Question about Hitachi StarBoard FX-77
I cannot double-click using finger or pen on the starboard!
How to enable the touch screen function
Try this:
  1. Click Start and then Control Panel
  2. In Control Panel, click on the Pen and Touch icon
  3. In the Pen and Touch Settings window, click the Touch tab
  4. Check or uncheck the checkbox next to Use your finger as an input device
  5. Click Apply and then OK
Apr 24, 2015 | Computers & Internet
I lost my starboard software cd
Software Download
Need to upgrade your software, or maybe you have misplaced your original disk. Click here and follow the procedure to request a downloadable version. You will need to have the serial number(s) of your product(s) to hand.
Software Download
Nov 04, 2014 | Hitachi StarBoard FX-77
Finger touch
1st You download Webcam Driver.
Finger touch
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Feb 27, 2013 | Samsung XE700T1A-H01US 11.6" Windows 7...
I have a Toshiba tablet M780-s7230 and i tried reinstalling the touch screen driver and my tablet pen and touch screen still don't work what else could i do?
Have you turned on the Touch feature on Windows 7 yet? That could be the reason why your touch screen feature is not working.
To turn it on please follow this:
1. Open your Start menu and type "Touch" into the search bar. This will show a variety of options, including the "Pen and Touch" options. Double-click it to open the "Pen and Touch" window.
2. Check the boxes next to the "Use your finger as an input device" and, if preferred, check the "Enable multi-touch gestures and inking" box as well.
3. Click "Apply" to set the options and click "OK" to exit the window.
Hope this helps!
Apr 10, 2011 | Toshiba Portege M780-S7230 Tablet PC
Pen drive insert disk problem.
I think there is a virus that has disabled your pen drive please follow these steps to try and remove that disability for the pen drive.
1. Click Start, and then click Run.
2. In the Open box, type regedit, and then click OK.
3. Locate, and then click the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\UsbStor
4. In the right pane, double-click Start.
5. In the Value data box, type 3, click Hexadecimal (if it is not already selected), and then click OK.
6. Quit Registry Editor.
Hope you like my solution.
May 25, 2009 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
My HP TX2050 pen works but the pen is not touching the screen.
you're probably resting your hand while you're writing...
this happend to me when i attempted to draw/write/what have you.
the computer can't differentiate between the pen tip and your hand, so what you need to do is disable your finger as a pointing device:
1) go to control panel
2) click on the mobile pc
3) go to pen and input devices
4) you should see a TOUCH tab. click on it.
5) uncheck the box that says "Use your finger as an input device."
This should help. obviously, you lose the capability to use your finger, and the whole idea of touchscreen in general, but you can always enable this after drawing or taking notes.
Hope this helps.
peace.
Jan 08, 2009 | HP Pavilion TX2000Z Notebook
Kingston 2GB pen drive not opening by double click
This is cause by a virus or something , first thing that you can do here is to back up all the files from your pen drive and then one everything is already back up you can go ahead and format the drive, just right click the pen drive and select format....that should;d fix the problem,,,,
Dec 28, 2008 | Vantec 1 Bay NexStar 3 USB 2.0 External...
StarBoard Fx-77 Pen does not write on the boards surface
i dont know why i bother looking on here, ive looked for a number of solutions for different problems and there is never any answers on here
Oct 18, 2007 | Hitachi StarBoard FX-77
My cursor was smooth and easy to draw with, but now it's all shaky and won't draw well!
the latest drivers have 2 modes...
1 open the driver control panel
2 at the top of the window double click the intuos3 tablet that is giving you problems
3 choose standard mode instead of recognition data
... this is at least what worked for me. I hope it helps.
Aug 01, 2007 | Wacom Intuos3 6x11
Hitachi StarBoard FX-77 Logo
99 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
