Question about HP Hewlett Packard J4899B New ProCurve 2650 50-Port Switch
Default password for HP procurve j4899a
Looking for default password for router HP procurve j4899a
  • 345 Answers
This link should tell you the answer. http://h30499.www3.hp.com/t5/Switches-Hubs-Modems-Legacy-ITRC/Clear-password-in-Procurve-2650/td-p/4598369#.U0sRNfldUok
Posted on Apr 13, 2014
4 Suggested Answers
  • 8 Answers
SOURCE: does HP ProCurve 1800-24G 24 Port Switch can act
The Procurve 1800 SWITCH series supports 802.1p, 802.1q VLANS, 802.3ad LACP, 802.3x Flow control, RFC1534 DHCP/BOOTP interoperation, the Cisco 2800 series is a ROUTER and dependant on its IOS version will support a multitude of routing/security features that the Procurve just isnt designed to do.
Posted on Mar 18, 2009
SOURCE: I want reset the factory
To reset using the CLI, run the command "erase startup-config". When prompted, say yes to reboot and that will restore the procurve switch back to factory settings after it starts up.
Posted on Mar 08, 2011
  • 378 Answers
SOURCE: I need the default password
There isn't one. If someone has added a password to the switch you can connect to it and at the prompt to enter the password, press the Clear button.
Posted on Apr 25, 2011
Default password j4868a
The switch ships from the factory with no default username and password. If someone set it and you do not know it then you'll have to reset the switch to it's factory default configuration. There is a reset switch on the back of the unit and when pressed/held in a certain sequence the switch will reset. You'll need to look up the proper procedure in the user's guide of the switch.
Mar 07, 2014 | HP ProCurve 2124 (J4868A#ABA) 24x10/100...
Default password
there is no default password on an HP switch. You can clear the password on a switch by powering on a switch and make sure it is done booting (you should see all the port light up for a short time in order down the switch when it is booted) then take a paper clip and press the clear button on the front of the switch. that will clear any password left on the switch
Feb 15, 2014 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
Default password
HP ProCurve Switch 2600 Series Installation and Getting Started Guide
Page 1-9
ftp://ftp.hp.com/pub/networking/software/59908821-0904.pdf
Clear Button
This button is used for these purposes:
Deleting Passwords - When pressed by itself for at least one second, the button deletes any switch console access passwords that you may have configured. Use this feature if you have misplaced the password and need console access.
Jan 03, 2014 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
Procurve 2626 default password
There is no default password. If a password is set you either need to know it or have physical access to the switch
Dec 19, 2013 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
Default ip procurve 2510 48
there is no default ip address on a procurve switch. you have to put an IP address on the switch. You can find a manual for your switch at http://www.hp.com
Oct 12, 2013 | HP procurve switch 2510-48
I am a tech at a private university. I need to access a procurve j8698a switch installed by a previous tech. I need a default password to access.
tRY THIS DEFAULT LIST OF BACKDOOR PASSWORD FROM MANUFACTURERS. HOPE IT HELPS. RATE ME IF IT DOES PLEASE. THERE ARE OTHER LISTS JUST GOOGLE MANUFACTUERER, ADMIN, OR DEFAULT ROUTER PASSWORD LISTS.
GOOD LUCK
http://www.irintech.com/x1/blogarchive.php?id=764
Oct 21, 2010 | Computers & Internet
Hi,this is pavan i want to b configure the HP procurve 2626 J4900B managed switch pls help me through anybody by giving the programme to configure it
What do you need it configured to support? Multiple subnets? VoIP support?
Here's an example to support 2 subnets, VLAN 1 Data and VLAN 2 Voice. This switch is the VLAN router for the site and it is also the default gateway for all the devices on the network.
show running-config
Running configuration:
; J4899A Configuration Editor; Created on release #H.10.50
hostname "HP 2650 dot 11 layer 3"
snmp-server contact "Your contact info here"
snmp-server location "Server Rack - Upper Switch"
time timezone -5
time daylight-time-rule Continental-US-and-Canada
interface 49
name "Uplink to HP2650 port 49 - 192.168.105.12"
flow-control
exit
interface 50
name "Uplink to HP2650 port 49 - 192.168.105.13"
flow-control
exit
ip routing
timesync sntp
snmp-server community "public" Unrestricted
vlan 1
name "Data"
untagged 1-46
ip address 192.168.105.11 255.255.255.0
ip helper-address 10.50.3.2
tagged 49-50
no untagged 47-48
exit
vlan 2
name "Voice"
untagged 47-48
ip address 10.50.3.11 255.255.255.0
tagged 1-46,49-50
exit
ip route 0.0.0.0 0.0.0.0 192.168.105.1
spanning-tree Always turn on Spanning Tree
spanning-tree priority 0 This switch is the master Spanning Tree operator.
password manager
password operator
Sep 20, 2010 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
I need the default password for ProCurve J4900B
Sep 09, 2010 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
Locked out of HP Procurve 2650 switch
If you have forgotten the switch's IP address or administration password you can return the switch to its factory default state by following these steps:
  1. Remove the power cord from the back of the switch.
  2. Connect port 1 to port 2 on the front panel, using a standard network cable.
  3. Reconnect the power cord to the rear of the switch.
  4. Wait at least 40 seconds before disconnecting port 1 from port 2.
After completing this procedure, the password will be empty, the network address will be returned to the default 192.168.2.10, and all configuration settings will be returned to the original factory defaults. NOTE: Since this process creates a temporary loopback condition on the switch, it is recommended that you remove the switch from a production environment until the process is complete.
Jan 15, 2009 | HP ProCurve 2650 (J4899A#ACC) 48x10/100...
HP Hewlett Packard J4899B New ProCurve 2650 50-Port Switch Logo
1,610 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
