Question about Electrical Supplies
Yamaha powermate 5700 will not run electricity
Generator has been running for about 6 hours but stopped, put more gas and then turned back on again but now no electricity is coming out
CarlGehrke
  • 169 Answers
SOURCE: powermate pm0545005 generator engine runs but no power out
I posted a general "how to" about troubleshooting Powermates here.
Don't forget to rate answers you like,
Carl
Posted on Dec 05, 2008
  • 67 Answers
SOURCE: Not a 6250W but a 6500W Coleman Powermate Black Max.
Call Pramac Co. at 770-218-5430. I get parts from them every week. A service center left holding the bag when Coleman/Powermate went out. Ken's Repair
Posted on Sep 23, 2008
knotbeerdan
  • 413 Answers
SOURCE: No electric power generated from my Coleman Powermate Maxa 5000W.
the gensets on coleman generators are definately nothing to brag about but i would start by checking the windings and make sure the brushes have a clean armature to ride on
Posted on Dec 19, 2008
protek480
  • 1714 Answers
SOURCE: My coleman powermate generator will start but will not generate.
The voltage regulator controls the output. You will need to check that first.
Posted on Aug 01, 2009
  • 5603 Answers
SOURCE: coleman 6750 powermate with yamaha mz360 electro
One of two things:
1. The rotor has lost all the magnetism it needs to get started generating. It needs to have a tiny bit to get started.
I have used the system of a couple series 150 watt lamps between the generator and the utility power. Search Google for description of this method. I have used it and it works.
2. You have blown diode(s) on the rotor. They would have to be replaced. I have not found a source and had to make my own.
Posted on Nov 02, 2009
Need image of where the wires go on a powermate 5700 generator with yamaha motor. the wire colors are yellow,blue,black, and black with white stripe
are these wires on the engine only ? if so they could well be from the low oil sensor, maybe over heat sensor and to the kill switch if this is the case then its possible that they connect in a chain from kill switch to earth which will shut down the engine if a fault develops
Mar 09, 2014 | Powermate Portable Generator 5700 Rated...
Powermate generator 3250 runs for hours then chokes out runs rough
If it runs for hours under the same a mount of load then, chokes down, make sure fuel lines are fully clear, it may operate with a full tank of gas then when the weight of the fuel in the tank gets less has a problem. When it chokes out fill the gas back up and see if it works again. Also make sure the choke butterfly is not closing again whilst hot. I don't know how many hours are on it, but a decarb may be in order, especially if it runs for hours no issues
Oct 27, 2012 | Powermate Portable Generator: 3250-Watt...
Generator has been running steady for 2 weeks. It will not start now. It has spark, gas is good, oil is good. It is a 5000 coleman powermate electric generator. Did it die due to a 2 week running? It...
if it doesnt turn over how did you test the spark?
if i have read it wrong then always try a new spark plug, these can fail under compression but will spark happily outside the cylinder.
if it wont turn over then it could be siezed or dropped a valve.
Apr 23, 2011 | Coleman Powermate Powermate 5000W...
Hello I got a 5000w powermate generator that could run for hours without problem but when i stop it and restart it again it will not produce electrcity. I have to open the back and clean the plate where...
Did you flash the exciter since it has been sitting and after brush replacement?It has probably lost its charge and needs to be flashed with 120v, let me know and we can go from there
Jan 21, 2011 | Coleman Powermate Powermate 5000W...
No AC out put
After working on several of this style coleman generator,i have found that the lead wires in the windings that are soldered to where your brushes would contact tend to break.I don't know if it's a poor design or just a fluke,i would check to see if your getting continuity on the rotor and go from there.They seem to either "burn off" or just break.
Mar 09, 2010 | Coleman Powermate Powermate 5000W...
My coleman powermate 6250 generator just stopped producing electricity. It was running all day. Motor still runs just no juice.
check the reset-- if power to reset line, switch bad if no power -check feed out from generator if no out put then possible internal problem --winding or short
Mar 02, 2010 | Coleman Powermate Premium Plus 6250W...
Can the ecu memory be flashed on a yamaha EF2800iportable generator? My 2800i will start and run for about 90 seconds and then shuts down. Carb is fine. Two issues: 1. It is not generating...
It sounds like its running on the gas in the carburetor and not the gas filling back up to run more, I bet you have a gas supply problem to the carburetor! Try Babbitts Yamaha Partshouse online...
Mar 12, 2017 | Yamaha 1,000 Watt Portable Generator...
5500 generator stopped producing eletric after
First check with the dealer and see if it is still under warranty. If it is not, make sure nothing is blocking the air flow around where the control modules are located. This could cause the voltage regulator and other electronic parts to overheat. Next check the brushes and make sure they are free of any dust or build up preventing them from making contact.
If everything is OK the next thing I would do is change the voltage regulator.
Nov 17, 2009 | Coleman Powermate Powermate 5000W...
Runs rough when choke pushed all the way to run position
Where can i obtain a manual for the 5500 gas generator
Dec 26, 2008 | Coleman Powermate Powermate 5000W...
Sep 15, 2008 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
223 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
