Question about Toshiba 26AV500U 26 in. LCD HDTV
Need InfraRed CCF codes for Toshiba 26AV502U
I need to know before buying
  • Anonymous Jan 24, 2009
    i need a remote code for toshiba 26av502u too, if anyone knows a good website to get these, please post
  • bbishop423 Apr 10, 2009
    need remote control code
I know you posted a few months ago, but i recently found the code. its 0156.
Posted on Jun 01, 2009
Colour on the tv is too green and red model 26av502U. Less then three years old. Reset to factory default settings per manual instructions and it didn't work
If you are using component cables change them out. It sounds like they're faulty. Try another device like a dvd player on a different input with different cables to see if the picture is still too red or too green. If so then the tv needs servicing. If not you can rule out the television.
Aug 13, 2011 | Toshiba 26AV502U 26 in. LCD HDTV
Toshiba 26AV600T When turn off by remote control ( stand by lamp still illuminate) I can not turn on by remote ( ON/OFF in the same button ) Q: TV set OR remote is bad. Thank you /// Thongsuk. My Mail:...
Tries the tv manual control power button pushes a couple of times on/off,if tv it turn on and off with no problems.Yes.Than the tv remote have problems.Try Remotes.com to buy the original remote.
Jul 13, 2011 | Toshiba 26AV502U 26 in. LCD HDTV
How do you reset a pin code for a phillips tv
If you have not set your PIN-code when you first turned on the TV set, you need to do this before you can use the Child lock feature.
If you forget the PIN Code, unplug the AC power cord for 10 seconds to restore the PIN Code to 0000.
If you need to set your PIN Code for the first time, proceed as follows:
  1. Press the ' MENU ' button on the remote control to access the main menu.
  2. Press the cursor up/down to select FEATURES and press OK.
  3. Press the cursor up/down to select Child Lock and press OK.
  4. When the Enter PIN appears on the screen, enter '0000'.
Dec 07, 2010 | Toshiba 26AV502U 26 in. LCD HDTV
I own a Toshiba 26AV502U and the TV volume automatically lowers as if I was holding the respective button. Last night I had no issues but today this problem first surfaced. I checked to see if it was a...
hi
first is your tv hooked on some converter cable hd device if so this unit could cause the problem if not you will have to replace the main module. This kind of problem is very rare on this type
Sep 28, 2010 | Toshiba 26AV502U 26 in. LCD HDTV
Toshiba 26AV502U, sound breaks up, picture freezes, then fades, and then sound comes back on as staticky, with no picture.
Ur Tuner board have problems,it dying.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Apr 22, 2010 | Toshiba 26AV502U 26 in. LCD HDTV
Remote Control wont open manue on new tv
ensure the satellite receiver is turned on and the output from the satellite receiver is connected to the ant. in on the tv. on the remote control, press the tv button, then the menu button. from the menu, select settings, set input to ant. .
do this and let me know what happens so we can get this working
I will be available till 2:00am CST
clarkco
Feb 16, 2009 | Toshiba 26AV502U 26 in. LCD HDTV
We just purcased Toshiba 26AV502U, now the screen is blank
Heard back from Toshiba. They said to unplug the TV, wait at least 3 minutes, and then plug it back in. This should allow it to reset itself. Sounded too simple, but after doing just that the tv has worked fine for the last three days! Toshiba noted that if this didn't resolve the problem we should contact them to have a Toshiba Authorized service person come check out the tv. It worked for us, hopefully it'll work for you too. Good Luck
Jan 18, 2009 | Toshiba 26AV500U 26 in. LCD HDTV
Toshiba 26AV502U (new) video dropout if VHS tapeis not perfect
Had problem checked by local outfit called "Circuit Pro"; their analysis was compatibility.
Actual answer was that the Toshiba required a better quality input from "any" VHS source.
I finally took a "less than perfect" VHS tape with me when I returned the Toshiba TV to the store and demonstrated the problem to one of the TV sales people. He played the VHS tape through a display VHS/DVD player to three different brands of TV. The picture was often "black screen" on a Toshiba, but was merely poor quality on the other two brands. I upgraded to a Sony KDL26M4000 from the Toshiba 26AV502U.
Dec 03, 2008 | Toshiba 26HF84 26" TV
Toshiba 26AV500U 26 in. LCD HDTV Logo
465 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
