Question about Magic Computers & Internet
MGT6012YB-A25 12V 0.26AMP
Wiring new A/C
you should not have to run a double wire to the thermostat and the power supply. you should be able to come from the power supply and wire the supply and then the other to the t-stat but do get a second opinion. watch the color coded wires though manufacturers changed them to confuse the d i y er
Dec 24, 2014 | Dometic Heating & Cooling
STEREO ETC STAYS ON EVEN AFTER TURNING IT OFF AND REMOVING THE KEY
It sounds like you have a constant 12V power supply wired to the radio instead of a switched 12V. If you've recently installed a new radio, check your wires again. There should be a 12V constant and a 12V switched. The switched 12V will turn the radio off, while the constant 12V is for keeping the clock and radio memory working.
Nov 07, 2014 | Honda Cars & Trucks
Linksys wrt54g manual
Power specification depends on the Hardware version
WRT54G 5V 2A
WRT54G V1.1 12V 1A
WRT54G V2 12V 1A
WRT54G V2.2 12V 1A
WRT54G V3 12V 1A
WRT54G V3.1 12V 1A
WRT54G V4 12V 1A
WRT54G V5 12V 0.5A
WRT54G V6 12V 0.5A
Nov 28, 2013 | Computers & Internet
I have a blackberry 8520 and i want to reset my blackberry username
Power specification depends on the Hardware version of router
WRT54G 5V 2A
WRT54G V1.1 12V 1A
WRT54G V2 12V 1A
WRT54G V2.2 12V 1A
WRT54G V3 12V 1A
WRT54G V3.1 12V 1A
WRT54G V4 12V 1A
WRT54G V5 12V 0.5A
WRT54G V6 12V 0.5A
Is a minn kota mag 36 just 12V or 12V -24V run
I believe the Mag 36 is a 12v and the Mag 40 is a 24v......Ive been doin a little research and cant find anything that points to a 12 and 24v system.....
Jan 19, 2010 | Minn Kota Endura 30 Freshwater Transom...
Linksys whireless 2.4ghz model wrt54g
WRT54G 5V 2A
WRT54G V1.1 12V 1A
WRT54G V2 12V 1A
WRT54G V2.2 12V 1A
WRT54G V3 12V 1A
WRT54G V3.1 12V 1A
Nov 11, 2009 | Computers & Internet
Computers & Internet Logo
Top Magic Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Computer Links
ctlimey
Level 1 Expert
Are you a Magic Computer and Internet Expert? Answer questions, earn points and help others
