Question about Garmin GPSMAP 172C GPS Receiver
Display screen faulty - Garmin GPSMAP 172C GPS Receiver
The screen on my del inpspiron is not working right
Dear LesleeAnnMar,
Greetings from New Zealand! Have you tried connecting another screen to the "video Out" socket? This will narrow-down the fault: if the 2nd screen displays ok, then you know that it is a faulty screen; if it is faulty on the 2nd screen also - then it is not a screen-hardware fault, but something wrong with your display adaptor/display driver. Hope this helps! Kind regards - GBU! - Bruce.
Apr 25, 2013 | Dell Inspiron Computers & Internet
Tip
Faulty Laptop LCD screen
FAULTY LAPTOP LCD DISPLAY
You may have a faulty inverter or defective CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight or a faulty inverter that supplies high voltage to the CCFL lamp. Usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.lcdparts.net
on Dec 08, 2009 | Computers & Internet
I have sony vaio vpceh25fd ,my screen was broken but was still working before i replaced it to a new one,after replasing the screen i am having a very dim display.even i tried the previous (broken lcd) its...
The dim display could be caused by a faulty inverter. The inverter supplies high voltage to the CCFL lamp that provides the back light to the LCD screen.
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Apr 14, 2013 | Computers & Internet
Sony Laptop not any display on the screen screen is working but no any display
Oct 22, 2012 | Sony Computers & Internet
Asus laptop no screen display
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Apr 12, 2012 | ASUS Computers & Internet
Screen is blank when powered up and i cant see anything on the screen
Hello.
Connect an external monitor / display to your laptop to see if your laptop's display is faulty.
If faulty, it is the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim rather than a slow degradation, the inverter would be indicated.
In either case, a technician in your area should be able to help. Evaluate to see if the repair is cost-effective.
Hope this helps.
May 24, 2011 | Computers & Internet
I ave a problem with my acer aspire 3000 , I am not sure if it is a black screen because the windows runs normally in the left corner ( about 2 inch wide) I tried to reinstal the windows and it didn't...
That sounds like the display itself is faulty.
To check the display, plug in an external monitor, if the picture is complete, your display is probably faulty. Replace the display, (ebay). If the display is still faulty, the VGA processor may be faulty. Replace motherboard/notebook.
Feb 06, 2011 | Acer Aspire 3000 Notebook
When you turn on I get a white screen.
It is possible that either your software is corrupt or yourr display is faulty.
So remove off your battery for some time (30 min) and after removing the memory card replace the batttery to switch on. If the display is the same but the phone loads and call can be received/called back, then the display is faulty. If not software must be reloaded.
Sep 11, 2010 | Nokia 5220 XpressMusic Cellular Phone
Display not comimng up when switched on
The screen cannot display anything, not even the charging display because the flex of the screen of your phone is faulty.
All you need to do is to replace the flex on the screen of your phone in order for the screen to display.
Take care.
Apr 21, 2010 | Sony Ericsson W550i Cellular Phone
I have no display o9n screen or monitor
It could be one of two things. First thing your display is faulty and will ahve to be replaced or the second thing is your system board is faulty. To know if its your system board use an external monitor via the vga port on your laptop if you can see and use your computer using the external monitor then just your screen is faulty if not then its your system board
Feb 22, 2010 | Sony VAIO VGN-NR220E/S Notebook PC
Garmin GPSMAP 172C GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
