Question about Refrigerators
My Black & Decker BNA17 Nucool 1.7 cu. ft. Compact Fridge - Black - will not cool?
At first the fridge would get cold now it is just cool. Even on the coldest settings. We have not had it a year.
  • 9 Answers
SOURCE: Fridge does not cool below 40 degrees
This is a common problem and a design fault...
Posted on Sep 06, 2008
tech master
  • 120 Answers
SOURCE: frigidaire frs26zrf
IS THE EVAPORATOR FAN INSIDE FREZZER WORKING AT ALL IF IS NOT WORKING THEN THERE IS NO AIR FLOW TO THE BOTTOM PART
Posted on Nov 10, 2008
Illeagle
  • 525 Answers
SOURCE: KitchenAid Superba fridge section not cooling, freezer is cold.
You have done a good job of attempting to diagnose by process of elimination, but this is a more complex system. I have provided some links below to assist you in diagnosing your problem. Links courtesy of www.repairclinic.com.
1. Ascertain that the evaporator fan is operational. This may be controlled by the Door Switch, (No.4) and could cause the fan to be inoperable.
2. Ascertain that the Fresh Food compartment light goes off when door is closed.
3. The air diffuser may be faulty by not controlling the air flow from the freezer properly
Tip: Always maintain dual temperature control settings at equal or +/- 1 setting position.
How refrigerators work:
http://www.repairclinic.com/0088_4_3.asp
You will need to verify operation of the following components listed below:
1. Evaporator fan motor
2. Air diffuser assembly
3. Light switch for refrigerator/freezer light
4. Door switch
Click on the links to identify the parts listed
1.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di921541&PartID=921541
2.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di827263&PartID=827263
3.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di438889&PartID=438889
4.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di586519&PartID=586519
Parts breakdown diagram:
http://www.repairclinic.com/Refrigerator-Side-By-Side-Appliance-Diagram
Posted on Aug 13, 2009
heatman101
  • 43501 Answers
SOURCE: Fridge not cooling, freezer not freezing even on coldest settings
From what you are describing, you have a refrigerant leak. The freon has leaked from the system, The compressor will still run and evrything looks fine. To double check you will have to have someone hookup gauges to the system and verify that the charge is lost.
It may be possible to find and repair the leak. This is not always possible as some of the system is virtually inaccessible in many refrigerators.
Make sure if you do have someone repair the system that they evacuate the system very well and do a good vacum test before recharging the system.
This should help you to solve your problem.
Thanks for using Fixya!!
Heatman101
Posted on Nov 24, 2009
  • 3 Answers
SOURCE: What size fuse to use in a Black And Decker NuCool
3 amp but if that is blown theres 2 diodes near it the may be bad . i had the same problem
Posted on Aug 28, 2010
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Won't stop running even on the off position on temperature. Freezes everything
the "o" position is as cold as you can get
try setting up around 4 and see what happens
Apr 29, 2015 | Black and Decker USA Black & Decker 2.7 cu...
Black and decker refrigerator model BCFA27B not working
Check any defrost water hasn't got into the electrics and blown a fuse.
May 28, 2014 | Black and Decker USA Black & Decker 2.7 cu...
Mini fridge wont get cold
How old is it? You proablaly need REFRIGERANT!!!
Jul 21, 2012 | Haier C-RNU1708B 1.7 Cu. Ft. NuCool...
My side by side 23.6 cu. ft. no frost refrigerator is not freezing and the refrigerator is not getting cold enough. There's frost on the back wall inside freezer. It's a GE TFX24VR. What can I
usually that means your fridge thermostat is being blocked by items in your fridge, telling the cooling system to shut down. If your fridge and freezer are packed, the fridge might protect itself by shutting down the cooling system. Happened to us last Thanksgiving.
Mar 07, 2012 | GE Refrigerators
Admiral 26 cu. ft. Side-By-Side Refrigerator FRIDGE VENTS ICING
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 21, 2011 | Admiral 26 cu. ft. Side-By-Side...
What size fuse to use in a Black And Decker NuCool 1.7 SqFt refrigerator? Model number is BNA17
Jul 22, 2010 | Refrigerators
I have a black and decker 1.7 cu.ft refrigerator its a 115 volts and 15 amp outlet and i am trying to put it in a semi truck. I am looking at a road pro 2500 watt. Do you think this will power it? And cool...
What wattage is the fridge Youy cant compare volts and amps withy watts.
If the fridge draws 2000 watts it wiull do the job but struggle as 2500 is the peak wattage and averages out at about 2000-2200 look at the back of the fridge. Just hope its about 15-1800 for effiecient cooling without strain on power source
Jul 28, 2009 | Electronics - Others
Camper fridge will not cool down(unsure of model)
ok firstly if you remove the element and give it 110v does it warm up if it warm up and still not making the fridge cold the propane chemicals are not right any more
May 15, 2009 | Dometic WA3210 Compact Refrigerator
Refrigerators Logo
134 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
