Question about Whirlpool Washing Machines
Ghw9160pwo water value replacement - Whirlpool Washing Machines
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Here is the part you requested. Remove the top cover to access the valve.
Posted on Nov 02, 2012
Have replaced water intake valve but still no water coming into drum
hi , is the value opening ? , check power is getting to the value to open it ...
Regards
Rob
www.gewizrepairs.co.uk
Jul 15, 2015 | Washing Machines
Hot water won't quit running into washer
Within your washing machine there is a 'water inlet value' that controls the flow of water into the unit. This value is controlled by various means, usually an electric solenoid itself controlled by the computer board also built into the machine.
If the shut-off value (the one coming from your house wall where you connect the water hose) is open, and water is still flowing into the machine while the machine if off, then the unit's water inlet valve is seized in the open position.
I've attached a video on how to replace the inlet value.
Mar 03, 2015 | Washing Machines
Kenmore dishwasher just hums when I turn on no water PR anythimg
make sure u r getting water to washer. is the water value turned on? if it is then most likely u need to replace the water inlet value
Apr 08, 2014 | Dishwashers
Water leaking into the drum of my Miele washing machine when it's not in use
water inlet value is leaking. turn off water after use until u replace the value or it could start running hard and flood the room
Apr 07, 2014 | Miele Washing Machines
Moen shower valve turns on full to cold water but flow becomes minimal when valve is turned to warm/hot. not getting enough warm water to shower. can this be fixed without rplacing the valve?
yes and no. Find hot water heater and insure cold water supply valve is open all the way. check to see if there is a hot water supply value and that its open all the way. If you replace shower value over iron pipe on the hot side it is corroded up replace pipe and value. If copper, find hot side, find value and open it up.
Nov 28, 2010 | Moen & One Handle Tub & Shower Faucet
My icemaker works, but does not dispense water
The inlet water valuve has two differant sides, one for ice the other for water, it may need replaced. Remove water line on value out to water in door and have someone push the water leaver in the door(like your getting a glass of water) if you feel pressure at the value where you disconnected then the value is good. the water line in the back inside of the fridge may be froze up, lower the temp in the fridge and give it a day. When you request water from door do you hear a clicking sound(you should).
Oct 18, 2010 | GE Refrigerators
Loud knocking and vibration during spin
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washing machine is overflowing
I replace the inlet water value. The part was less than $40.00 and took about 30 minutes to do.
Mar 23, 2009 | GE Washing Machines
Washing Machines Logo
18 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
