Question about Locks & Locksmithing
I have a wolf electronic safe 25EA and i will change the key pad,and ware i can find
5 Suggested Answers
  • 124 Answers
SOURCE: i forgot the safewell electronic code and didnt have the key
NOTE: The safe needs to be upright and right side up or the locking mechanism
won’t work.
ELECTRONIC SAFES
To open an electronic safe the first time, press the following numbers/letters on the
electronic keypad –159B. (These numbers are preset. You should change the code as soon
as possible after opening the safe to insure proper security). After you have entered the
factory set code, you will need to turn the knob on the faceplate to open the door. You will
have 5 seconds to turn the knob before the locking mechanism is reactivated.
ENTERING YOUR SECURITY CODE
To enter your own security code you will need to follow the steps listed below:
1. After opening the electronic safe (with the pre -set factory code of 159B) locate the
small red button on the inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep.
DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW
SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits
long, and confirm your new code by pressing the letter “B” on the electronic touch pad.
Before you close the door, try the new security code to make sure the lock release the
knob so you can turn it and retract the live action locking bolts.
If you can not get this open more then likely you will have to cut it open.. One last thing to try is to email safewell sales@safewellsafe.com
Good luck
Posted on Sep 14, 2009
  • 2976 Answers
SOURCE: micromark Electronic safe
Contact the manufacturer with the model and serial numbers. They CAN supply a default passcode number.
Posted on Aug 07, 2009
jmgldsmth
  • 1889 Answers
SOURCE: somebody tried to open my electronic safe box and
call a locksmith to open and, reset your combination;
Posted on Jul 23, 2010
  • 905 Answers
SOURCE: Hi there, I recently purchased a
The keyhole for the emergency key is likely located under the plastic label to the right of the knob. You will need to insert the key, turn it, and then turn the knob to withdraw the pins and the door should then open.
There are a few version of this safe that are floating about, they were made for several different companies. The exact version that you have is unknown, but the key hole is likely hidden behind a label, or could be under the knob itself (although unlikely since you have to be able to turn the knob while the key is turned as well).
Posted on Aug 18, 2010
I have a Namson SFT-25EA electronic safe, batteries dead, can't remember where I stored key, can I get into it and be able to re use or do I need to force my way in
A "Trouble key" has been provided in case you forget or lose your security code. Remove the small central panel from the front of the faceplate. Insert the key and turn it counter clockwise. Then turn the knob on the door towards the right. This will manually open your safe. If you lose your key, you may purchase a replacement key by referencing the serial number located under the central panel by the lock.
Feb 15, 2017 | The Home Security
Where is the battery compartment in my ce electronical digital safe?
do you have a round lock pad. This model has 2 9 volt batteries under the key pad
http://bestbatterytips.com/change-replacement-batter/safes-with-electronic-locks-replacing-the-battery/
Lots of info here
  • How to open digital safe when battery is flat and key not ... www.youtube.com/watch?v=aqC9V7SDKdQ
    • BY KHTHHONL
    • 1 MIN
    • 417K VIEWS
    2012-11-09 · How to open a digital safe when the battery is flat and the ... How to open digital safe when battery is flat and ... How Secure Are Electronic Safe ...
  • Locked out of my Digital Safe [Archive] - PPRuNe Forums www.pprune.org/archive/index.php/t-357319.html PPRuNe Forums > Misc. Forums > Computer/Internet Issues & Troubleshooting > Locked out of my Digital Safe. ... CE (Chinese made) electronic security safe ... battery ...
  • LA GARD LG Basic digital electronic safe lock changing ... www.youtube.com/watch?v=M07EpfSmoAU
    • BY DEANSAFE
    • 3 MIN
    • 99K VIEWS
    2009-10-13 · For instructions on this and other electronic digital safe ... How to change the combination and battery on ... Basic digital electronic safe lock changing ...
  • User Manual for Safe EA25 Installation - Tayabally www.tayabally.com/digitalsafe/mannuals/Safe EA25 Installation... You should change the code as soon as possible after opening the ... BATTERY REPLACEMENT. This safe uses ... MAINTENANCE FOR KEY AND ELECTRONIC SAFE.
