Question about Frigidaire GLTF2940ES Front Load Washer
What does a defective control board mean? - Frigidaire GLTF2940ES Front Load Washer
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
Think of it as the motherboard in your computer. It pretty much controls everything.
Posted on Nov 02, 2012
What does flashing red LF mean on freezer
Kenmore Refrigerator Error Code = Er 1F
Error Condition = The fan for the ice compartment failed
Repair or Check = Icing fan blocked - ice fan motor is defective - wiring in the circuit is defective - control board has failed
Parts Needed = Ice fan motor - Wiring harness - Power control board
Kenmore Refrigerator Error Code = Er IF
Jul 05, 2017 | Washing Machines
What does LF flashing red mean
As i power on my ricoh mp2000le this is the error i saw. sc 829 code 301 detail ac000000. whats the meaning and solution?
here are some reasons.
1.Self-diagnostic Error: Optional RAM
The optional RAM returned an error during the self-diagnostic test
Resolution - ( Replace the optional memory board
- Controller board defective.
2.Charge roller current leak
The polling module detects a current leak of the charge roller. Causes as follows' • Defective charge roller
• Defective high voltage supply board
• Loose connection of the PCU.
Feb 26, 2015 | Ricoh Office Equipment & Supplies
What does EE code on lg dryer mean
The EE error code stands for "EEprom Error" which means that the main control board EEprom program memory is defective.
Replace the main board.
Feb 19, 2015 | LG Washing Machines
He3 dryer no heat electric F01 code in diagnostics also f 28
The F1 error code means that the control board has detected a error within the control itself
the F28 means that the moisture sensor is defective,now the moisture sensor is justa metal bar that fits into the front of the drum and hardly ever bad so sad to say both error codes point to a bad control board that would need to be replaced.
GENE
Oct 12, 2011 | Kenmore Dryers
When cleaning the oven, F1 appears on the screen. What does this mean?
F1 - Board failure
Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Only solve with replace control board (also called ERC or clock).
Hope this helps.
May 19, 2011 | Whirlpool Ovens
Remote control functions Ok (ie display appears and settings can be changed), but the air conditioner unit does not respond. Can operate using ther manual switch on the inside unit, but does not get past...
Use your cellphone or any digital camera as your eyes by pointing the camera to the remote control transmitter. Light should emits on the remote control receiver. If no lights means defective remote control. But if lights emits means that either the receiver board or the main board is defective.
Try also the rst or reset button if present. Reset and try the remote.
Jun 02, 2009 | Heating & Cooling
In Ricoh aficio 401
The SC360 is Hard disk drive error 1. This means that the machine does not detect the connection signal from the HDD.
CHECK THESE; poor connection between the HDD and the HDD controller,
the AC power connector to the HDD is disconnected,
HDD defective,
HDD controller board defective,
BICU defective.
Make sure all connections are tight and secure, make sure power is connected securely, make sure HDD ( hard drive) is not bad if so replace. If the above are fine, replace the controller board and if the problem is still there, replace the BICU board.
Nov 15, 2008 | Ricoh 6513 Copier
Remote control
First you have confirm what really the defects is, is it the remote control or the control board.
HOW TO CHECK THE DEFECTIVE REMOTE CONTROL:
Check if the remote control if still good, using the camera of your cellphone point remote control to the cellphone camera and press the "on" button of your remote and you can see the light emitting from your remote control transmitter. If the lights emits that means your remote control is good, if not means the remote control is defective. If the remote emits light it means that the receiver at the control board in the indoor unit is defective.
Aug 18, 2008 | Fedders AED24E7F Wall/Window Air...
F1 flashing and blinking in middle of baking
F1 Circuit board defective Replace control board
F1 for frigidaire means it has a defective erc (control board)
Nov 20, 2007 | Frigidaire FGB24T3A Gas Single Oven
Frigidaire GLTF2940ES Front Load Washer Logo
19 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
