of any appliance, potentially lethal voltages can occur under fault conditions that the ground protects you from.It is a connection to a bonding point of your nearby mains distribution transformer. If your problem is hum then you could try using a balanced screened cable between your TV & audio units with one end of the screen disconnected (This is normal practice in studio's and broadcast situations) HAMAR
Posted on May 18, 2007
Hi Guys, I have a Sony 55nx810 TV connected to wifi with the latest update. My 3D, one day just stop working. Since then, in the options menu/3d menu, I only can select: "3D simulatior" or...
Sounds to me like it is the 3d Transmitter, but before you go and buy another one try and do a factory reset on your t.v , maybe this could help everything go back to normal. By the way you have a great tv :) .. if the problem continues call sony customer support 1-877-865-7669. Have a nice day.
Jun 23, 2011 | Sony TMRBR100 3D Sync Transmitter for 3D...
Tip
How to Fix a Polaroid LCD TV Screen
<p>A Polaroid LCD TV delivers its picture via DVD player or cable connection to your home or office. After setting up your device and using it, you might experience technical difficulties with power loss and picture quality. Navigating through a few steps of self-maintenance will have your Polaroid TV running smoothly again in little time. You can examine your TV's power cord for damage, rewire a DVD player connection, and adjust your Polaroid's backlight.<br /> Difficulty:Moderate <span>Instructions</span> <ol> <li> <ul> <li> <span></span> Turn your Polaroid around so that the back is facing you, as a first step in correcting a power loss issue. Examine the length of the power cord from the back panel of the Polaroid to the wall outlet for damage, such as tears or rips. Replace the cord, if you see damage. Unplug the TV from the wall outlet and inspect the metal receptors (prongs) for dirt. If the prongs are dirty, clean them with a dry cleaning cloth. Plug a separate electrical device into the outlet and turn it on to confirm that the outlet is performing correctly. Plug the Polaroid TV back into the outlet, and try again.<br /> </li> <li> <span></span> Twist the Polaroid TV's back panel towards you so that the connected cables and jacks are easily accessible to you. If you're experiencing problems getting a picture from your DVD player, inspect the connection of the audio/video cables to your "Composite In" jacks. There are three cables in a standard audio/video setup: a yellow cable, a red cable, and a white cable. Unplug all three cables from their jacks to reset the connection. Insert the yellow-tipped cable into the "Video" port, which is yellow-colored to make matching the cables easier. Insert the white-tipped cable into the "L" (left audio) port and the red-tipped cable into the "r" (right audio) port. Perform the same steps on the audio/video cable out ports of the DVD player, and try again.<br /> </li> <li> <span></span> Raise the TV's backlight level, if you're having trouble seeing the picture. Push the "Menu" button (located on your remote control), and the TV setup menu will appear. Use the navigation buttons located on your remote control to scroll to "Image," and push "Ok" -- located within the navigational buttons on your remote control. A list of options will be displayed, such as "Contrast," "Hue," and "Saturation." Choose "Brightness" from the options. Use the four-way navigation buttons to raise the brightness (make your screen brighter and more illuminated) or lower the brightness (make your screen darker).<br /> </li></ul> </li></ol>
on Dec 27, 2010 | Televison & Video
I have problum in assassins creed,my pc req:2.0GHz 1gb ram (nividia geforce 5500 256 mb card),when i start the game the game runs but! the screen show na thing everything is runing back the sound can i...
I can help you with that problem, its simple just pull the video in and video out cord from the tv and blow on the cords to get the dust and dirt from out of it then plug it back in.
Feb 27, 2011 | Ubi Soft Entertainment Assassin's Creed...
I have a kenwood KMR-700U. We have disconnected all the speaker wires and only have power going to it. We have ereset it multiple times, but it will not come off protect mode.
try and taking power away from it completely just disconet the power wire and then hook it back up if that dont work disconnet the power and ground and maybe find a new better place for your ground
May 22, 2010 | Car Audio & Video
Sony wega #KDF-55-WF-655 won't turn on: goes to standby mode
don't wory sir , may i help you .
this is a not mager problum but sum times technicean is parsnal baneefits besness and fast money making this rongh dignosis and canfused to castamer so don't wory ...
[1] problum is in side tv set in out put voltage form EHT becose your tv is red and green light is ok then SMPS is ok
pls. check with tv techicean and follow sum tips
* voltage check From EHT out put and canacting spear.
* H- out put tangester and cancting sperar
* H out put tarngester base tarminal voltage check if ok then 100% problum is EHT or canacting spaer so don't wory all spear is not very expancive pls.find Best tech.and solve this problum Esely
best of luck...
Jan 30, 2010 | Toshiba CZ36V51 36" TV
My picture is larger than the screen size
hi,
this is a coman problum.
this is a pin.amp scaction problum. it is not expancive pls.fix this problum with NR.tv.techincean esyly.
Nov 16, 2009 | RCA F27450 27" TV
The little red light next to the power button blinks, but when you push the power button all we get is a series of click, click, clicks. My wife said she was watching it and it just went dark. No pop, no...
pls check this problum with your thch. this is a horizantel saction problum
check: H-output tranjister / SMPS outpot rectifer / EHT
it is not major problum. thch. is sole the problum
NOTE:pls check your tv power code pin is proper canect with pluge atherwes same prob. agein
Oct 06, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Looking for a power supply
Sorry about the above post, but I wasn't signed in yet and this crazy GLITCH here put me down as a GUEST instead. The above post was mine, as I'm resending it again below.
Thx,
Frank
FRANK'S FIX IT SHOP
AC/DC power adapter + Power cord. 24VDC power adapter + power cord for Toshiba 20HLV15 20" Flat Panel LCD TV
Specification:
Input :100-240VAC (50-60Hz)
Output : 24VDC 4Amp (72W)
Part# ADP-2404-3PX
Approx cost: $50-60
Call Toshiba USA and give them that p/n for an exact cost quote plus shipping.
Best regards,
Frank
Apr 01, 2008 | Toshiba 20HLV15 TV
Transparent horizontal bar
May 14, 2007 | LG 42PX5D 42 in. Plasma HDTV
LG 42PX5D 42 in. Plasma HDTV Logo
