Question about Brother Office Equipment & Supplies
Change the ink cartridge and still will not clean
  • mjamir58 Nov 01, 2012
    people might be more helpful if you post the model of your printer.
  • Brother Master
  • 32,281 Answers
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Posted on Nov 02, 2012
2 Suggested Answers
SOURCE: Need to change dried old ink cartridge before it says it is out
While the printer is on, press and hold the paper feed button. The ink cartridges move into the replacement position.
Also useful to make sure you use every last drop of ink in a cartridge (the software lies!).
Posted on Jul 25, 2008
How to reset ink level canon iP 2772??
Download and run the ipTool to reset your ink level :
http://www.mediafire.com/?nmj5nnzzjaw
Features IP Tool software:
  • Showing all info on the printer such as ink level, ink counter number of cleaning, cartridge replacement and more.
  • Print test feature to test nozzle on the cartridge.
  • Cleaning and deep cleaning feature to clean head cartridge and cleaning the rollers.
  • Changing the delay value for drying.
  • Set the printer model manually.
  • Reading and reset EEPROM printer.
  • Reset counter and reset ink level on the color and black cartridges.
Ink Level - shows the level ink:
  • BK - black cartridge.
  • CY - Cyan cartridge.
  • MG - Magenta cartridge.
  • YL - Yellow cartridge.
  • WM - Waste ink counter status.
  • WP - "additional" waste ink counter status.
Port Name - displays the port where the printer installed.
Port S / N - shows the serial number of the printer port.
Power - shows the number of:
  • ON - inclusions printer.
  • OFF - to turn off the printer.
Cartridge Info - Displays information status of:
  • CL - colored cartridge.
Head Parking - displays the number of parking.
Head Cleaning - shows the number how many time the cartridge cleaned.
Head Deep Cleaning - displays the number of deep cleaning Printer cartridge.
Cartridge Replacement - shows the number of cartridge replacements:
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 20, 2010 | Office Equipment & Supplies
Brother 1840c -problems after changing cartridges
If you are using new cartridges, the problem is in the sensors. The ink sensors get dirty and malfunction. Remove the ink cartridges and thoroughly clean all the surfaces, Allow to completely dry and replace the cartridges. This should cure your problem.
p.s. I usually use alcohol on a Q-Tip to clean
Jul 02, 2009 | Brother IntelliFAX 1840C Plain Paper...
HP deskjet 920C replaced both ink cartridges and now it prints in
When we see high page volume in these printers, the cleaning ink resorvor needs to be cleaned. It may be even to teh point of stopping the head cleaning carriage from functioning.
It sounds like it is not priming and wiping the head of the cartridges correctly.
You can also try setting the head of the cartridge on a damp warm (water wet) paper towel. If there is ink coming out onto the paper towel you know it is the printer not the cartridge. If you are not seeing any color then I would change the cartridges again.
May 12, 2009 | HP DeskJet 920c InkJet Printer
Ink well cleaners
There is a design reason why the print heads are changed when you change an ink cartridge is changed. The print head isn't made to be reused and the quality of your print will suffer at some point if you reuse the same print head 6 or 7 times. I would get new cartridges and be happy with the print quality that a new cartridges will bring.
Nov 10, 2008 | Brother MFC-5860CN InkJet Printer
HP 1610, Remove Cartridge message
also replace the colour cartridge as it is not showing but the printer is not able to detect that cartridge also.many a times it solves the problem.
Sep 30, 2008 | HP PSC 1610v All-in-One Printer
Changing ink cartridge
Here is how to get the ink cartridges to move to the changing position on the R320.
1. Press the paper jam/ink button on the printer control panel.
2. A menu comes up. 1st item is ink cartridge replacement. Press
OK button.
3. Another menu with ink cartridge replacement. Press OK button.
4. Thats it, ink cartridges move to the changing position. Change your cartridge as you normally would and follow prompts on screen to finish process.
Hope this helps.
Aug 05, 2008 | Epson Stylus Photo R320 InkJet Printer
I have changed the black ink cartridge and my lexmark 125 keeps telling me to change the black ink cartridgeand I can not get the thing to copy for me. All it does is keep telling to change the black...
After you get the carriage centered to remove the ink, power off the printer. If you replaced the cartridge with a new cartridge check cartridge for tape residual that might be covering the copper contacts. ( you may not be able to see this).
If you use a refill kit. Most printer Mfg's insert a chip in all there ink cartridges. This chip tracks when you remove an empty cartridge through the printer software. So it knows you replaced the same cartridge forcing you to buy another.
You can also clean the copper ink cartridge contacts with some alcohol & cotton swabs. (Careful not to drip excessive alcohol onto the bottom of the cartridge). Clean the carriage contacts as well. Re-place the cartridge & try again.
Luck!
Mike
Apr 11, 2008 | Office Equipment & Supplies
Hi I have just inserted a new HP ink cartridge 94 into my HP PSC 2350, as the ink was running low. I was printing photos, which keept printing with a red line throughout the picture. After inserting the...
Try opening the printer properties and cleaning the print heads (should probably be done each time a cartridge is changed), it uses some ink up but should clean the build up from running the previous cartridge dry and hopefully solve your printing problem.
Good luck.
Mar 29, 2008 | Computers & Internet
Won't stop cleaning and using up all ink in cartridg
I found a solution at another forum. I have the same printer with the same problem. What you need to do is put some electrical tape on the colour cartridges to stop the printer from sensing the ink level. I put tape on the clear plastic ridge on the back end of the cartridge and this allowed me to print from the black ink cartridge even though the colour ones were empty. I used black tape which i think would work best.
I am also going to leave the printer off until i need it so that it doesn't waste the ink by doing random cleaning at all times of the day.
Feb 01, 2008 | Brother MFC 210C All-In-One InkJet Printer
12 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
