Question about Refrigerators
The compressor of unit not turn on again after unpluged
After switch off the unit to changed inline water filter and turn power on again, the fridge/freezer compressor not started again, only one little horizontal bar of LCD panel blink, the inside light and water dispenser still work. How can I test the compressor relay still OK (by multimetter)?
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
You can just unplug the relay and shake it. If it rattles, it's bad.
What is your model number?
Posted on Nov 02, 2012
aborcass
  • 2651 Answers
SOURCE: ice won't dispense, no power to water light
I would check hte wire harness leadngto the door under hte freezer hinge. itll be wrapped in a black web like covering. Just under hte unit itself follow ht ewire and unplug hte harness. then carfully cut hte black webbing and inspect wires. there tends ot be apinch point there and the wires will sheer from one another, . if so there is no replcing hte harness, the door would have to be replaced at a cost of nealry $600. not enough room for a wire nut, but hav had sucess using stright inline bullet style connector, or others have sucessfully soldered connections back in place
Posted on Mar 25, 2008
SOURCE: Superba ice maker stopped working, door water still dispensing
Use a cup of water and just fill the ice cube maker with enough water for the first batch and the sensor will then begin making ice again.
My ice cube maker stopped working after I changed the filter. After reading countless posts about wiring and defrosting and using a blowdryer into the fill line I emptied my freezer and fridge, then unplugged it. I got no results after two days. I finally just put some water in the ice cube maker (the metal ice cube tray below the white plastic fingers that forms the cubes) plugged it back in and closed the door for a few hours and it worked. I wonder if I needed to defrost the unit at all. It was working before I changed the filter, then the filter was full and stopped water from flowing (or decreased the flow dramatically anyway).
Good Luck
Barry Eager
Posted on May 05, 2008
  • 1073 Answers
SOURCE: Water and Ice Dispenser shorts Fridge
call ge there is a replacement program for the 05-06 sxs motherboard issue call 800-386-1215 to see if your machine is one of the machines in this program you will need the serial number of the ref before you call
Posted on Jun 13, 2008
  • 1122 Answers
SOURCE: refrigerator Compressor hot to touch & fridge/freezer not cooling
you need to do an amp draw with your meter,clamp the run wire on the compressor,you should get 2-5 amp reading,any higher means the compressor is going bad,also should be a locked rotor amp(LRA) reading on comp.-mike
Posted on Nov 04, 2008
  • 74 Answers
SOURCE: Front panel beeps when I push any button or
possible bad dispenser board
Posted on Nov 17, 2010
Ice maker and dispenser is not getting water
Make sure "Stop Bar" is all the way down. Check water filter (if applicable. If water filter needs replaced, it can stop water from entering the system). Unplug the fridge or shut power off at fuse box for 20 minutes. After restoring power, If ice maker does not start after a few minutes, Check water inline. (if fridge has been moved, it could have pinched the inline). Check the point of where the inline starts (if possible, disconnect and flush inline. The inline has been known to get clogged at their point of origin coming off of a main water line)
May 15, 2016 | Frigidaire Refrigerators
Unit in room displays fault code -0 and 6. Unit is a Sharp eco inverter AY-XP07ER. Unit runs for a few minutes and cuts out showing fault code.
Do not allow the signal receiver window to receive strong direct sunlight, since it can adversely affect its operation. If the signal receiver window is exposed to direct sunlight, close a curtain to block the light.
Using a Fluorescent lamp with a quick starter in the same room may interfere with transmissions of the signal.
The unit can be affected by signals transmitted from the remote control of a television vcr or other equipment used in the same room so make sure if anything recently added to the room is un plugged for testing purposes.
Do no leave the remote control in direct sunlight or near a heater also protect the unit and remote control from moisture and shot which can disclour or damage them.
Check whether the remote control batteries have become old and weak. (replace with new ones)
Try to send the signal again with the remote control pointed properly towards the units signal receiver window
Check whether the remote control batteries are installed with the polarites properly aligned
This could also be a result of the error locking out the remote as well so keep this in mind.
Also if possible unplug it and let it sit for atleast a day then plug it into a different outlet (if possible) to see if there is any change in the units functionality.
After that I would have to say check the area around the base of it and make sure that there is no moisture damage to the unit.
A good cleaning could be in order as well.
then if all else fails and the error presists contact customer service with the issue of the machine they will know what the error codes are.
hope that helps let us know how you make out.
Aug 02, 2008 | Sharp Heating & Cooling
Water pressure has dropped over time. when softener is bypassed, water pressure is fine
A inline water softener functions similar to a filter. When a filter become clogged it restricts water flow. Perhaps this is what is happening with the inline softener unit. Try changing to a new unit.
