Question about Rowenta Irons
Have black resdue on iron...when heated smells like burnt marshmallows. How do I get it removed?
  • 673 Answers
Clean the black residue with cotton dipped in vinegar.
Posted on Nov 01, 2012
4 Suggested Answers
roadrunning1
  • 152 Answers
SOURCE: shorted out, over heated, no power my wife was
the burning smell is the element protective coating , I'm afraid you need to buy a new one sorry
Posted on May 10, 2009
heatman101
  • 43501 Answers
SOURCE: Black & Decker D2020 Iron - Burning Smell & Beeping
The iron is probably junk...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
bayyagg
  • 1672 Answers
SOURCE: Hi can you please tell me how to remove liquid
Just put lots of water in it, and let it DRIP, do that until the soap is gone in ur iRON!
Posted on Nov 29, 2010
My iron turns on but will not heat up. Prior to that it smelled very hot. Can I purchase a new cord if that is the problem?
You probably could but, I doubt if that is the problem. It sounds like something has burnt up inside of it.
Apr 10, 2016 | Irons
Why steam iron won't heat up
if there is no light or heat even when the thermostat is switched to the hottest setting then assumption is that the iron is defective.
with the iron not plugged in check the cable and see if it is worn or kinked or cut. look for any burn markings on the plug. if the iron is some years old it may also be that the element has burnt out. this happens more often in areas where water scale is high.
I hope this was useful.
May 12, 2014 | Applica Black And Decker F975 Steam Iron
Cannot get black stains off with the cleaner kit from Rowenta that I bough at Bed Bath and Beyond. Used almost all of the cream and still not clean. adjina39@aol.com
Are you heating up the soleplate first to get it really hot, then put on an oven mitt to protect your hand, squirt cream onto a folded pad of clean cotton fabric, then apply to iron sole plate, rub over stained area gently, wait, then rub off. you may want to rub the whole iron sole onto a piece of waste fabric to remove the burnt bits. Itcan take a couple of goes to clean. The ironing press cleaning sticks work well too.
Nov 03, 2013 | Rowenta Irons
The light is on to indcate there is power going to the iron but it does not heat
It sound like the heating element has burnt out. this can be replace but can be uneconomic. it may be best to buy a new iron...sorry
Oct 06, 2009 | Black & Decker AS150 Iron
Burning smell
thermal switch is not working...upon reaching a certain temperature limit it should switch off then switch on again after a moment to maintain the set temperature..what happened here is that your thermal switch didn't switch off so the temperature continue to rise to the extent that the heating element burnt and smell like that..adjust the setting in such a way that it switches off after reaching the desired temperature..
Jun 18, 2009 | Rowenta Irons
Black & Decker Iron - Steam Advantage - won't turn on
Just open your flat iron and locate the face plate contactor that has a soot burn causing the filament not to heat,use a sand paper to clean the contact from soot burnt,this the common problem of a flat iron...
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 10, 2008 | Black & Decker Steam Xpress AS250 Iron...
heatman101
May 11, 2008 | Black & Decker D2020 Iron
How I can fix The Black&Decker digital advantage that does not heat
The iron will probably have to be taken apart.
If you are handy, you can do this when unplugged.
Check for broken connections and anything that is obvious like burned smell etc.
Feb 16, 2008 | Black & Decker AS150 Iron
Irons Logo
53 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
