Question about Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
Sharp LC-26DV24U has Black screen only
Does power on
  • criola4ever
    criola4ever Nov 03, 2012
    Thanks do u know any web side to buy that part. I do think is something w video because it powers up but only black screen
  • 127 Answers
The Video/ luminance. or the power voltage supply line is not
working. needs repair.
Posted on Nov 01, 2012
  • Tony Nov 03, 2012
    First you can order the power suply module.To try to solve the problem.
  • Tony Nov 03, 2012
    Video Module may be to expensive.Or you can buy another brand Tv.
4 Suggested Answers
brownline45
  • 310 Answers
SOURCE: LC-26DV24U displaying a white screen.
good day the defect is in the main board ,or loose connection in the main board
Posted on Jun 20, 2010
budmrtn
  • 11361 Answers
SOURCE: LC-26DV24U white screen only
The grey screen is caused by failed transistor for the switched 12vdc for the T-CON board, same as my pictures here (my does not have the DVD), but it can also be the main 12vdc itself that is bad, you will have to do some probing. Since the screen is grey, you will not be able to tell if the set really function or not. http://s807.photobucket.com/albums/yy352/budm/Sharp%20LC-26SB24U/
Here is the free service manual that you will need: http://elektrotanya.com/?q=showresult&megnev=SHARP&megnev2=LC-26DV24U%20&kategoria=&kat2=all
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please let me know what you find.
Posted on Jul 15, 2010
bshldn
  • 736 Answers
SOURCE: I have a Sharp AQUOS LC-32D47UA 32", black box
Press the cc button on your remote control. You want cc to be off. Play around with the cc button to become comfortable. Press it over and over again. Observed that a different closed captioning option appears on your screen each time you press the cc button. Now press cc and when it says cc off do not press the button anymore.
Posted on Jan 23, 2011
How do I Fix my tv? My TV plays for awhile and then the screen turns white. Sound is good even when screen is white.
sounds like maybe something is begining to go. I usually recommend that it is reset to factory default through the menus available from a remote control. If, after resetting, the fault persists it must be something to do with the electronic hardware and the fault shoud be diadnosed by a qualified technician.
Jun 02, 2015 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
How do I tune my Sharp tv to channel 3 so the cable will work?
Go to the Tuner setup screen and select cable instead of air. Then put the TV on Channel 3 and connect the cable box to the antenna connector on the TV.
Jul 04, 2014 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
How to troubleshoot lcd tv
If you are using the ANTENNA input mode of the TV and should be receiving a local station on a properly chosen channel then something is wrong with the RF or IF section inside the TV. If you can connect an external video source to the TV see if that works while selecting the proper input mode.
Jul 01, 2014 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
My sharp LC-26DV24U is displaying a white screen only.
I have the same model Sharp TV with the same symptoms. The TV would sometimes work perfectly, then go to white screen (audio OK) and sometimes back to working perfectly again.
I saw Posts saying to check F404 and Q413 - My fuse F404 was not blown, and replacing the Q413 transistor did not fix it.
On Q413 I had about 12.4 VDC on the Emitter, 12.3 VDC on the Base and about 1.5 VDC on the Collector. My service manual called for 11.6 VDC on the Base lead. As a Test, I used a 150 Ohm resistor from Q413 Base to metal chassis ground, and that made the TV work OK.
I replaced the Q419 NPN silicon driver transistor, and now the TV has been restored to 100% proper operation.
I hope that helps someone else down the line.
Mar 27, 2012 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
Jul 15, 2010 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
Jun 20, 2010 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo Logo
153 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
