Question about Dryers
Dryer will not heat
Our 16 month old dryer has stopped heating. Model is WED5900B0, Serial # is Mu2001756, Type is DWSRELE 2406026 RSDU. Since it just the two of us and I average less than 3 loads a week, what the heck could be wrong? I have tried evach setting seperately, and re-set the breakers between.
    President:
  • 2,692 Answers
The breakers trip out?A shorted heating element or plug.
Posted on Jan 04, 2009
MY DRYER SERIAL NUMBER X073808040 STOPS AFTER 20 MINUTES
Kenmore Dryer - heats & runs but stops mid-cycle - Ask Me Help Desk
https://www.askmehelpdesk.com/.../kenmore-dryer-heats-runs-but-stops-...
Kenmore Dryer - heats & runs but stops mid-cycle. Asked Aug 30, 2006, 12:25 PM - 10 Answers .... Unfortunately it shuts off after a few minutes, I'll estimate about 5.After waiting about 30 minutes, ... New Member. Jun 16, 2010, 09:20 AM ...
Sep 15, 2015 | Dryers
Whirlpool admiral clothes dryer won't turn on. It's approx 8-9yrs old & in good condition. The Model number AED4475TQ1 Serial number MY1739210 Type DWJR-ELE-2406026-FM54
Check breaker in breaker box (30 amp). Check door switch plunger on door, check door switch. Check dryer plug in to outlet.
Sep 06, 2015 | Whirlpool Dryers
I have a whilpool electric dryer type d433-2406026-fm54 this dryer doesn,t heat anymore but the dryer still runs.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101,,.';'
Aug 02, 2011 | Dryers
I have a maytag dryer (dwsr-ele-2406026-fm54) and all of a sudden it will not heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 16, 2010 | Dryers
I have a maytag electric dryer and it will not heat and dry clothes. The type number is DWSR-ELE-2406026-CV54. Mod # MED5800TWO SER - MV4920498 The owners manual does not have any trouble shooting...
heatman101
Nov 21, 2010 | Maytag Dryers
Dryer runs...timer wont rotate and wont heat up
Good day,
Timer woun't run if there is n heat.
1. Check to see you are getting 230 volts to the machine. The motor uses only 115 so is not a good indication.
2. Remove back cover. You will need an ohm meter to test the components.
A. In the center bottom is a skinny white bakelite device held on with one screw. Remove one wire and check. It should check zero ohms. If not replace.
B. On the bottom right is a canister with the heating element terminals sticking out. They should test at 30 or less ohms. If not replace the heating element.
C. There are about 3 other limit thermostats in the area you're working. They should all check at zero ohms. Replace as needed.
Below is a tutorial on changing a heating element.
http://www.applianceaid.com/wp_element.html
Mar 02, 2010 | Whirlpool Dryers
My Fisher Paykel dryer runs as normal just doesnt put out any heat.
Usually when an electric dryer runs but stops heating, the heating element has failed and needs replacing. I don't know if you are a do-it-yourself type, but you can get the model/make/serial information and obtain the correct element at your appliance parts store.
I hope this helps... Good luck.
Oct 23, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Doesn't heat to dry clothes.
i have the same problem and am looking for a solution too so i will write back and let you know
Mar 27, 2009 | KitchenAid Dryers
Dryers Logo
Top Dryers Experts
Richard Roth
Richard Roth
