Epson l110 waste ink pad
I want to know if there's any free way of resetting my epson L110. I have scoured the internet without any success. Maybe since the L110 is fairly new in the market, no one has come up with a solution. Anyway,would be really great if someone could help. TIA
Hi
I want a free software to download to reset my printer and I tried in SSC Service Utility v4.30 but software don't have epson L110 model so, please help me to find right software to reset my printer. Thank you
mr.mehdihassani@yahoo.com
Posted on Jan 31, 2014
SOURCE: waste ink pad counter reset software.
Dear Sir,
My Epson R30 Photo Printer has a problem from Waste Inkpad Full massage and it's not working. I want a free software to download to reset my printer and I tried in SSC Service Utility v4.30 but software don't have R390 model so, please help me to find right software to reset my printer. Thank you.
mallajanak@yahoo.com
Posted on Jan 12, 2010
SOURCE: Need To Replace The Waste Ink Pad on my Epson Stylus C66
I modified a little what Worldvet had done. I opened the door as if to change the ink cartridges. I first used a pair of needle nosed pliers and carefully took out the sponge type pad which is along bottom of the printhead travel lane. One will see the two center plactic guides within this lane. The sponge is very delicate, so be very gentle in removing it. It has ink residue in it so use gloves if necessary and upon removal place the sponge on a paper towel folded in triplicate so the ink does not bleed through the towel. Remember to what position it was before removal, so there is no problem when you try to replace the sponge after cleaning.
The second sponge I removed as follows: With the power on, I pressed the ink cartridge removal light (red) (far left) once. This moved the print head to the "far left", before the position to change cartridges. With the power still on and the printhead to the far left, I was able to very gently (with the same needlenose Pliers) remove the sponge under where the printhead was parked. It too is very delicate and be careful not to rip it. It too, one will find, has two plastic slots on the botton which the sponge will have to be returned into. I then turned the printer off, which caused the printer head to return to the parked position.
I took both sponges, and with Alcohol (Pharmacy type), I placed the sponges in a disposable plastic bowl and filled it with the alcohol. I gently used the needle nosed pliers (Closed) as a device to gently press on the sponges which were submerged into the alcohol. I continued to alternate up and down the sponge pads, causing the alcohol to dilute and clean the pads. When the alcohol became saturated with the ink from the pads, I took the pads out of the alcohol bowl and placed the pads on a triple folded paper towel so the remaining ink would not bleed through anything.
I then took the bowl of alcohol/ink and while I flushed the toilet and the water was going down, I emptied the alcohol down the middle of the water spout as the toilet water was completing its flush. This keeps any ink from touching any porcelion.
I then refilled the plastic bowl again with fresh alcohol and resubmersed the pads, just incase there was any ink still left in them. Upon pressing on the pads and the alcohol remained clear (indicating all the ink was removed) I again used another set of paper towels, trippled, and placed the pads onto the paper towels, and squezzed them dry. I disposed of the alcohol the same as before.
I then, first replaced the large pad onto the printhead travel lane, back into the same position, being careful that the holes and slots fits back into its proper position and the edges are tucked under the proper hooks (little plastic hooks attached to the side of the travel lane).
Upon reinstallation I pressed gently on the pad to make sure it was secure.
Replacing the second pad, I again turned on the printer and pressed the ink replacement light (red), same as before, causing the printhead to travel to the far left as before. I then very carefully replaced the second pad into the slot from which it came from.
After I made sure the second pad was secure in its proper position, I pressed the ink replacement light twice, causing the printhead to return back to the parking position. I had already reset the counter, so that was not neccessary. I returned to the computer and printed a test page to make sure the printer was working properly, at which time it was, so I therefore returned to what I was doing and the Service Warning was cleared. My fingers got a little ink; but what the heck, soap will take care of that! Good for another 20,000 pages. Hope this helps, not as bad a it sounds.
Posted on Mar 26, 2009
tigertail
  • 163 Answers
SOURCE: waste ink pad saturated. EPSON STYLUS PHOTO R360
Replacing the pads is costly, messy and requires the printer to be taken completely apart. If you have little or no experience of stripping down printers it is best left to a proffessional. Contact Epson to find your nearest service centre, but remember to get a quote as it may be more economical to replace the printer. Sometimes the counter can "jump" to the end of life number, this especially happens where 3rd party or refilled inks have been used. If you believe this to be the case and there is no sign of ink leakage and the pads look fairly clean then you can just reset the counter using special software called the SSC utility. See these sites:
http://www.ssclg.com/epsone.shtml
http://inkjetprinterhelp.us/epsonSSC.html
More information about this issue and the "official" Epson resetter is available from the Epson web site, please read this link:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Please take a moment to rate this solution. Thanks.
Posted on Apr 14, 2009
pineworks
  • 4041 Answers
SOURCE: epson RX-595 ink waste pad reset....Help!!! No one
Hi there you can download this from my website.
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Download Free
Click Link = http://www.4all2sell.com/reset-tools/sscserve.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Posted on Mar 19, 2010
SOURCE: Epson R230 ink & Paper Lamp Blinking
could someone show us how to open the r230? im having hard time cleaning the waste ink pad because i cannot open the r230..
Posted on Oct 27, 2008
I need resetter for Epson L110 ink pad need to
hi my printer epson px660 displays a message that the printers ink pads are at the end of their service life what should i do
Aug 02, 2013 | Office Equipment & Supplies
Ink pad resetter for epson L110.. please help me..
The L110 needs the WICReset utility to reset the waste ink counter and a key to do that too.
I believe the WICReset tool will also reset the ink levels without needing a key so if you can source the necessary bulk ink locally you should be able to get printing again.
Aug 02, 2013 | Epson L100 Original Ink Tank System...
Free keys for wic restter epson L110
No purchase needed , just download all of them for free from their official site
http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-CX3600/Drivers-Support
Nov 26, 2012 | Compaq Computers & Internet
Instruction how to refill ink of Epson L200 and how can I input the code of the ink?
To pour the ink, follow instructions in http://goo.gl/rX6uY0 .
Then, if any code window doesn't open up, then download wicreset.exe from Free Epson Ink Reset ID Codes for L100 L200 L800 printers or watch video from Epson L100 L110 L200 L210 L300 L350 L351 L355 L550 L800 printers Ink...
Hope this helps... e-mail me at geekgeekout@gmail.com if you have any doubts or if you want to thank me...Lol!
Nov 22, 2012 | Epson Office Equipment & Supplies
How to reset l110
How to reset epson l110 printer? please help me.
Nov 07, 2012 | Epson Office Equipment & Supplies
EPSON STYLUS T13 printer's ink pads are at the end of their service life HOW TO RESET FREE
Apr 26, 2011 | Epson Printer
5,323 people viewed this question
k24674
