Question about Samsung SC-D353 Mini DV Digital Camcorder
Vertical lines on memory card playback
Whether recording to tape or to the memory car, I get vertical lines displayed in the playback. And cleaning the heads did nothing (especially since the problem is present on memory card playback).
    Problem Solver:
  • 5 Answers
The lcd ribbon cable is cracked and must be replaced
this is a common problem with this model I have fixed over 100
Posted on Feb 03, 2009
Not able to view anything on screen
I work on this model of samsung the lcd problem is a common thing with this camera
The ribbon cable to the lcd from the camera cracks and causes what you are talking about .
Normally the camera will still work buy using the eye viewfinder for recording and playback but you will not hear the sound unless the lcd door is open but then the picture in the viewfinder goes away when this door is open and comes back when it is closed
my email is spinboss@comcast.net and sell on ebay as uromastyx
Jan 25, 2009 | Samsung SC-D353 Mini DV Digital Camcorder
Lines across screen on playback.
A Q-tip should never be used to clean a video head.  Unfortunately they can pull the tiny head out of alignment.  I believe this is your problem and the repaid may be more costly than a new purchase.
Nov 25, 2008 | Panasonic Palmcorder PV-DV351 Mini DV...
TRV138 Audio only on playback.
The video heads are clogged or broken. Remove the cassette cover and in the middle back of the mech is a cylinder, this is the drum assy. You can gently spin the drum and look for a black piece of carbon (tiny). This is actually one of the heads. You can take a swab (Q-tip) with liquid head cleaner and very gently clean the heads (more than one) wipeing horizontally, never vertically to clean the heads. Inspect for broken heads as well.
Mar 17, 2008 | Sony Hi8 CCD-TRV138 Camcorder
Horizontal lines on display but firewire and SD card work fine
Hello people who face similar problems...
First confirm whether it is a problem with the head assembly/ dirty heads.
Do the symptoms appear only on the camcorder's internal TFT side display or is it visible on an external monitor (connect using the AV cable supplied) and the EVF(electronic view finder) also.
If it is visible on the EVF, TFT Side display and the external monitor then it is definately a case of Bad video heads or the tape guide requires to be aligned or calibrated
Dec 18, 2007 | Canon Elura 100 Mini DV Digital Camcorder
Recording problem on Sony SLV-R1000
The deck needs a good cleaning. Try using a brand new tape and run it on playback for 20 min or so. You could try using a cleaning tape, but many of them are abrasive. If this doesn't work, you need a deck re-alignment which will cost more than your set is worth.
Nov 13, 2007 | Sony SLV-R1000 S-VHS VCR
Lost LCD Screen
You MAY just have a dirty playback head. Purchase a head cleaning tape (Bestbuy, Target, etc., for about $20) and try cleaning your playback head. Colored lines is ONE symptom of a dirty head. A blue screen is ANOTHER. I had that symptom yesterday (9/7/07), got a cleaning tape and solved the problem. I can now again see on the LCD display what I recorded on the tape. Good luck.
Aug 21, 2007 | Samsung SC-D363 Mini DV Digital Camcorder
Vertical lines while recording Canon zr100 camcorder
I'm positive the camera needs to be cleaned. The recording heads sound like they are dirty and it doesn't matter what tape is placed in there, whether it's new or not. Purchase a cleaning tape from a consumer electronics store. Make sure you read the directions very carefully. The tape actually rubs the recording heads so you only want to do it for a short time to avoid damage. Let me know how it goes.
Nov 20, 2006 | Canon ZR100 Mini DV Digital Camcorder
Samsung SC-D353 Mini DV Digital Camcorder Logo
135 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