  • Elektronischer Digitaler Safe Electronic Digital Safe www.produktinfo.conrad.com/...799999/...DigitalerSafe_de_en_fr_nl.pdf · PDF file Electronic Digital Safe Version 12/08 ... (CE). Any usage other than ... Replace your batteries when both the red and green light illuminate. 1.
  • Instructions for an Electronic Digital Safe ' eHow www.ehow.com > Home > Home Safety > Home Safes Instructions for an Electronic Digital Safe By Shawn McClain eHow Contributor Pin Share ... Replace the used batteries with new ones. For most safes, ...
  • Apr 24, 2016 | Locks & Locksmithing
    I just purchased it but it is close, what is the default safe code to open it? Thanks
    RUSH BACK TO THE STORE WHERE YOU BOUGHT IT. The only one who can give you safe code is the one who sold it to you.
    As if it has a default code? Electronic cosdes might be reset but of sourse, you should know the original.
    https://www.youtube.com/watch?v=_tqTp57YfCw
    http://www.safeoptions.co.uk/blog/how-to-change-number-on-keysafe-lock/
    In any case, if someone with experience with a safe similar to yours might be interested to share his experience, you should provide make and model of you unspecified safe.
    I've been lookin for safe mnauls on internet and got this one:
    http://www.sargentandgreenleaf.com/pdf/630-302_6120_op.pdf
    and also this one:
    http://hilkab2b.co.uk/manuals/s-25ea%28ii%29.pdf
    How To Change Number On Keysafe Lock Safe Options
    Guses might find some better information should you provide make and model of your safe.
    Aug 22, 2015 | Home Security
    CATHEDRAL ELECTRONIC SAFE 25EA CANNOT OPEN IT WITH MY CODE NEED THE RESET CODE
    You can't, as there is no reset code available once the door is locked. It would be absolutely useless anyway if all a thief had to do was to ask on a public website for a bypass code. The only alternative way into the safe is via the override key (an actual physical key which fits into an opening hidden behind a removable plastic panel on the safe door).
    If you cannot find the emergency key then you have just one fix: you must open the safe destructively. Fortunately, your model is just a budget-priced electronic strong-box rather than a true safe, so the top or sides can be easily be cut open using a grinding disc or by just drilling a few holes and joining them up with a cold chisel.
    Note that it's not worth calling out a locksmith, they'll only cut the box open and the charge will be many time more than the cost of a complete replacement strong-box (you can buy a similar complete replacement for under £40 including postage from this seller).
    Sep 19, 2011 | Vacuums
    How to open electronic safe of model 25EA
    thank you very much, I change the batteries and password did not work ... doliann
    Oct 11, 2010 | Safe International Digital Electronic Safe...
    Batteries are dead and I've lost the keys. Its an old electronic digital safe and I have the key number that goes with it. Know where I can get replacement keys or if its cheap enough to have...
    Only through a licensed locksmith. Provide the key numbers and possibly even take the safe to him/her as proof of ownership. Locksmiths have to record all attemots to open safe's or maling f keysto the police.
    Please provide a rating for my help++++Thanks for using FIXYA
    Jun 15, 2010 | Safe International Digital Electronic Safe...
    I WANT TO CHANGE COMBINATION ON MY SENTRY FIREPROOF SAFE HOW?
    I have a sentry safe csw 4747 Idont no tha combination
    how do I do the safe a key and electronic key pad
    Jan 11, 2010 | Sentry Fireproof Safe
    I forgot the safewell electronic code and didnt have the key
    won’t work.
    ELECTRONIC SAFES
    Good luck
    Sep 14, 2009 | Locks & Locksmithing
    I locked my key in the safe and I CAN'T REMEMBER THE CODE THAT THE MANUFACTURER GAVE YOU WHEN YOU FIRST PURCHASE IT. psf80 PRO-SAFE ELECTRONIC DIGITAL SAFE
    Press 159 - safe will beep for each number pressed on the key pad, Then press A or B, the green light will come on. Rotate the knob clockwise and pull the door open.
    Aug 18, 2008 | Office Equipment & Supplies
    Locks & Locksmithing Logo
    680 people viewed this question
    Top Locks & Locksmithing Experts
    ray gallant
    Tom Chichester
    Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
