Hitachi washing machine fault code c9 - Washing Machines
  • phyokaungsan
    phyokaungsan Aug 11, 2016
    I will like to know about c9 error .let me know
    New Friend:
  • 3 Answers
Error code c9
Posted on Dec 17, 2016
    Top Expert:
  • Washing Mach... Master
  • 51,489 Answers
Posted on Aug 11, 2016
SOURCE: AEG OKO LAVAMAT 86741 UPDATE. WASHING MACHINE
I have washing machine AEG 62800 model.
When I tried to start a washing the error E60 was displayed on screen.
The following actions were done:
1. Turning knob to right to first position "COTTON LINES 95"
2. Pressing on all 5 functions except START button (Rinse Hold, Rinse+, Time Saver, Pre Wash, Stain).
Red lights will flash .
3. Pressing on Start button and simultaneously starting to turn clockwise till OFF position.
It will reset error and will release machine.
I'm hoping it will help.
Boris.
Posted on Jul 31, 2008
SOURCE: Washing Machine Fault Code
The recommendation to get a new motor may be overkill and a very expensive option. Also on this site I found an alternative solution which was to just replace the motor brushes. This we did and it fixed the problem, coasting us just £20.15, rather than the £199 quoted for a new motor!
A reasonably competent person needs to remove the motor, identify the brushes and remove - just involves two hex-head screws. When new the brushes will be around 2.5cm long. They need to be around 1 - 1.5cm long to work. Alternatively the spring(s) may be sticking, preventing the brushes from being pushed against the rotor.
When calling suppliers to enquire as to availability I needed not just the product description, but also the PNC and serial numbers (located inside the front door), as types of brushes have varied during the production period. However the outlet I went to still did not have the correct bush - housings were different. The chap serviing very kindly swapped new brushes into the existing housings - this is something you could do yourself if you cannot get the exact same ones - just a little fiddly.
Hope this helps!
Posted on Sep 25, 2008
SOURCE: AEG Oko-Lavamat 86820 Update Error code C9
Hello. I got error code C9 on a LAVAMAT 86800. It pumped in water, and it pumps out water. You can select pump in or out....But the motor dont turn. It will not sentrifuge. So I bought new carbon brush'es on the net. One of them were totally wore down. Now it works. They lasted for 10 years.
Posted on Feb 05, 2010
  • 3 Answers
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Posted on Feb 20, 2010
  • 174 Answers
SOURCE: What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
Posted on Jul 16, 2010
Hitachi SF-P120LJ. What does "C9" code indicate?
you can google this and receive the answer
Nov 02, 2015 | Washing Machines
SF-P95JJ GIVE ERROR C9
Not "hitachi washing machine error code c9 what to do"
electronicsfurnitureinfo.com/.../hitachi-washing-machine-error-code-c9-...
Info about hitachi washing machine error code c9 what to do in Electronics ... What do you think about this washer Electrolux ZWT-61M, do you like the design?
Jul 28, 2015 | Washing Machines
Showing c9 code in my wishing hitachi sf-120jjs
http://www.hitachi.com.au/Admin/uploads/Documents/79f34607-50d7-41e3-82a9-68436f3cd04b.pdf
page 42 If warning signs to tell you some failure or trouble, such as "F0", "F9" are generated, immediately stop operating the washer and contact an authorized service dealer or a service agent for further inspection and or repair.
Dec 09, 2014 | Washing Machines
Hitachi washer showing error code c9
What About Same Error C9 for Hitatchi SF-P95JJ
Sep 05, 2013 | Washing Machines
Hitachi washing machine. Model:SF-P90DJ Fault code F9
my hitachi model SF-120 HJ is washing machine cleck c2 n c4 warning stop f9..........
Jul 29, 2010 | Washing Machines
Jul 14, 2010 | AEG Lavamat 72640 Front Load Washer
What means error code "C9" ? AEG Lavamat 76669
C9 Indicates Motor Fault. It seems that the Carbon Brushes have Worn out.
Replace it and more likely it would Fix the Problem.Once you replace that, you need to put the machine into Service Mode to Reset the Error.
Steps for Reset the Error Code
1. Press and Hold the Prewash and Soaking Buttons Together.
2. Whilst Holding them, Turn the Dial from Off one Click Anti Clockwise
Note - If problem persists, Check the motor plug for broken wires and check the state of the carbon brushes.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Feb 28, 2010 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat washing macine C9 error code
C9 is a motor fault.
Normally it's worn out carbon brushes so you'll need to check them first.
If worn out or broken, replace them.
Then, you need to erase the code (reset the machine).
To do this, turn the dial to off.
Press and hold together, prewash and soaking buttons.
While holding them, turn the dial 1 click anti clockwise.
Release the buttons.
Turn the dial to off, to any program and back to off.
This should get rid of the C9 code.
It will come back if you don't repair the motor fault.
Dec 10, 2017 | AEG Lavamat 88840 Front Load Washer
AEG 88730 UPDATE
For a solution to your dilemma, I recommend that you first replace the brushes, then to reset the error code C9 hold down the pre-wash & short wash together and turn the control knob from off to gentle spin. this sequence should clear the C9 from your washer.
Aug 18, 2008 | Washing Machines
Washing Machines Logo
1,311 people viewed this question
Top Washing Machines Experts
