Question about Canon PowerShot Pro1 Digital Camera
Lost lens cap
Canon pro 1, i lend my camera to my cousin, she lost the front cover lens cap, im particular about the original cap.
any suggestion where i could buy 1, tried my conon dealer they are all out of stock for this type.
  • 4,472 Answers
Http://www.bitssite.com/canon-powershot-pro-1/2827/rear-lens-cap/accessory.html
That should be the cap your looking for if not let me know. Please take a moment to rate my solution fixya if it helps.
Thank you,
Lee
Posted on Jan 04, 2009
How do i replace lense cover on a canon sx170 is?
Since I cannot see your pieces, I can recommend actual replacement. You can Google your camera's make/model with replace lens cover and pick from the listings. You can also go straight to Canon USA and search their store as they have replacement lens covers. I did this here for another customer as an example.
Lens Caps ' Canon Online Store shop.usa.canon.com/shop/en/catalog/.../ef-lens-accessories/lens-caps
Canon Tips & Tricks When using a lens with IS while on a tripod, ... Canon Tips & Tricks That hole in your battery cover has a purpose! ... Lens Cap 14mm f/2.8L II.
Jul 19, 2014 | Canon PowerShot SX170 IS 16 Megapixel...
Replace lense cover on camera
You can try doing a Google search for your camera make model. I did and found this - below.
btw - Canon is spelled with one "n" which might help in your search results. I'd go to canon usa and click on their link or search their store for your replacement lens cap. Different lenses have different sized lens caps, so be sure you have the right one.
Mar 19, 2013 | Cannon Cameras
The lens cover on my Canon Power Shot A530 will not close completely. The camera still works fine, but I am concerned about damage to the lens. Is this fixable?
A stuck lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it: 1) Try blowing lots of compressed air around the lens cover to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Use no heat mode if possible. 2) Slide a thin strip of paper between the lens cover shutters and the outer support ring. Work it around 360 degres to clear out any debris that may be in there. 3) With the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. Repeat the above three steps several times. If repeated tries don't work (keeping in mind that it usually does), it then may be necessary to open the lens barrel to access the lens cover mechanism.
You can open the lens barrel up to fiix the covers, but only as a very last resort. The above procedures normally work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty).
Oct 13, 2009 | Canon PowerShot A530 Digital Camera
Lens cap will not stay open
try opening your camera in front unscrew the bolts and pull the front cover.you will see a metal cover not properly align.
Apr 06, 2009 | Kodak EasyShare V570 Digital Camera
Powershot Pro 1 shutter problem
The whole thing is very complicated. In many of the new technologies, there are mechancal devices with very complicated electronics intigrated with them.
Sometimes you can get different opinions, but until the job is done and proven, it is difficult to know who is really right until everything has been done.
Personaly, If I like the camera, and I cannot find something that good for 250 EU, I would fix it.
Apparantly, the PRO-1 is one of the best small digital cameras that Canon ever made. I personaly own one. I have not taken too many pictures with it. But, when I use it, for the size its performance is impressive.
I ended up buying a small Canon camera that will fit in my shirt pocket to carry around with me. I use the Pro-1 for more serious pictures.
Jerry G.
May 07, 2008 | Canon PowerShot Pro1 Digital Camera
Lense will not close properly
You can open the lens barrel up to fiix the covers, but only as a very last resort. The above procedures normally work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Apr 25, 2008 | Canon PowerShot A70 Digital Camera
Lens cover only partially opens
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. But it should be similar for the A430:
Mar 31, 2008 | Canon PowerShot A540 Digital Camera
How do you replace the lens cover for the Canon A620.
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. But for the A620, you might want to extend your zoom all the way out before removing the camera's batteries. Also you'll be applying the ring loosening rubbing alcohol around the barrel's perimeter instead of the front as shown in the procedures.:
Mar 25, 2008 | Canon PowerShot A620 Digital Camera
Lens error, restart camara issue in SD900
well **** that doesnt sound complicated or anything.
Feb 29, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Black screen, loud beeping when opened, doesn't work
The following blog outlines some simple repair options for a lens error. But please first try the listed Fix #2. I heard that fix particularly works well for a camera who's battery had run down with the lens open. Please post back here with a follow up comment if any of the fixes work:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 23, 2007 | Canon PowerShot S60 Digital Camera
Canon PowerShot Pro1 Digital Camera Logo
170 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
