Question about Toshiba 65HT2U 65" Class Full HD LCD HDTV
Power Supply Issue - Green LED ON..no power up
I have a Toshiba 65ht2u. When I plug it in, the Green LED lights on, but no response when I press the power button. I checked the voltage outputs on the power supply. 5V is good but no 24V. I did this was all connectors disconnected from Psupply. Is that correct or should i be checking voltages with all boards connected? Also, is there a service manual available for this model? Thanks in advance!
  • Joe Stiene Nov 02, 2012
    Is there a schematic available somewhere that I can use to troublshoot the 24 volt circuit? I did disconnect the power inverters as well as the main board from the power supply and it is reading 0 volts on the 24V outputs on the connectors. The only voltage I am getting is the 5V.
  • francoise cleofas
    francoise cleofas Nov 03, 2012
    ok, i'll try to find diagram for that particular model so it can help you to diagnosed.
    Genius:
  • Toshiba Master
  • 2,432 Answers
Tried to disconnected the 24v supply connectors going to the power inverter board which may the cause of voltage drop. after you disconnect then if still no output 24v dc coming from the power supply board the cause will be bad power supply board. check for an open resistance or bad regulators going to the 24vdc out. by the way you should connect all the connectors going to the main board to turn on the processor and the inv_on voltage going to the inverter board.
Posted on Nov 02, 2012
    I did disconnect the inverter boards as well as the main board. The power supply was reading 0v at the24v pinouts on the connectors. I did get 5V output readings but that was it...also...is there a schematic available that I can use to troublshoot the 24volt circuit?
2 Suggested Answers
consaka
  • 661 Answers
SOURCE: I have a Toshiba 1415 S173 laptop I'm working on
I agree with micromend on the clone power supply. It sounds like perhaps the voltages aren't right or the wave form is messing up the power parts of the laptop.
I dont necessarily agree about the cmos battery but then Toshiba could be different then the ones I have used in the past. I havent tried it lately but you used to be able to run computers with no cmos battery at all. it just meant you had to redo the date and any custom bios changes at boot up. Please clarify this micromend. You cant boot a toshiba with no cmos battery?
I have a bad battery in one of my old compaqs and it still works. just have to set the date whenever I boot it up. (I been lazy to take it apart despite having piles of these batteries laying around lol)
Posted on Mar 14, 2010
Thought I should add more detail about what the laptop is doing. The laptop sat for a long time with a dead battery, because the power supply low voltage wire got chewed by one of our puppy's when it was...
from the web -
1 Removed the battery
2 Removed the AC power
3 Plugged in the AC power again
Note:- At this point the light from flashing amber light to solid green indicating AC Power
4 Plugged in the Battery
Note:- Solid green AC power light and Amber charge light
Oct 30, 2013 | Toshiba Satellite C655D-S5084 Laptop
Error 3
Perform an EEPROM reset:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
times Orange EEPROM reset
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 23, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Please tell me how to reset my i9950 printer once the ink tank has been cleaned
Try this:
  • With the printer plugged in and powered off, press and hold the "Resume/Cancel" button, then press and hold the "Power" button. Do not release the buttons. The LED will be gree.
  • While holding the "Power" button, release only the "Resume/Cancel" button.
  • While holding the "Power" button, press the "Resume/Cancel" button 2 times, and then release both the buttons.
  • When the LED light is green, press the "Resume/Cancel" button 4 times.
  • Press the "Power" button. The LED lights in green, and the reset is performed. When the operation completes, the printer returns to the menu selection mode automatically
  • Press the "Power" button to exit service mode.
Thanks, Joe
Feb 05, 2011 | Office Equipment & Supplies
Emachines model 4026. We had a short power cut. The computer went off and now will not start. At the back of the machine close to the power plug is a round green L.E.D. light. This is now constantly...
it looks like the power supply went bad, before try to do something else. I would recomend you to get you powe supply (part #) and order a new one . it is really simple to install it. the power supply is on the back of the computer where you see the green L.E.D light it is what gives power to the whole system.
follow this link and watch the video to know how to install it. http://video.about.com/pcsupport/powersupply.htm
Jan 24, 2011 | E-Machines eMachines Desktop PC
Hi Everything is plugged in and power strip is on, but the printer just won't turn on. Is is a power supply thing? Worth fixing?
If it is the power supply, not worth it....
Try an EEPROM reset:
button pressing
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 23, 2010 | Canon PIXMA MP150 All-In-One InkJet...
E 2, 7
MP150/160 resetting errors:
E2-2 No paper (ASF)
Reset the EEPROM:
button pressing
4 times Green Waste ink counter reset .
5 times Orange Destination setting .
Thanks, Joe
Dec 19, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I GET AN E 5 ERROR
button pressing
procedures below.
procedures below.
Thanks, Joe
Nov 30, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Wont print error 5100
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
Turn off printer by pressing the power button
press the Resume button and press Power button.
Keep holding down Power button and release Resume button
Press Resume button 2 times then release BOTH buttons
Green lights will flash and then stop blinking.
When green lights are solid, press the Resume button 4 times.
Press the Power button and the printer should turn off, if not, press the Power button once more.
Nov 19, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Green led mains light comes on, battery amber light rapid flash
This sounds sucky, but you may have a power-supply issue. Especially if you have had to repeatedly press the power-button. If the laptop is new, call Toshiba and see if it's under warranty. If not, find a local computer tech to test your power-supply. This problem is less common nowadays, but still an issue for some!
Hope this helps!
-- RT
Aug 26, 2009 | Toshiba Satellite Pro 4600 Notebook
Toshiba 65HT2U 65" Class Full HD LCD HDTV Logo
146 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
