Question about JBL On Stage Micro Iii 3 For Ipod Iphone Audio Dock Speaker Black
Jbl onstage micro 3 keeps turning off during opperation on mains supply
During normal operation it switches off after 10 min while on mains electricity. I understand there is a power saving function but this is not mean't to click in when music is playing. Can you help please.
4 Suggested Answers
SOURCE: JBL OnStage - faulty connection
According to the user guide the clicking sound seggests a fault with the powersupply.
Posted on Aug 21, 2007
madansakre
  • 51 Answers
SOURCE: JBL onstage
Yes it can be repaired through company workers so please contact your nearest speakers shop to be get repaired as quickly as possible...
thankyou...
Posted on Jan 04, 2008
SOURCE: Just wondering what the power supply output JBL Media 3 Speakers
I have JBL Media 3 Speakers running on the factory supplied power supply and the label states: JBL POWER SUPPLY, Model No. DV-9319B, Input: 120VAC 60Hz 35W, Output: 13.8VDC 1.7A, UL Listed3T58, E148325, CSA LR99152, Power Connection Diagram shows, Ring: Negative, Tip: Positive, CAUTION: INDOOR USE ONLY
PERSONAL NOTE: The power supply DOES NOT have the AC plug on the back. It is big hefty black block with an attached AC cord on one side and an attached DC cord on the other. My speakers are mounted high on the wall and run at approx.90% of full volume with Bass & Treble set flat. Actual volume and EQ settings are controlled via the sound card software based "Mixer Panel".
Posted on Apr 15, 2010
The sound is screeching when the volume is louder
that screeching is called feedback..which is caused by loop oscillation in plain english that means that sound is going from the speaker to the microphone and "looping" causing feedback noise or "screetching" there is nothing you can do but lower the volume it's a normal phenom not a fault in the product but more user error. sorry to say. the only thing you can do is lower the volume till it goes away.
Dec 12, 2013 | JBL On Stage Micro Speaker Dock for Apple...
I am thinking of getting and Ipod touch 3G. I have JBL on stage micro Speakers. I've charged a Ipod touch 2G, but I want a 3G! Please Help!
When the OnStage speakers first came out, the charger was not compatible with 3g iPods or iPhones. Newer speakers have an upgraded charger and will charge all current iPods/iPhones (up to and including iPhone 3Gs)
Bad news is that there's no way to upgrade an old OnStage.
You can test yours by trying an iPhone 3G (if you have a friend with one, for example) to see if you have the old or the new charging circuit.
Jan 23, 2010 | JBL On Stage Micro Speaker Dock for Apple...
E-000003-0000
During printing, the main thermistor detects less than 120°C/248°F for 1
sec or more continuously.
Main cause:
The fixing film unit is faulty (main thermistor fault, thermal fuse blow, fix-
ing heater fault).
Or the power supply PCB is faulty.
Or the DC controller PCB is faulty.
Action1.
Malfunction
Turn off the power; wait for 10 min, and turn on the power. Is the problem
corrected?
YES:End.
2.Wiring
Is the wiring from the DC controller PCB to the fixing film unit normal?
NO:Correct the wiring.
3.Fixing film unit
Try replacing the fixing film unit.
Is the problem corrected?
YES:End.
4.Power supply PCB, DC controller PCB
Try replacing the power supply PCB. Is the problem corrected?
YES:End.
NO:Replace the DC controller PCB
Nov 07, 2009 | Canon imageCLASS D320 Digital Copier
I need to open a JBL onstage II speaker system to reattach the ipod dock, i can do that, it just doesn't seem to open
you have to remove the 3 sticky pads in at the bottom of the speaker and there you will expose all the screws that need to be removed...there is also one where the batteries go
if you have any luck replacing the ipod dock let me know please
Oct 17, 2009 | JBL ONSTAGE Docking Station for iPod
JBL on stage micro will not charge my ipod any more. It plays songs fine from the ipod but for some reason is not charging it. Any suggestions?
The JBL Onstage Micro is supposed to disable recharging of the iPod when running off AAA batteries to avoid draining them, but sometimes this setting gets stuck even when the unit is plugged in through the AC adaptor. The workaround that I found is pulling out and reconnecting the iPod to the Onstage Micro (while both are powered on) and then unplugging and reconnecting the AC adaptor. Sometimes you have to repeat this process, but the iPod should start recharging after that. I tried it on the new 5th generation nano and this seems to work.
Jun 14, 2009 | JBL On Stage Micro Portable Speaker Dock...
When plugged in, the ipod batteries go low immediately.
The JBL On Stage Micro is supposed to disable recharging of the iPod when running off AAA batteries to avoid draining them, but sometimes this setting gets stuck even when the unit is plugged in through the AC adapter. The workaround that I found is pulling out and reconnecting the iPod to the Onstage Micro (while both are powered on) and then unplugging and reconnecting the AC adapter. Sometimes you have to repeat this process, but the iPod should start recharging after that. I tried this on different versions of the iPod nano and this seems to work.
Apr 16, 2009 | JBL On Stage Micro Portable Speaker Dock...
Will not charge a ipod touch 2
If you're willing to spend $40, there's an adapter available from Scosche Accessories. It comes in both black and white and they say it will convert any docking device to the new charging format. (The problem is that Apple has discontinued charging via the FireWire pin - which virtually all accessories - even including Bose - have used up to now. All the 2nd Generation stuff now uses direct USB charging, not FireWire.
Check out the convertor at:
http://scosche.com/products/sfID1/210/sfID2/339/sfID3/318/productID/1694
Dave
Dec 29, 2008 | JBL On Stage II with Remote Remote Control...
JBL On Stage Micro Iii 3 For Ipod Iphone Audio Dock Speaker Black Logo
349 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
