Question about Maytag Washing Machines
Washing machine leaking
Model ALW880QAW has leak when water is in machine-is it the drain pipe & how can I tell?
  • Kim Lausman-Diedrich
    Kim Lausman-Diedrich Feb 08, 2013
    I used a putty knife to open the top springs and take off the front panel to check the drain hose for holes (not pipe as above) the pump and if neither of those look at the seal and bearings under the tub however I cannot get the spring to let go so I can lift the panel off or lift up the top of the machine casin I think you call it. Does anyone know how to get the spring to release?
    Kim Lausman-Diedrich Mar 05, 2013
    I did just that and it only leaks when it is spinning out. I cannot see the hose from the front of the machine however I do think it can be repaired. Thank-you Richard for responding.
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Remove the bottom kick plate, then the upper plate and run the machine to find the leak.
Posted on Nov 02, 2012
    The kick plate is held in with some hex nuts or some kind of screw that I don't have a tool for. I was told there are springs on top inside that I should use a putty knife to get inside to release a spring which allows me to remove the washing machine outside metal and see the mechanical parts to inspect what the problem is. The problem is the spring is not releasing. Do you have a suggestion?
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
  • 8 Answers
SOURCE: washing machine leaking
pump seals worn or possible obstruction - remove pump and check for wear and rep[lace .
Posted on Oct 25, 2007
SOURCE: Water Leaks from beneath my washing machine
Our WM2077CW just started the water leaking from underneath. We unplugged the electrical cord and disconnected the hoses (water, drain). We then removed the inspection plate from the back and checked for wet hoses. The big black hose on the bottom was a little wet. On careful examination we found a small hole that looked like a material fatigue failure at the point where the accordion part of the hose met with the solid part of the hose near the main drum connection. I suspect this is may occur in other LG washers of the same design. Unless your floor is perfectly level it's hard to tell whether coming from the left or right side really indicates where underneath the water is coming from.
Posted on Dec 05, 2007
ngafm
  • 166 Answers
SOURCE: washing machine leaking at the connection to water pipe.
Hi vks1,
Your water is coming out into the washer even when you water supply is switched off at the pipe?
Disconnect the washer hose from the water pipe and see if the water still comes out of the water pipe even when the water valve is shut off!
If the answer is YES!
This is a plumbing malfunction.
The valve on your water pipe is not closing completely!
There is a washer in the water valve attached to the end of the valve stem that more than likely needs replacement.
And not a washer malfunction.
If I understand your explanation correctly this is the cause.
If this is not the problem then the washer has a water inlet that is stuck open.
But this dose not make sense if the external water valve is shut off there should not be water reaching the washer inlet faulty or not!
I believe I figured out the problem for you and you will be fine when the valve is fixed or the valve stem replaced!
Bless You,
ngafm
Let me know that you have succeeded!
Happy to of helped you.
Please give me a good rating before you sign off our site!
Thank You
Posted on Sep 10, 2008
  • 215 Answers
SOURCE: water coming out of drawer & door
Hi Gary,It sounds to me that you have a blockage within the pressure systemas this is a classic sign. If you take the top off the machine you will see a round switch with a few wires going to it.This is the pressure switch. at the bottom of this switch is a thin pipe,normally black or clear. there is a small spring clip holding this pipe to the switch, If you remove this pipe and gently blow down it you will probably find it is blocked. You will then need to follow this pipe to the bottom of your machine. At the bottom of the machine where this pipe is fitted you will see there is a chamber and it is this chamber likly to be blocked.Some times you may clear this with a small piece of wire by removing the small pipe and poke wire through, but best way is to see how this chamber is removed and remove it for cleaning.Ensure machine is off at mains. this chamber fills with water and causes air pressure within the switch at the top of machine, which in turn tells programe when machine is full and also when empty. If this fails then machine will not turn off water supply as long as it is on. there fore when you reconnect parts ensure they are tight and clips back in place. Good luck and hope this works. Failing this working you may need to call an engineer to check switch and possible fault on board.
Posted on Feb 13, 2010
Replaced drain pump, still leaks water
Is the door seal the issue here, it is a common source of leaking water.
Jun 09, 2016 | Fisher and Paykel Washing Machines
Washing machine lots of water from under washing machine
Possible drain pump leak, door seal leak, pipe break, inlet pipe leak.
Aug 28, 2014 | Washing Machines
Leaking washing machine
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.
If helped, click.
Apr 14, 2013 | Indesit Washing Machines
Hi, our washing machine started leaking water underneath just the weekend gone. I didnot see where the water was coming from but my wife tells me that she started the washing machine as per normal as...
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end. You have indicated that the spin was activated to drain off and so the drain exit seems good . Hence I would advice that you check the drain hose fittings and drain pump. Check once again to confirm if this was a program controller malfunction of the cycle. finally keep your machine in slight slant /tilt so that the water drains off fully to the exit valve.
Apr 11, 2011 | Washing Machines
1. Water is leaking out from the bottom of the machine. 2. Also, wanted to know if you are suppose to manual pipe in water for this model........................thank you.............ong
The first part is that you need to check at the following for leaks.
1. Check for leak from the inlet due to poor water connection. check leak at the inlet valve.
2. Check for leak from the tub.
3. Check for leak from the drain pump/valve or the drain hose.
The second part is not clear but a connection for water and an outlet for drain is needed.( make/model not seen.)
Feb 19, 2011 | Washing Machines
I have a leak in my kenmore 300 series washing machine. Model # 11027332600
Can you tell where the water is coming from? Is it the back, out of the drain pipe, out from the front?
How much water do you see?
Sorry so many questions but it will aid in helping determine what needs fixing.
Thanks!
May 22, 2010 | Kenmore Washing Machines
Water leaks from underneath Indesit WG1130d washing machine.
I had a problem like this and it turned out to be the hose that carried the water out to the drain was overflowing the drain pipe.
Make sure the P trap in your drain line is open and clear. A plumbers snake, draino, or a high pressure nozzle on your garden hose might help to clear it.
Oct 04, 2017 | Indesit W 123 Front Load Washer
Zanussi front loader leaking
Most likely you have a pump shaft seal leaking you can buy a new pump at this site. You may remove the pump and clean with pool muratic acid, but it is very caustic you would have to put pump in the acid bath in a metal pan that you don't mind using it and it will eat all the organic buildup from the pump. However it may leak worse as the organic material may keep it from leaking too much. So I suggest you use the pump, if you use mueratic acid it is highly toxic so read directions on using it and were air mask and rubber gloves while using it then rinse off with clean water. You should put water hose in the drain pipe and tunrn on the water to test the drain pipe as well. this will make sure the drain pipe is fine. Look at the hoses near the clamps as this is where holes develop on the water pump hoses.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=Zanussi+front+loader
Sep 05, 2009 | Washing Machines
We have a Whirlpool,Type 111
you have a bad drain pump
May 18, 2009 | Washing Machines
Leaking water durign spin cycle
you have to de-clogged the drain outlet pipe. it could be clogged already that is why when it is draining, the pipe can not handle the amount of water coming out of the machine and it leaks out of the pipe or from the hose on the wall where the drain pipe is.
tnx 4 using fixya,
drcool
Oct 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
35 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
