Question about Dryers
My gas dryer spins but doesent get warm at all
My roper gas heavy duty large capacity dryer wont heat up, the serial # is RGL46320[w or h cant tell]0 serial #me3901465 the drum spins fine whats wrong? im on a fixed income and need to fix it myself if i possibly can. thanks ! debra
  • 1 more comment
  • Debra Scott Jan 04, 2009
    i dont here the click when i turn on the dryer so what is the part called? also is it installed from the back and do i need to open the cabinet somehow? hope not! also i have worked with gas lines before so not to worry there. thanks fellas i apprieciate your help and god bless you too! Debra
  • Debra Scott Jan 05, 2009
    i will try that and see if i can fix it. might take a couple days to get back here but in the mean time thanks for caring i apprieciate it soooooo much! Debra
  • souandkelly Jan 21, 2009
    I have a Frigedaire gas dryer that turns on but no heat comes out. What do think is the problem and can I fix it myself?
  • 78 Answers
When you turn it on listen for a clicking sound. If you don't here that. The electric igniter needs replaced. And sometimes theres a circitboard that goes bad. But its gas, and there fore very dangeruse. FOR YOUR SAFETY IF YOUR NOT EXPERANCED WITH GAS APP. GET A PRO TO WORK ON IT.
Posted on Jan 04, 2009
    Sergeant:
  • 311 Answers
Hi debra,when you start your gas dryer you should here two clicks, if so then your ignitor should begin to glow.if not two clicks then its going to be your thermol fuse.armed with that give me some feed back an will go from there.God bless ,tom
  • Thomas Malailua
    Thomas Malailua Jan 04, 2009
    dear debra this info means you are only hearing one click when it starts.if your dryer has a back panel,yes its in there .its small ,white has two wires to it and is shaped like a missile,or fliyng sauscer,you can connect those two wires and isolate with black tape,then try start, if go replace fuse,but you need to inspect all venting and dryer air passages for blockages because they can cause a fuse to blow to protect the consumer.God bless ,tom
Where is the heating element for a Kenmore heavy duty 60 series soft heat large capacity?
How to Replace Your Electric Dryer's Heating Element
www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid Electric Dryer's Heating Element. Here's a common job that many folks are afraid of, but it's ...
Whirlpool / Kenmore Dryer Heater and Thermostat Test ...
? 7:40
https://www.youtube.com/watch?v=KZY9CQ_CqvY
Sep 13, 2010 - Uploaded by Bill Newberry
Basic checks for a Whirlpool made dryer. ... Whirlpool & KenmoreDryer Repair - How To Diagnose No Heat ...
Whirlpool - Kenmore - Maytag Dryer Not Heating Repair ...
? 2:42
https://www.youtube.com/watch?v=i95okOr2rOI
Mar 1, 2011 - Uploaded by ApplianceAdvice
It will explain step by step instructions on how to test the thermostats, fuses, and heating element inside the ...
How To Fix Dryer With No Heat ' Dryer Repair - PartSelect
Dec 12, 2015 | Kenmore Dryers
Cell phone gets hot
Probably due to lots of apps running in current and background sessions. Turn some of the unneeded apps off, and understand that as you use your phone the battery will become warm as it provides the current to the phone.
Mar 31, 2015 | Frigidaire FGX831FS Washer/Dryer Laundry...
It takes at least 2 cycles to dry clothes. It is Roper heavy duty high capacity electric dryer. Thank you for any help you can give me. janebellard@yahoo.com
Check for air restrictions which cause the heat control to shut down faster than normal.
When the moisture cannot be removed fast enough the heat builds up and has nowhere to go so the heat control stays off longer and the clothes just tumble on.
Service manual and more HERE
Mar 14, 2011 | Roper Dryers
I have model REX3514PQ0 that I purchased from Lowe's in 2005. It is a Heavy Duty, Extra Large Capacity, 3 Cycle dryer. The dryer will turn on and will blow but only cold air. A friend suggested I check...
There are three switches :: high heat thermostat, low heat thermostat, and thermal limit switch.
Could the the thermal limit switch is opened because the dryer overheated -- these cannot be reset -- need replacing.
Could also be a faulty heating element. To test these components you'll need an ohmmeter (multi-meter) and will need to remove the back of the dryer.
More info, let me know.
Charlie
Feb 20, 2011 | Roper Dryers
Want heat roper heavy duty dryer
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 14, 2010 | Roper REX4634KQ Electric Dryer
When one opens door ------dryer keeps running
Simple repair. e45a747.jpg5fc411d.jpgf1e9000.jpgIf you gonna remove the front to do the repair I suggest you lift up on the panel to keep from damaging the clips that hold the bottom secure46c7a66.jpg
Jul 24, 2010 | Roper Dryers
Capacity of Kenmore Model: 110-9155120 Washer and 97566200-75662
3.6cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 30, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool model number LGV7646ANO gas dyer will not heat up
Can you hear a click like always? If not then it has to be either the fuse, ignitor,or sensor. If you hear it clicking then the operator coils are dead. HERE is a link that shows pictures of these parts and locations.
Jan 19, 2009 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
145 people viewed this question
Top Dryers Experts
