Question about Stairmaster Exercise & Fitness
Stairmaster won't have a continuous workout
My stairmaster 4400 pt or cl will only work on manual for about 5 mins and then automatically reset to the beginning( intro and selecting a workout). with the other options as soon as its pressed it goes back to intro. What is causing this?
  • Stairmaster Master
  • 918 Answers
My Stairmaster unit seems to work in manual mode, but resets when I select a program. What is wrong? It is possible that the console on your Stairmaster unit may not be configured for the appropriate machine. This can result in the console accepting and allowing a manual workout but not accepting or allowing a program. Stairmaster Units Works in Manual Mode but Not in Program
Posted on Jul 22, 2014
maxtreadmill
  • 832 Answers
SOURCE: stairmaster climber model 4600 pt pedals go all
Unplug dc power connection then remove right side panel check for loose connections on on alternator, check distance of speed sensor to speed sensor disc you should no more than 3 credit card distance between them. Next remove the black wire from the B+ terminal on the alternator, then remove the brown wire from the field terminal on the alternator.Place a short wire with alligator clips between B+ and field terminals start stepping for about 10 to 15 second you should full resistance in that case its the upper console that if not replace alternator
Posted on Mar 14, 2010
maxtreadmill
  • 832 Answers
SOURCE: Stairmaster freeclimber 4400 pt will
Remove console knobs form the back of the console, lift the up, and disconnect the 20 pin cable from the console. Get a multi meter go to dc volts 100v range. On the connector you will be testing for 12 to 19 volts. When Looking at the connector the connector nipple should be pointing left starting form the bottom left odds numbers right bottom even you will hunt for pin 1 Neg pin 10 Pos. If all voltage readings are within 12 to 19 volts and the console is not powering up , then either replace or have the console repaired.
National Gym Parts can help with process go to http://www.gympart.com/
Posted on Apr 11, 2010
maxtreadmill
  • 832 Answers
SOURCE: stairmaster pedal slip
Sound s like it maybe the hub assembly they have a one-way bearing in them and that could be cause the problem go to
http://www.gympart.com/ or call them 1-800-496-7278 they will have the parts for your
maxtreadmill
  • 832 Answers
SOURCE: stairmaster freeclimber 4400pt how to fix slipping
This could be the hub assembly slipping I would replace this assembly and the pedal chains call National Gym Supply @ 800-496-7278 and get pricing for the hub assembly and step chain ( L & R )
Posted on Jun 01, 2010
Marco Darko
  • 3 Answers
SOURCE: Stairmaster 4000pt pedals lose resistance during workout
places to check.
http://www.mindbites.com/lesson/8320-diy-stair-master-4000pt-pedal-drop-or-slip-diag
Posted on Jul 26, 2010
I have a stairmaster 4400 and every time I get on and try to select a workout it says config rqrd and if I push the clear button it turns off
Display reads CONFIG RQRD or NTM CONFIG RQD on Stairmaster Equipment Probable Cause The message CONFIG RQRD or NTM CONFIG RQD appears when the console needs to be configured for the machine type it is installed. This message is common when the console has been replaced or if the settings have been changed. Message is commonly seen on various Stairmaster equipment such as bike models 3000CE, 3300CE, 3400CE, 3600RC, 3800RC and 3900RC; stepper models 4400PT, 4600PT, 4400CL, 4600CL and SC916; stepmill models 7000PT and SM916; elliptical model ClubStride 5100.
Corrective Action
  • Make sure the unit is in an "idle" state. "Idle" state means the console is not displaying an error or any message that requires data input. The display should basically be freshly powered up, scrolling the EKG or welcome message
  • Configure the console for the proper machine type by pressing Level UP, 80, ENTER
  • Using the Level UP or Level DOWN keys, scroll through to the proper machine type (Bike, Elliptical, Stairclimber or Stepmill)
  • Once the proper machine type is shown on the display select the machine type by pressing ENTER
  • This completes the steps necessary when your Stairmaster display reads CONFIG RQRD or NTM CONFIG RQD
Stairmaster Console Message CONFIG RQRD or NTM CONFIG RQD
Feb 26, 2014 | Stairmaster 4400 PT Stair Stepper
Corrective Action
Resets after begin
Feb 24, 2014 | Stairmaster Stepmill 7000 Pt
4400pt cuts out
It sounds like the console is either, losing power or it is suffering a glitch in the software. Please check the voltage output from the power supply. It should be at least 12V DC. Anything less and the machine will not power a workout. The following video will show you how to use a multimeter. Extech Volt Amp Meter AC DC SPORTSMITH net
Nov 07, 2013 | Stairmaster 4400 PT Stair Stepper
Belt continues to slip off
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
This video covers the installation and adjustment of the Eccentric Hub Assembly for the Stairmaster 4400PT/CL and 4600PT/CL Steppers.
The video begins with the Eccentric Hub Assembly removed from the unit. If you need help removing the Eccentric Hub Assembly from your stepper, please see our video about the Eccentric Hub Assembly Removal.
Tools Needed: Socket Wrench, 7/16" Socket, Adjustable Wrench or 7/16" Wrench
  • Begin by placing your HTD toothed belt around its pulleys. This allows you to set the proper belt tension before mounting the Eccentric Hub Assembly to the frame. The "egg" shape of the Eccentric Hub allows for adjustment of the belt tension. Rotate the hub counter clockwise to tension the belt. Proper belt tension allows about ¼" of play.
  • Line up the 4 bolts through the Eccentric Hub Assembly and the frame. Be sure to place the bolts facing the same direction as noted from removal of the old Eccentric Hub Assembly.
  • Once all the bolts are aligned, retighten them to the frame using the socket wrench with socket on one side and the other wrench on the opposite side.
  • Reinstall the poly-v alternator belt.
  • The Eccentric Hub Assembly installation and adjustment is now complete.
Stairmaster 4400 4600 Eccentric Hub Installation Adjustment
Sep 30, 2013 | Stairmaster 4400 PT Stair Stepper
Grinding stairmaster
Taken from the service manual under "mechanical troubleshooting":
"If you hear a grinding or clicking noise, or experience excessive vibration during exercise.........you probably have a problem in the drive train."
You can find more information in the following linking, beginning on page 57 of the document reader.
http://www.sportsmith.net/images/product_support%5Cstairmaster%5CManuals%5C42-44-4600PT-CL_Red-LED_Display_Freeclimber_Manual.pdf
Apr 11, 2013 | Stairmaster 4600 Cl Cordless Freeclimber
Looking for a manual for stairmaster 4600 free
Hi, I just purchased a used StairMaster 4600CL last week, and found a link for an owner's manual that covers the StairMaster FreeClimber 4200 PT, 4400 PT/CL, and 4600 PT/CL. This is a free, .pdf download:
http://gymstore.info/manuals/upload/StairMaster/stairmaster_freeclimber_4200_4400_4600pt_cl_c40_om.pdf
Vanessa
Jan 23, 2010 | Stairmaster 4600 Cl Cordless Freeclimber
I can go about five minutes on my 4400 pt/cl and then the left pedal just drops down
Replace the drive hub. You can try greasing it with a good lithium grease but probably to late.
Aug 15, 2009 | Stairmaster 4400 PT Stair Stepper
Exercise & Fitness Logo
178 people viewed this question
Top Stairmaster Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Matt Olenzek
Matt Olenzek
fordexpert
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
