I have a 40" screen colby flat screen, I'm having problems with my monitor coming back on???? I've tried leaving it unplugged for two days but when I plug the monitor up, don't nothing com
    Genius:
  • 2,432 Answers
If the power indicator goes light green then turn to red, you must check the power supply board. look for a bulging capacitors.http://en.wikipedia.org/wiki/Capacitor_plague.a panasonic brand capacitors with low esr is a good replacement just look for the ratings and value must be the same when replacing. then make it sure check the polarity the positive and the negative. just let me know if you need further assistance good luck
Posted on Nov 02, 2012
SOURCE: monitor shuts off but green light stays on
I know that this is going to sound crazy because it sounded crazy to me...but my monitor was doing the exact same thing and it was really getting to me, so I came up with an idea...somewhere in my brain I decided that turning down the brightness would help...so I turned the brightness down to about 57, and I have not had a problem since. I know all of these problems were posted a long time ago...but I hope that this helps someone out and saves them some money. I have a Dell LCD monitor and it fixed the problem right away.
Posted on Apr 29, 2007
kjanx
  • 194 Answers
SOURCE: AOC LM729 17" LCD Monitor
the inverter needs to be replaced
not real hard, but must have some knowledge of the process
Posted on Feb 02, 2008
skotkolr
  • 558 Answers
SOURCE: dell 17'' flat panel monitor power light is blinking
some transistors on the board have shorted they supply power to the inverter to run the lamps, they power is not cut off intermittently and the protection circuit has stopped the monitor. the fix is here
http://josepino.com/other_projects/?howto-repair-dell
goo dluck if you want it fixed for you let me know
Posted on Mar 22, 2009
  • 1684 Answers
SOURCE: Dell Monitor Problems
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 17, 2009
  • 1684 Answers
SOURCE: I have a Samsung Syncmaster 2493HM monitor. The
Your power supply is going out. LCD monitors have a common issue. The heat buildup in the in the cases cause parts called capacitors to overheat and bulge. When they bulge out the don't operate properly and cause the power supply to not start up correctly or not at all. First thing check the warranty, Most Samsung units have a 3year parts and labor warranty. If it is out of warranty then repair it yourself. If you can solder then you should be able to do the repair yourself. Check out our web site at:
www.ccl-la.com We don't have your exact monitor but you should be able to look at other Samsung guide we have posted and see the parts that need to be replaced. Open your case and replace any capacitors that are bulging and you should be back going again. If you don't want to do the repair yourself we do offer a repair service for you unit, check our site for details.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jan 03, 2010
I have a Sony Bravia LCD tv an it won't turn on at all the standby light is not even there I've tried turning on an off and leaving unplugged for an hour still nothing.? Help,
You either have a problem with your power supply board or main board. I would start with having the power supply fuse checked as well as the power supply board!
Jan 26, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Coby 40" Wont turn on
I'd add something to this. We had the same issue with a 40" coby. We'd declared it dead and after a few days turned it on again to show the problem before trashing it. The TV came on. We've since learned that there seems to be a HDMI handshake issue related to this tv. If you turn it off with HDMI devices still sending a signal, it will periodically return to this point, and take a day before it will turn back on (I guess until the caps are fully drained.) If you turn the TV off first and then devices however, this never seems to happen. Dunno if this is the same for others, but I'm curious
May 17, 2012 | Coby 40 TFTV4028 LCD TV
Steady yellow light
To reboot unplug the unit for 30 minutes. then plug back in. This may fix the problem, and try this link for troubleshooting PDF.http://homeappliance.manualsonline.com/manuals/mfg/bionaire/127176.html...
Apr 20, 2017 | Holmes Products BH3955-U Bionaire Utility...
Hp f2105 black screen after 2 sec on?
You've asked this question in two places. This is confusing--try to ask it in one place only.
I answered it in your other request.
Nov 20, 2011 | Rosewill R700J 17" Flat Panel LCD Monitor
I was using the tv as a monitor on a laptop. When I restared the laptop, the tv screen showed multiple imagmes on top of one another. When I turned off the tv, it would not show a power light and will not...
I've got a Polaroid TV and have had nothing but issues with it. Try unplugging it and leaving it for 10 seconds then plug it back in.
You might also have pressed the PIP/POP (Picture in Picture / Picture on Picture)button, which basically tells the TV to display one input on top of another. I could have the name of the button wrong but it's something similar. If you get it to power up again, try hitting that button till it looks "normal" again.
Thanks
Moza805
Aug 30, 2011 | Polaroid TLA-01911C TV
I have a small magnavox HDTV. I unplugged it to watch it in another room. The next day when I moved it back into the living room I turned it on. Every time I try changing the channel it changes the source...
Is it a multi-function remote? If it is, make sure you've punched the TV button before using it. Also, make sure none of the buttons on the remote or the TV have accidentally been pushed down and are stuck.
Jul 05, 2011 | Philips Televison & Video
Hi I have a samsung syncMaster 920N The screen has suddenly gone blank - the power light is showing. I have a second identical monitor and have swapped cables but no difference Is it a repairable fault?...
This happened to me a few months back. I removed all cables and left it for 2 days. Switched back on on it worked fine. That is until yesterday when half the screen went black. I found that my driver was out of date. I have undated the driver but have decided to leave it off and unplugged for another day.
You could try this. You say you have another monitor, i would suggest using it for a few days and the try the old one again.
Dec 05, 2009 | Samsung SyncMaster 920N 19" LCD Flat Panel...
Tv screen has got 2 green spots
your monitor has came in contact with some magnetic material remove all the things containing magnetsfrom around it and leave monitor unplugged for 1 day and then start it will work fine
pls rate my suggestion
thankyou for using fixya
have a nice day
Feb 20, 2009 | IBM G 40 Monitor
TOSHIBA FLAT SCREEN TV has black screen but power light is on!?
Try resetting the TV by leaving it unplugged for an hour.
Plug it back in and check to see if it works normally.
If that doesn't work, rule out the Directv box by pressing the reset button near the access card. The box could be putting out a signal that doesn't have video or audio.
If everything fails, have the tech man come back to check everything that he did before you use the warranty on the TV.
Feb 20, 2009 | Toshiba 40RV525U 40 in. LCD TV
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
