Question about Western Digital My Book Essential Edition 750GB External USB 2.0 Hard Drive
My Book light is off
I just purchased a My Book 750, I plugged it in, the light was on for a while but I wasn't able to see the drive in "my computer", now the light is off, nothing seems to work. Any tips?
    Sergeant:
  • 369 Answers
PLEASE CHECK YOUR POWER CORD IF CONNECTED PROPERLY ,NEXT TRY TO REMOVE THE POER PORT FROM YOUR HDD AND REPLACE IT BACK IT SHOULD WORK ONCE UU U HERE THE SOUND OF YOUR HARD DISK SPINNING TRY TO COONECT THE USB CABLE TO THE HDD AND THEN TO THE SYSTEM IT SHOULD WORK..
PLEASE LET ME KNOW
THANKS AND REGARDS
GOOD LUCK
Posted on Jan 04, 2009
We purchase western digital 500 gb hdd when pc is
The blinking of the lights is just the indication that data is being accessed.
Mar 19, 2010 | Western Digital My Book Essential Edition...
I just purchased a My Book 3.0 IT DOES NOT START UP
I found my MyBook didn't work on my Dell laptop. I had to plug it into my desktop and format it before it would work on my laptop.
Is there any way you can try connecting your MyBook to a different computer? See if you can format it on a different device and then try your laptop again.
Feb 19, 2010 | Western Digital My Book Essential 1TB...
I am looking for a 2002 GSX750 wiring diagram ?
Google it ( 2002 suzuki gsx-r 750 specs. ) it works
Aug 14, 2009 | 2002 Suzuki GSX-R 750
WD Mybook I TB hard drive won't power up
It could be the power adapter but you'll need to verify that the wall outlet or power strip you have it plugged into actually has power. If it's a power strip make sure that it is turned on and has power and also plug the adapter into a different outlet on the strip as individual outlets can go bad or have a bad connection.
Jul 31, 2009 | Western Digital My Book Essential Edition...
How often do the valves need doing on this model?
Brent, valves don't need to be reseated unless they are worn, that will vary by mileage and use or abuse of the machine. I strongly suggest the purchase of a compression guage and start a log book, check compression of each cylinder at least every six months. Track the values in a log book, do it both 'dry' nothing injected into the cylinder and 'wet' a small squirt of light oil in the hole prior to attaching the guage. Do this with all plugs removed to prevent the engine from starting. Also while your in to the motor checking valve clearance will indicate wear over time. Depends on the make and model on how to adjust that clearance if at all.
Jul 23, 2009 | 2002 Ducati 750 SS
How do I get started???
Hi firewolf708,
You’re going to love your WD 750! The way WD set up your drive is like a spare hard drive. To access it you will click on My Computer, and you'll see your C:\\(local Drive) and your WD 750 might be called X:\\(My Book) . (X = new letter of drive possible E: or F: and so on) All you have to do is click on that My Book drive and you have one very large folder to start copying and pasting into. It's just that simple. A good plan for navigating to it on a continuous method is, when your are at the My Computer screen that shows you both your C:\\ drive and your X:\\ drive right click the X:\\ drive and mouse over Create a Shortcut. Once the system creates the shortcut you receive a message that it can't create a shortcut in that area, but it can create one and send it to your desktop. You want to click on yes, and when you go back to your desktop, you'll find a easy icon that you can click to access that drive with a few clicks.
Have Fun!
Mark
Dec 31, 2008 | Western Digital My Book Essential Edition...
Happy New Year. I just purchased a Western Digital My Book Essential 750 GB/GO - my computer recognizes it however I do not know how to use it. How do I store items such as pictures or documents in it???...
One method:
START - MY COMPUTER It should now be listed  Open drive. copy file desiring to save, paste into drive.   another method : working on file. Save as (change drive name to ethe new installed drive.
External Hard drive 750 gb does not meet the storage capacity as describe
Hi scotti0619,
The answer to this question is spelled out by the manufacturer, Western Digital, at http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=615&p_created=1034613413&p_sid=coT55l9j&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MzEsMzEmcF9wcm9kcz0yMjgsMjA5LDIyMiZwX2NhdHM9JnBfcHY9My4yMjImcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9mbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1mb3JtYXR0ZWQgY2FwYWNpdHk*&p_li=&p_topview=1.
The capacity you are seeing is alcuatlly measured in a binary (base 2) system rather than the simplistic base 10 system of 1 GB = 1,000,000,000 bytes. In binary measurement, 1 GB = 1,073,724,841 bytes. Thus, 750 GB in base 10 = 698.47 GB in base 2. You are likely getting the full capacity from your drive, but it is simply being looked at on a different scale.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 21, 2008 | Western Digital My Book Essential Edition...
My Book not being recognized
try downloading updated software from western digital, install then connect!
May 12, 2008 | Western Digital My Book Essential Edition...
Western Digital My Book Essential Edition 750GB External USB 2.0 Hard Drive Logo
133 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