Dec 21, 2015 | Water Water Heaters
If the water filter is bad, will this cause freezer and refrigerator to be warm?
NO being low on freon will do it tho and only certified repairmen can recharge them
Nov 09, 2015 | Refrigerators
Washing machine water
Firstly, do you have water at the moment? Then, your power must be on and the taps turned to on - hot, cold or both.
Secondly, the cycle must be selected and activated; by pulling or pushing the control knob.
Still not working? Check power to the house. Switch on a house light. Does it work? Plug something else into the power point. Does this work. If not, then the fuse may be blown. ELCB (safety switch) may have tripped. Reset, replace etc;
Lights on but nothing working - then switch off, unplug the machine, turn off the taps and disconnect the hoses to the machine. Most washing machines have inline water filters and these can become blocked. Clean/replace and try again.
Beyond this it may be that the solenoids are broken and need replacing. A multimeter could confirm this.
Sep 21, 2012 | LG Washing Machines
Split AC whole unit turnig off at each compressor start up!
Dirty coil wash outside unit with water and change indoor unit filter
Jun 08, 2017 | Heating & Cooling
Where do I find the filter that needs to be changed
Hi
There are two types of water filter fitted to this model they are both located in the top right hand corner of the refrigerator section.
1. The standard water filter looks like an upturned bowl, to change this you need to unplug and switch off the unit, turn off the water supply and unscrew the filter around 1/4 turn anticlockwise.
Replace the filter and tighten the bowl checking that the O rings are in place. You may make a bit of a mess with water dripping out as you remove the filter bowl. These can be quite stubborn if they have not been changed before.
2.Pure source filter is on the face of the unit next to the thermostat, again shut down the unit and turn off the water before removing the filter, there is a small button lower right on the face, when you press this the filter should pop out, again spilling some water.
It is vital that you prime the system properly before using the water or ice this means running at least 2 gallons of water out of the water valve on the front to make sure that all the air is out and that pure water is in the machine.
You manual is available at this link
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/241856000en.pdf
Hope this helps
Gordon
Apr 26, 2011 | Frigidaire FRS3R5EMB Side by Side...
I have a used ultrasonic cleaner model CD3800A, and need operating instructions.
I had a problem with Ultra sonic cleaner Model 3800. It would not turn back on. I found that if I unpluged it and waited 5 seconds it would work again. So if your unit will not turn on just unplug it (wait 5 seconds) and plug it in and see if this solves your problem. Because my unit plugs into a power strip under my desk and was difficult to get at, I put aan inline switch in the power cord.
Good Luck
Feb 09, 2011 | iSonic Ultrasonic Cleaner Model D3800A...
SBD21VE Side-by-Side - water dispenser line seems to be freezing. Water is still getting to the ice maker, as ice is still being made. When I recently had the fridge unplugged for a thorough cleaning,...
COOLING Dust on the condenser coils can cause overheating, observe safety precautions then clean coils. Switch off the unit before you clean them. If the problem persists, test the compressor for overheating. Overheating will cause many problems with cooling ability. Leave the unit unplugged for 3 hours and plug it in again. If it starts working, the compressor is probably overheating (Observe cautions with food going bad). A simple cause of the problem might also be that there is not enough airflow Lack of airflow is the number one cause of compressor problems and thus an owner purchasing another unit for hundreds of dollars when you can fix it for free.There should be at least several inches distance between the sides and walls/cupboards/ceiling. Electrical There is an in-line fuse mounted in the line supplying the power to the ice-maker. It is in the wire clipped to the side, change out this fuse asap. It is actually a 20-amp fused, associated with the grounded electrical supply. PARTS You may order parts very cheap from here www.canadianappliance.ca/KBRS22KV.html TIME TO CHANGE YOUR FILTER While your on the back of the system, please check the filter. There is a filter in the back of the fridge in the upper right hand side. If you do not change it, it will slow down the frig and burn it out permanently.
Jan 28, 2011 | Amana Refrigerators
My refrigerator just won't run. We noticed that the ice was thawing yesterday and now it's totally not cold at all. No water comes out of the water dispenser too. It has power though based on the light...
Electrical: A 115 Volt, 60 Hz., AC only 15- or 20-
amp fused, grounded electrical supply is required.
It is recommended that a separate circuit serving
only your refrigerator be provided. Use an outlet
that cannot be turned off by a switch. Do not use
an extension cord
QUICK REFERENCE TO YOUR MANUAL
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=mfi2568&siteCd=MT_EN_US
COOLING
Electrical
PARTS
Jan 25, 2011 | Frigidaire PLHS67EGSB Stainless Steel Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
