Question about Carrier Heating & Cooling
Furnace stopped working.
My Furnace is not working. The blower comes on for approx. 1 minute, then shuts off. I have a Carrier 58PAV135, Furnace. I found two different buttons, that appear to be reset/pressure switch buttons, I have turned everything off, waited 30 minutes, pushed the resets (there's no click or anything significant), checked the connections, restarted, and same thing, just a fan blows and then shuts off. The LED code is 1,2 sometimes, and 3,3 other times. Please help. Thanks, Cold in Detroit.
  • Keith Miller
    Keith Miller May 11, 2010
    is the burner igniting if not is the igniter working
  • 163 Answers
HI!!! Looks like your ignitor has stop working..change your glow ignitor and you should be fine..Good luck..
Posted on Jan 04, 2009
Carrier gas furnace does not cycle right.
Check out the flame sensor see if it is clean and check the connections .
May 21, 2017 | Carrier Heating & Cooling
Have old Carrier standing pilot furnace. Furnace calls for heat, but blower does not come on for almost 1 minute. How can I make blower some on sooner??
If it has a honeywell fan control, the cover can be pulled off and the setting can be lowered by adjusting the small lever on the dial, if it is a timed control it probably has no adjustment unless it was replaced with an adjustable fan control.
Oct 30, 2011 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier furnace clicking/rattling
Hi some thing in the blower motor or combustion fan?
Feb 16, 2010 | Heating & Cooling
Carrier 58 Series Furnace Blower Motor Won't Shut Off
Yes. If the high limit is tripped, the furnace will bring on the fan continuously until the limit resets. Often, they will not reset if tripped repeatedly. If the furnace is too large for your application, you probably are not able to move enough air to keep the heat exchanger cool enough.
Oct 03, 2009 | Heating & Cooling
Need schematic for carrier furnace/ac. A butcher
There should be a schematic inside where the blower is or in the main elec. panel on unit
Oct 02, 2009 | Heating & Cooling
1994 Carrier 58 PAV
sounds like the relay for the unit may be bad, usually if a blower motor goes it stops or has a very loud humm and only goes slow
Aug 03, 2009 | Heating & Cooling
Furnace runs OK, but blower runs again a few seconds later
Could be a defective thermostat in the plenum.
When a gas furnace shuts down the fan(blower) will run until the plenum cools to the safe range. Usually 1 and 1/2 minutes.
Intermittent operation is a defective thermostat or relay.
Mar 11, 2009 | Carrier Heating & Cooling
Furnace runs but won't ignite.
Error code 12 is blower on after power up. Meaning: after you turn on power to the furnace for aprox. 60-90 seconds the blower will run. The blower should then shut down and the furnace should go through the start up process, providing that the thermostat is set for and calling for heat. If the furnace fails to start after blower shut down there should be a new fault/error code. However if the blower continues to run longer then 90 seconds and continues with the same fault code more then likely the circuit board is bad. Please let me know if this was helpful and give me a rating. Good luck.
Feb 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Furnace pilot problem
check the pilot gas pressure, might be too weak and blowing out when the blower starts, the clicking noise is the gas valve shutting down when it detecks no pilot flame, that park is normal.
Jan 10, 2009 | Honeywell Power Humidifier: Furnace...
Heating & Cooling Logo
466 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
