Question about HP Compaq ProLiant DL380 G4 Server
W2K3 O/S does see additional SAN drives
The server already has SAN drives attached and is working fine. Added additional drives to increase space but O/S does not recognize them but the drives can be seen in Powerpath. Have rebooted several times no luck
    Scholar:
  • 97 Answers
Although the system "sees" the drives, it also must have the new drives included in the RAID method you are using within the SAN system. Depending on the RAID type and controller used this can be accomplished in several ways but it should be done within your RAID manager. you are basically expanding the RAID. Then the SAN will be of the new dimensions.
CAUTION: backup first! Most RAID controllers can do this on the fly, but some will cause data loss during this operation!!!
-Good Luck
Posted on Jan 04, 2009
WONT RECOGNIZE ADDED DRIVES ADDED 2 ADDITIONAL 146
If they are SCSI drives, you must enter the SCSI configuration software during a powerup and initialize the drives. From there, you can add them to a drive array or create a new array.
Feb 18, 2011 | Dell PowerEdge 1600SC Server
Hard drive not detected. When i trying to install Win 2003 Server Std edition. It does not detect the hard drive.
you will need to download the RAID drivers from the Dell website
http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R74082&SystemID=PWE_PNT_P3C_2450&os=WNT5&osl=en&deviceid=1374&devlib=0&typecnt=5&vercnt=7&formatcnt=2&fileid=126163 and load them onto a floppy drive.
Then when installing the server press F6 to install other drivers this will load the PEC drivers and W2k3 will then see your drives
Do not try to load the drivers from a USB as W2k3 is "preset" to only accept drivers from a floppy drive unlike WIndows server 2008
Hope this helps
Jul 22, 2010 | Dell PowerEdge 2650 Server
Can i add 142GB of hard disk on Dell PE 2600 motherboard
You can always add more storage to a server, as long as you have enough internal connectors in the server. You can also purchase another scsi or sata backplane to add more ports if you're out of internal connectors.
You may also want to look into a SAN or NAS device to offload some of your not too frequently used data. Many SAN devices give incredible performance with pretty good scalability.
Steven
Sep 16, 2008 | Dell PowerEdge 2600 Server
Cant create additional raid
if there is a limit this would have been mentioned in the features of the product
please have a check
Aug 01, 2008 | IBM xSeries 226 Server
Power light flash
check the firmware you are upgrading to is supported for the hardware model yoiu are using.
Jul 25, 2008 | Dell PowerEdge 2450 Server
Pixma ip 5200 r -> CD Labeler Problem
After long research .... I found out that the pixma is indeed a network printer ;) .... BUT it has a printserver already build in!!!! Having 2 Servers is obviously not too good of an idea ;) ....still wonders me as to why it did work in the 1st place ..... (i guess there was something wrong with the w2k3 print server *muhaahha)
May 07, 2008 | Canon PIXMA iP5200R InkJet Photo Printer
Server doesnt boot
First create a floppy disk with your RAID driver for W2K3 Server. Next boot the server with the W2K3 Server CD, and hit F6 when prompted, and S to add the specific driver for your RAID and using the floppy to get the driver installed.
Next boot to the recovery console of W2K3 Server. If it finds your hard disk, it will even ask for your Administrator's Password to continue. If this works, then you are probably home free.
Get to the command line of the W2K3 Server Repair console and perform some directory searches to see if the data is there and intact. You can also perform a CHKDSK from that console.
Once you have made sure your data is there and intact, type these two commands: FIXMBR and FIXBOOT
This should solve the problem and when you EXIT out of the console, it should reboot. Remove the CD and it "should" re-boot from the hard disk.
If you still have problems, let me know with how far you got with the steps above. I have another solution but need to know your RAID controller's model (ServeRAID 5i, 6i, etc).
-Chip
Apr 02, 2008 | IBM xSeries 346 Server
Lack of space on C drive
You can relocate any my documents folders to the D:\ drive using a right mouse click and properties to enter a new directory. When you are logged onto the appropriate account.
If you have items on the desktop (data) you can relocate them to a folder on the D:\ drive and place a shortcut to them on the desktop -- same functionality but the disk usage changes drives.
You can uninstall specific applications and reinstall them on the D:\ drive
You may be able to reassign the temporary internet folders depending on the version of Internet Explorer to the D:\ drive to reduce use of C:\ Likewise Temp if you change the JCW value.
If you are using older versions of Internet Explorer that have been updated you may be able to remove backups using the add/remove programs scenario -- do not backoff current versions there are buttons in some versions of IE to remove the backups created when updating.
Using add/remove programs to eliminate items not used. If this is a true server -- items like calculator and numerous accessories could be removed. There may be additional unused programs and services that can be removed to buy some additional space.
Anti-Virus software often keeps backup copies of signature files -- reviewing your software in that area could provide additional files that could safely be removed.
I do not know if windows 2000 had the indexing service. If it does is maintains a second directory and space of the search service is not required eliminating the associated data can reduce C:\ drive space requirements -- if necessary the associated files can be relocated to the D:\ drive.
In the end all of the above may not be much space but it could be some.
Jan 02, 2008 | Dell PowerEdge 2500 Server
Problem with new array.
Do you see your new disk in the "Disk Management" window? To get there go to "run", type "compmgmt.msc", then click disk management. If you do see the disks there, then you need to format the disk to a "basic" configuration. If your new disk/volume does not show up there, I would suggest a hard reset on your server whenever possible. I see this issue at times with Windows and newly added storage array logical drives.
Aug 31, 2007 | IBM Total Storage DS400 (13n1777) Fibre...
HP Compaq ProLiant DL380 G4 Server Logo
103 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
